Old December 9th, 2010, 09:03 AM   #1
kashun84
kashun84's Avatar
Motorcycle(s): 2010 Lime Green 250R
Valve Shims questions
Guys, I am working on my valves. I went to the dealership where they offer a shim swapping, basically they take the shims you don't need and give you the shims you want at a lower price compaer to getting new shims. However, they didn't give me new shims and they are not from the Ninja 250. I took it home, measured the thickness to make sure they are what I want and they seems fit well as the OEM shims. My question is the manual said do not use the shims from other models. Should I order new oem shims for the valve job everytime or it will just works fine? Thanks a lot~~~~
kashun84 is offline   Reply With Quote
Old December 9th, 2010, 09:54 AM   #2
randomwalk101
self wrencher
randomwalk101's Avatar
if it's same size & correct thickness you're good. The manual is typed up by a secretary who just graduated from highschool with a C average....serious, if the dude was smart, won't you expect him to be a surgeon or something?
Old December 9th, 2010, 11:14 AM   #3
HKr1
IC2(SW)
HKr1's Avatar
Sure makes you wonder about the quality of after markets shims. When you can get 5 for a dollar...... and oem shims cost 10 -11 dollars each.
Hardness of the cheap shim is in question for me.
Old December 9th, 2010, 12:35 PM   #4
kashun84
kashun84's Avatar
Got it man, thanks a lot and I saw the source for a good set of aftermarket shims from the DIY thread.
Valve Adjustment: Clean cams,buckets,shims before re -install? Floki 2008 - 2012 Ninja 250R Tech Talk 24 January 11th, 2014 10:05 PM
Anyone stock valve shims in SoCal yblaser Items Wanted 1 June 23rd, 2012 08:34 PM
Where to find shims for valve adjustments cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 7 December 12th, 2011 06:42 PM
Carb - leaky float valve questions ako 1986 - 2007 Ninja 250R Tech Talk 34 June 15th, 2011 10:04 AM
Buying valve shims... headshrink 2008 - 2012 Ninja 250R Tech Talk 4 March 5th, 2010 01:24 PM
