Old April 21st, 2010, 06:38 PM   #1
WELLS
Motorcycle(s): 07 250R
breather?
First off, great forum. I have turned a simple project on my 07 250 into a large one. My issue is with my airbox removal. I'm sure it has already been discussed, and I tried to find it so please bear with me. My concern is with the crankcase breather tube that originally ran to the bottom of the airbox, in the past after long rides I have noticed small amounts of oil in the box from this tube. What is the proper way to allow this tube to vent while keeping oil from " leaking " or ending up on the motor. Thanks.
Posted via Mobile Device
WELLS is offline   Reply With Quote
Old April 21st, 2010, 07:05 PM   #2
drstimpy
two wheels good
drstimpy's Avatar
Motorcycle(s): 04 ex250 and 08 Triumph Sprint ST and custom calfee carbon race tandem
put a cute little breather filter on the end of it...looks like a mini k and n filter. I have actually wondered if I could route it to my chain and have a low tech auto oiler???
Some must watch while others must sleep
drstimpy is offline   Reply With Quote
Old April 21st, 2010, 07:06 PM   #3
2WheelGuy
2WheelGuy's Avatar
Some people attach a small K&N filter to the crankcase breather outlet.
I prefer the racer method of attaching a small bottle to the frame and running a tube from the crankcase into it. My racing organization (AFM) requires a minimum 6 ounce clear bottle. Most racers use either a baby bottle or a bear shaped honey bottle with a Zip-Tie around its neck. Since you have removed the airbox their is plenty of space to find room for a small bottle.
AFM #278
Old April 21st, 2010, 07:15 PM   #4
WELLS
I
Thanks, that was my concern on running an open crankcase breather filter in that there was nothing to capture the oil. Does this catch can need to be able to return? Should it be vented?
Old April 21st, 2010, 07:44 PM   #5
greg737
Motorcycle(s): -
I think it should be vented. It was vented in it's original configuration (when it was attached to the air box).
I was thinking that a small model airplane fuel tank would do the job nicely. They come in all shapes and sizes. They are "fuel safe" if you make sure you buy one meant for gasoline type fuels (as opposed to methanol or oil/nitro mixture). Most of them are set up with two tubes so you could use one as the crankcase breather tube and the other could be the vent tube. You could hang it downward with the other vent tubes the EX-250 already has.
Old April 22nd, 2010, 07:00 AM   #6
Snake
Snake's Avatar
This just keeps getting better and better. I love your idea about using the model airplane fuel tank.
Old April 22nd, 2010, 07:12 AM   #7
2WheelGuy
2WheelGuy's Avatar
It does not need a return. I've ridden for years with only a tiny amount of oil accumulating in the catch. Yes, it does need to be vented.
AFM #278
Old April 22nd, 2010, 07:49 AM   #8
WELLS
Thanks for all the help, I will let you all know how it goes
Old April 27th, 2010, 07:49 AM   #9
HotWheels
Motorcycle(s): EX 250
Use filters like these
The first one is what I am using and it works great. Most auto parts stores will have at least one or the other on hand.
http://www.purolatorautofilters.net/...partnum=B23124
http://www.amazon.com/Fram-BA3749-FR.../dp/B000A09KM4
HotWheels is offline   Reply With Quote
Old April 27th, 2010, 08:03 AM   #10
2WheelGuy
2WheelGuy's Avatar
Photos of my setup:
AFM #278
Breather hole in block..?? Josh_kcco 1986 - 2007 Ninja 250R Tech Talk 11 August 21st, 2014 11:54 AM
Cleaning Crankcase Breather indr 2008 - 2012 Ninja 250R Tech Talk 6 January 10th, 2013 06:50 PM
Breather element woes LoD575 2008 - 2012 Ninja 250R Tech Talk 2 July 3rd, 2012 09:36 AM
Crankcase Breather POD zzrguy 1986 - 2007 Ninja 250R Tech Talk 7 May 2nd, 2012 10:28 AM
K&N Breather Filter indr 2008 - 2012 Ninja 250R Tech Talk 8 February 12th, 2011 11:35 AM
