Old February 10th, 2011, 04:18 PM   #1
RedRider715
Motorcycle(s): 2009 Ninja 250
Diode Mod.
I have heard a few people talking about a diode mod that can be done. I am not sure what it improves or how to do it. If someone can help me out with that it would be great.
Thanks,
Joe
RedRider715 is offline   Reply With Quote
Old February 11th, 2011, 10:58 AM   #2
kamikaze
ex-ninjette.org guru :o
kamikaze's Avatar
Motorcycle(s): 2003 SV1000 S
it's to allow for use of LED bulbs in turn signals. According to a friend of mine (he's an engineer) he said that the way our blinkers are wired up its using the side that's not flashing for ground. since LED's don't have as much resistance, if you put LED bulbs in all the way around, you'll get 4 way flashers instead of signal lights. the diode mode fixes that. it keeps the current from backflowing to the side you don't want flashing and adds a ground behind the cluster.
the post here has pictures that helped to explain it for me. http://www.ninjette.org/forums/showp...91&postcount=6
you don't need anything fancy for diodes either, should be able to pick them up at radio shack.
kamikaze is offline   Reply With Quote
Old March 10th, 2011, 05:36 PM   #3
Whats the best ground to use or do I just pick one? Right now I'm running LEDs, but I took out my indicator bulb so to get rid of the four-way flashing. Went for a ride today, and it was really annoying not having an indicator.
Old March 12th, 2011, 07:27 AM   #4
kevlar250
kevlar250's Avatar
Motorcycle(s): '94 Vulcan 1500, '06 Katana 600, '08 FZ1
Use the ground (black or black w/yellow stripe) for the dash illum. bulb right next to the turn ind. bulb. A scotchlock connector works great for tapping into it.
kevlar250 is offline   Reply With Quote
Old March 12th, 2011, 08:40 AM   #5
Thanks. Thats what I ended up doing last night and it seemed to work
Wiring a DIODE for 4 L.E.D turn signals AnarchoMoltov 2008 - 2012 Ninja 250R Tech Talk 126 November 9th, 2021 12:13 PM
Does my pre-gen need the diode mod? mayonaise_invasion 1986 - 2007 Ninja 250R Tech Talk 16 August 22nd, 2014 11:31 AM
Bad Diode red5 2008 - 2012 Ninja 250R Tech Talk 3 July 26th, 2012 04:27 PM
No-cut Diode kit CThunder-blue Motorcycle-related 16 July 24th, 2012 09:37 PM
LED/DIODE question. Seattle_Chris 2008 - 2012 Ninja 250R Tech Talk 8 June 23rd, 2010 08:48 AM
