Old September 10th, 2010, 10:50 PM   #1
crackerjack
slightly mechanical
crackerjack's Avatar
Motorcycle(s): 2001 ninja 250; 1981 yamaha maxim 650(have not started working on her yet)
leaking petcock
2001
around the face plate on my petcock i have 2 screws, one of which is stripped and not holding the faceplate tight so it is leaking even in the odd position.
can i just use a bigger size screw to keep it tight?
crackerjack is offline   Reply With Quote
Old September 10th, 2010, 11:27 PM   #2
have you seen this?
http://faq.ninja250.org/wiki/Rebuild...tcock/fuel_tap
Old September 10th, 2010, 11:46 PM   #3
crackerjack
slightly mechanical
yea ive been there
im just wanting to know if it is ok to put a slightly larger screw in to hold the faceplate tight
Old September 11th, 2010, 12:31 AM   #4
sure... why not, you've got nothing to lose. perhaps something like self tapping machine screw might work better than just a larger diameter screw?
Old September 15th, 2010, 11:47 AM   #5
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Tap it out to the next larger size and use a larger screw, no big deal. Or, use a self-tapping screw, but be warned that self tappers don't make good enough threads to be much reusable. IOW, if you go that route plan on not messing with it later.
Leaking gas Alisha_Ardella 2008 - 2012 Ninja 250R Tech Talk 23 May 11th, 2015 10:41 AM
petcock leaking s3an78 1986 - 2007 Ninja 250R Tech Talk 15 August 18th, 2014 06:32 AM
Coolant leaking into oil and oil leaking out of somewhere. Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 31 May 25th, 2013 04:09 PM
Vacuum nipple came off petcock - fix or replace petcock? fierostetz 1986 - 2007 Ninja 250R Tech Talk 3 November 24th, 2012 11:03 AM
Fuel Petcock Leaking FrankW 1986 - 2007 Ninja 250R Tech Talk 9 July 8th, 2012 04:19 PM
