May 28th, 2010, 02:53 PM | #1 |
Join Date: May 2010 Motorcycle(s): 08 ninja 250 Posts: 7
exhaust help?
i just installed a mgp growler on my 250 and the exhaust bolt seems kinda short. should I be worried? also should i use lock tight? can anyone help?
May 28th, 2010, 10:39 PM | #2 |
Join Date: May 2010 Motorcycle(s): 08 Ninja 250R Posts: 11
tighten it, should be ok... or get a longer bolt
May 28th, 2010, 11:23 PM | #3 |
Join Date: May 2010 Motorcycle(s): 2009 Ninja 250r, 1996 Yahmaha YZ 125... Both in Blue the coolest color Posts: 285
just got mine also, had the same problem but I just tightened it and it seems locked on.
May 29th, 2010, 02:06 AM | #4 |
super ninja
Join Date: Feb 2010 Motorcycle(s): 2009 kawasaki 250r Posts: 127
yeah i had that one before i got my akra and i had the same problem just push that bolt through and you'll be good might hurt ur hand a little tho
2009 Ninja 250r aftermarket parts *HotBodies double bubble* *Swing Arm Sliders* *Sylvania Sliverstar Ultra* *Akrapovic Slip-on* *Shinto Clip-Ons/Grips/Bar Ends* |
May 30th, 2010, 08:00 AM | #5 |
thanks for the help guys. i think i mite change the bolt just to be safe
June 1st, 2010, 02:35 PM | #6 |
just to let anyone know who also got the growler, i picked up a longer bolt and locktite at my local kawi dealer. seems to work alot better and the tech guy down there said it should be changed to the longer one.
FS: Area-P solo exhaust bracket for Ninja 300 w/stock exhaust | c-dog | Motorcycle-related | 2 | September 12th, 2014 10:48 AM |
How to remove stock exhaust and install aftermarket Slip-On Exhaust System Ninja 300 | SON1C | 2013 - 2017 Ninja 300 Tech Talk | 4 | August 14th, 2014 05:45 PM |
WTB: Area P full exhaust (or exchange 08+ stock exhaust) | mikecronis | Items Wanted | 0 | June 16th, 2010 05:54 AM |
