Old January 18th, 2011, 06:54 PM   #1
Order
Order's Avatar
Motorcycle(s): 08 Ninja 250R (race), 01 Ninja ZX6R (race), 00 Ninja ZX6R (street), 03 R6 (race)
08 250R Dyno / after full exhaust + jetting
Here is a video from my last dyno run of my 08 Ninja 250R - no air filter, TYGA full round exhaust system and Factory Pro jetted carbs.
If you want specifics I did a writeup on my site: http://racingorder.com/2010/11/ninja...-dyno-results/
Order is offline   Reply With Quote
Old January 19th, 2011, 01:37 AM   #2
wayanlam
wayanlam's Avatar
Motorcycle(s): 2014 Z250
impressive dyno run, 32.3hp with just the Tyga exhaust, snorkel removed and stock jetting.
strange that jetting the bike would only get another 0.2 Hp over stock tho. makes me wonder how accurate the dyno was.
too bad you didn't get a reference run with the stock exhaust. that would have been a good indicator and interesting to see
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer
Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield
wayanlam is offline   Reply With Quote
Old January 19th, 2011, 02:56 AM   #3
sombo
Newb..... on a steeek! :D
sombo's Avatar
Motorcycle(s): 2012 Harley Davidson XL883L Sportster Superlow
Nicely done. After watching your video I watched one of the suggestions and found this one:
sombo is offline   Reply With Quote
Old January 19th, 2011, 05:15 AM   #4
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
This is from last year. Itis just fifth gear from idle to 14500 RPM to test top end Air fuel ratio.
I like the sound.
http://www.youtube.com/watch?v=269u3WNk6Ic
Old January 19th, 2011, 03:15 PM   #5
Order
Order's Avatar
I did get a stock exhaust reference... and I was told the dyno was accurate and tested against another local dyno. I still need to do further tuning, but I don't think it's too far off from what I'll race in the spring/summer.
See writeup with Stock vs. Snorkel removed vs. Snorkel removed + TYGA exhaust: http://racingorder.com/2010/10/tyga-...-dyno-results/
Old January 19th, 2011, 04:34 PM   #6
scotty
scotty's Avatar
Motorcycle(s): Yahama v star 650 classic
That is some good increase in power!
scotty is offline   Reply With Quote
Old January 19th, 2011, 04:43 PM   #7
Powerlogix
Powerlogix's Avatar
Motorcycle(s): 2010 ninja 250
Nice increase in power, how do you like your tyga exhaust?
Powerlogix is offline   Reply With Quote
Old January 19th, 2011, 04:49 PM   #8
sombo
sombo's Avatar
I also like how it seems to have smoothed out the power on the dyno. Can you feel it run smoother then stock?
Old January 19th, 2011, 05:06 PM   #9
Order
Order's Avatar
So far so good.. 8.6lb weight reduction sure didn't hurt! But I haven't had serious road time as I'm making it into a race bike.
Old January 19th, 2011, 05:13 PM   #10
Order
Order's Avatar
It certainly smoothed it out. From factory it was really rich, as the carb hadn't been adjusted before I put in the Factory Pro jet kit. I haven't had much time besides on the dyno, so I won't know how it's really running till I get it on the track... as I'm setting it up to race this season!
But for the price, the TYGA system is a killer deal for good performance gain vs. expensive brand name. I'm not affiliated with them nor do I sell anything, just giving my .02 cents from what I saw.
If anyone is interested there is a coupon code on my site for a sponsor that'll give you a decent discount.
Old January 19th, 2011, 05:41 PM   #11
DaBlue1
DaBlue1's Avatar
Originally Posted by Order View Post
... From factory it was really rich, as the carb hadn't been adjusted before I put in the Factory Pro jet kit.
That's good and interesting info to see because it's been reportedly lean from the factory below the mid-range, but it is not the first time I've read something similar to this. The race team in this article also found the stock bike carb setting almost perfect, so much so they reduced the stock jet size from 98-95 and added an Area P exhaust for their application. http://www.sportrider.com/features/1...250/index.html
What were your settings with the jet kit you installed?
Was the stock setting just rich at a certain range for you?
Old January 19th, 2011, 06:15 PM   #12
dino74
dino74's Avatar
Thanks for the info! I got the TYGA system and I'm just waiting for the K&N pods / Factory Pro Kit to arrive.
Maybe I'll dyno the bike this weekend to get more stock/modified data out to the 250 community.
Also I have an AEM UEGO A/F gauge. Hmmmm, I think at first I'll just change the exhaust and see what the A/F.
Old January 19th, 2011, 06:54 PM   #13
wellcraft
wellcraft's Avatar
Motorcycle(s): Ninja 250R
How much does a dyno run cost?
wellcraft is offline   Reply With Quote
Old January 19th, 2011, 07:13 PM   #14
dino74
dino74's Avatar
I called a place by me and they said it was around $65
Old January 19th, 2011, 09:00 PM   #15
Order
Order's Avatar
I'm really interested to see what data you get, if you dyno the bike. And what kind of A/F readings you get before jetting.
Old January 19th, 2011, 09:17 PM   #16
kingkang204
Motorcycle(s): Bike-less, Can I ride yours?
^ Did you happen to ride today? It was kinda cold down here in Olympia, but I went out and rode like 40 miles anyway. I'm sure being pretty much sea level helps our power delivery. I'm still contemplating racing this year in the Ninja Cup because I really don't think I'm on that skill level yet. I think more realistically I'll be taking track day classes at Pacific Raceways.
kingkang204 is offline   Reply With Quote
Old January 19th, 2011, 09:55 PM   #17
dino74
dino74's Avatar
I made a dyno appointment for Saturday @ 3pm, so I should be able to change out the exhaust on Sunday.
I'm just worried about it being too lean and damaging the engine. I guess if the meter shows it dangerously lean, I could turn the choke on until I get home.
Old January 19th, 2011, 10:51 PM   #18
Order
Order's Avatar
Wait, shouldn't you dyno after you swap the exhaust? Ideally before and after...
As for the A/F, I'd go off the meter and be prepared to make changes if need be or not ride back.
Old January 19th, 2011, 10:55 PM   #19
Order
Order's Avatar
No, haven't ridden for a while sadly. It's been so damn cold and rainy, roads are usually frozen in places from the night before. Being near sea level I'm sure help...
Have you done a track day or raced before? I'd think racing a 250 would be FAR more fun than a track day, since you'd be racing against 250's and not on the track with a wide range of bikes. As for not being on the skill level for racing, go through the Novice program, race the 250 and you'll learn a lot from the experts. There will be other Novices racing in the Ninja Cup.
Old January 19th, 2011, 11:09 PM   #20
dino74
dino74's Avatar
I really should do three dynos
  1. Stock
  2. Stock Intake/Jet with modified exhaust
  3. Modified Intake. Jets, and exhaust
Old January 19th, 2011, 11:12 PM   #21
Order
Order's Avatar
  1. Stock
  2. Stock Intake/Jet with new exhaust
Yes! Although if you're getting charged by the hour, you might want to jet it another time.
FS: Customled Kit and Area P Full Race Exhaust+Dyno Jet Race Kit n250r Motorcycle-related 7 January 30th, 2014 03:27 PM
Area P full race exhaust/jetting/airbox-delete/kleen-air delete.. corksil 2008 - 2012 Ninja 250R Tech Talk 24 January 21st, 2014 07:57 PM
Jetting, Dyno Tuning, AFRs??? Help A Jiglet Out Jiggles 2008 - 2012 Ninja 250R Tech Talk 134 November 3rd, 2012 10:10 PM
Full exhaust + airbox mod = how hi maintenance are the carbs/jetting? 675Raisinator 2008 - 2012 Ninja 250R Tech Talk 14 December 27th, 2011 12:05 PM
Dyno Charts with jetting and stock exhaust? KURT 2008 - 2012 Ninja 250R Tech Talk 5 February 27th, 2011 10:03 AM
