Old September 14th, 2010, 06:28 PM   #1
ReDnEcK
ReDnEcK's Avatar
Motorcycle(s): 2005 Kawasaki Ninja 250R
delete
delete
Last futzed with by ReDnEcK; October 2nd, 2010 at 12:27 AM.
ReDnEcK is offline   Reply With Quote
Old September 15th, 2010, 05:35 AM   #2
bamaland
bamaland's Avatar
Motorcycle(s): 93 kawi gpz500
after the 20mins does it idle steady and correctly?
if not try turning the idle screw on the left (clutch) side of the bike.. try in 1/4 turns to the right(clockwise)
if it does, probably bad gas? or clogged fuel filter. check filter and if dirty replace it, if its not then remove gas and replace with some good shell v-power
bamaland is offline   Reply With Quote
Old September 15th, 2010, 05:39 AM   #3
Are you riding the bike at the time, or are you just having it sit there with no load on the engine?
Old September 15th, 2010, 07:54 PM   #4
ReDnEcK
ReDnEcK's Avatar
I didnt know there was a fuel filter on a pregen... did I miss something?
Posted via Mobile Device
Old September 15th, 2010, 08:50 PM   #5
bamaland
bamaland's Avatar
its stupid small almost point less.
it will be inside the line going to the carbs. just look for a split in the line.
its a tiny cone filter that rest inside the fuel line
first thing i did was remove mine and replaced it with a true fuel filter
Need Help Diagnosing Bike That Wont Run Yondaime 2008 - 2012 Ninja 250R Tech Talk 25 October 4th, 2014 01:18 PM
09 Ninja 250r wont stay idle without choke TqAmsNy 2008 - 2012 Ninja 250R Tech Talk 11 March 20th, 2013 01:38 PM
Help!! Need advice... Bike Wont Run Trainsk8 2008 - 2012 Ninja 250R Tech Talk 3 May 30th, 2012 06:32 PM
Oil leaking out of airbox bike wont run properly peeweecollins General Motorcycling Discussion 18 July 9th, 2011 10:05 PM
Ninja 250r Wont Rev or run without choke esde 1986 - 2007 Ninja 250R Tech Talk 21 November 9th, 2009 02:32 PM
