September 2nd, 2010, 04:02 PM | #1 |
Mad Scientist
Join Date: Jan 2010 Motorcycle(s): way too many to really consider without getting some kind of help.... Posts: 3
09 Ninjette wheel bearing removal
Hi!
I've got a set of 09 EX250 wheels that I am trying to get powder coated. I'm stuck at removing the wheel bearings in the hubs, both front and rear. I have not done this procedure before, can someone run me through it by chance? I don't have an EX, I'm just doing the powder and the lady that owns it is out of the country until December. Any assistance would be greatly appreciated! Lee Last futzed with by Swaggeringpagan; September 2nd, 2010 at 04:03 PM. Reason: turning on email notification |
September 2nd, 2010, 04:07 PM | #2 |
you'll need a long piece of some sort of steel rod. put the rod into the hole in the bearing and reach all the way over to the other side bearing. put the rod end on the other side bearing outer race and hit the rod w/ a hammer. it should come out as you work your way around the circumference of the opposite side wheel bearing. once you get one out, remove the axle tube inside the wheel and remove the remaining bearing the same way.
needless to say, you need to install new bearings when reassembling. |
September 2nd, 2010, 04:12 PM | #3 |
Ninjette CPT
Join Date: May 2009 Motorcycle(s): Black 08 250r Posts: A lot.
lee,
pm tims250r, he has a powder coating business and has done LOTS of motorcycle wheels. i'm sure he'll have all the tips you need. |
September 2nd, 2010, 04:41 PM | #4 |
Mad Scientist
Thanks gents, that worked out just fine. I just didn't want to damage her wheels..
September 2nd, 2010, 09:45 PM | #5 |
/moved to new-gen tech
September 3rd, 2010, 12:10 PM | #6 |
Mad Scientist
September 3rd, 2010, 04:29 PM | #7 |
No worries, that's what I'm here for...
replacing front wheel bearing question | mikedabike64 | 2008 - 2012 Ninja 250R Tech Talk | 3 | May 31st, 2014 05:20 PM |
Fix for front wheel squeak noise/Front wheel removal | cuong-nutz | 2008 - 2012 Ninja 250R Tech Talk | 13 | April 23rd, 2014 12:25 PM |
Replaced a NewGen front wheel? I need your bearing spacer! | InvisiBill | Items Wanted | 10 | February 20th, 2014 01:04 PM |
Wheel bearing quality | broken neck | 2008 - 2012 Ninja 250R Tech Talk | 15 | January 18th, 2014 07:34 PM |
Wheel Bearing?! | RiderOnTheStorm | 2008 - 2012 Ninja 250R Tech Talk | 3 | May 20th, 2012 07:12 PM |
