Old November 17th, 2010, 02:24 PM   #1
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
A&L motorsports rearset adjusters?
Has anyone tried these?
http://www.a-lmotorsports.com/Produc...-adjuster.aspx
I'm not looking to replace the entire rearset. I would just like to have it shifted back a little bit. Does the brake line or anything need to be modified for shifting it back?
Old November 17th, 2010, 07:20 PM   #2
Plasmatoast
Plasmatoast's Avatar
Motorcycle(s): 09 250R - 08 250R - 03 250EX - 86 KLR 250
I believe that is the company that has taken over Cycle Controls operation,
If it is, then they bolt on then you have to change the sifter lever linkage with the included threaded rod. the brake line doesn't need to be changed but i does move a bit same with the reservoir hose.
Plasmatoast is offline   Reply With Quote
Old November 18th, 2010, 11:14 AM   #3
dubojr1
dubojr1's Avatar
Yep, you are correct.
Old November 18th, 2010, 11:58 AM   #4
HKr1
IC2(SW)
HKr1's Avatar
Thought these looked like the best version.
http://www.ninjette.org/forums/showt...ight=rear+sets
Old November 18th, 2010, 12:41 PM   #5
CThunder-blue
ModMy250.com
I've seen those. They're +$30 over the A&L ones.
Old March 16th, 2011, 01:27 AM   #6
spencerkro
Bump
spencerkro is offline   Reply With Quote
Old March 16th, 2011, 01:58 AM   #7
spencerkro
bump!
Old March 16th, 2011, 09:39 AM   #8
CThunder-blue
ModMy250.com
Why are you bumping?
The www.ModMy250.com guy
Old March 16th, 2011, 09:48 AM   #9
spencerkro
I want to get some feedback from people that have used these rearsets because I am interested in purchasing them myself.
Old March 16th, 2011, 12:57 PM   #10
austexjg
austexjg's Avatar
Motorcycle(s): '09 zx6r Green/Black, (ex-)Diablo Black '09 Ninja 250r
Just installed an older set from CycleControl - only needed to retap the bolt hole and adjust the gear shift pedal. I was pleased with the new set-up.
Last futzed with by austexjg; March 16th, 2011 at 04:13 PM.
austexjg is offline   Reply With Quote
Old March 16th, 2011, 02:01 PM   #11
dk58
dk58's Avatar
Motorcycle(s): 10 Ninja 250R
I installed my set on Saturday. I had the same problems CThunder had. The threaded holes needed to be gone all the way through with the tap, and I had to drill out the holes that connect to the frame.
dk58 is offline   Reply With Quote
Old March 16th, 2011, 02:44 PM   #12
CThunder-blue
ModMy250.com
you might be interested in this thread:
http://www.ninjette.org/forums/showthread.php?t=61545
Old March 16th, 2011, 02:45 PM   #13
CThunder-blue
ModMy250.com
I guess mine wasn't a fluke after all.
A&L Motorsports rearset adjusters Dr Honda Motorcycle-related 14 January 31st, 2015 04:55 PM
FS: A&L Rearset adjusters jp129 Motorcycle-related 3 June 29th, 2012 11:02 AM
FS: A&L Rearset Adjusters - Brand New Toly Motorcycle-related 6 May 21st, 2012 09:18 AM
A&L Rearset adjusters Group Buy!!! Kevin2109 Motorcycle-related 243 May 8th, 2012 03:10 PM
installed A&L Motorsports rearset adjusters. The Good & Bad CThunder-blue 2008 - 2012 Ninja 250R Tech Talk 21 May 28th, 2011 03:17 AM
