Old March 30th, 2011, 04:58 PM   #1
Choter
Motorcycle(s): 08 ninja 250r
BRT TIS kick-stand kill working
Purchased the programmable unit from Matt, this one was dated 3/16/2011 and it seems now the kill switch for the kick stand is functional he told me to post it up.
Choter is offline   Reply With Quote
Old March 30th, 2011, 05:09 PM   #2
randomwalk101
self wrencher
randomwalk101's Avatar
That's cool. I got one of the older one and kick stand is not working. Any way to update the firmware?
Old March 30th, 2011, 05:17 PM   #3
ok general question here. What are the benefits of advancing the ignition? I know it requires you to use higher octane gas to avoid knocking, but I don't know much other than that
Old March 30th, 2011, 05:20 PM   #4
randomwalk101
self wrencher
Cuz stock cdi bad
Old March 30th, 2011, 05:47 PM   #5
Originally Posted by randomwalk101 View Post
Cuz stock cdi bad
...embellish on that for me maybe?
Old March 30th, 2011, 05:51 PM   #6
randomwalk101
self wrencher
Or search the forum may be?
Old March 30th, 2011, 05:56 PM   #7
g21-30
g21-30's Avatar
May not have to use higher octane gas! YMMV
Old March 30th, 2011, 06:09 PM   #8
I have been searching. I know that people have changed to the pregen CDI because theirs acts funny when it warms up, but I'm not asking about the physical CDI, I'm wondering what advancing the ignition does.
Old March 30th, 2011, 06:11 PM   #9
randomwalk101
self wrencher
Adv timing gives a lil better response and may be hp but I swapped it out bc of bad cdi (fluct rpm).
Old March 31st, 2011, 04:28 AM   #10
g21-30
g21-30's Avatar
http://www.circletrack.com/howto/184...nce/index.html
Old March 31st, 2011, 05:48 AM   #11
dubojr1
dubojr1's Avatar
It helps the fuel to burn more completly as the RPM of the engine gets higher in turn producing slightly better HP in each cylinder.
Hope this helps. This subject can get real technical.
Old March 31st, 2011, 08:13 AM   #12
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
It makes the spark plugs fire at a different time during the compression stroke. When the timing is advanced, the combustion cycle happens earlier since the spark plug ignites earlier. Hence the term "advanced timing."
http://en.wikipedia.org/wiki/Ignition_timing
Timing advance is required because it takes time to burn the air-fuel mixture. Igniting the mixture before the piston reaches TDC will allow the mixture to fully burn soon after the piston reaches TDC. If the air-fuel mixture is ignited at the correct time, maximum pressure in the cylinder will occur sometime after the piston reaches TDC allowing the ignited mixture to push the piston down the cylinder with the greatest force. Ideally, the time at which the mixture should be fully burnt is about 20 degrees ATDC. This will utilize the engine's power producing potential. If the ignition spark occurs at a position that is too advanced relative to piston position, the rapidly expanding air-fuel mixture can actually push against the piston still moving up, causing pre-ignition and possible engine damage. If the spark occurs too retarded relative to the piston position, maximum cylinder pressure will occur after the piston is already traveling too far down the cylinder. This results in lost power, high emissions, and unburned fuel.
Simple answer is that with a correctly timed engine, you will be able to maximize power output.
It's good to know they fixed the kickstand kill switch issue.
The www.ModMy250.com guy
Old March 31st, 2011, 11:39 AM   #13
tac12345
Motorcycle(s): Ninja 250r 09 SE
Nice !
It was the only think that wasn't cool about this CDI.
tac12345 is offline   Reply With Quote
Old March 31st, 2011, 01:53 PM   #14
austexjg
austexjg's Avatar
Motorcycle(s): '09 zx6r Green/Black, (ex-)Diablo Black '09 Ninja 250r
I have never forgot about the kickstand, so this was not that big of a deal, but I could see a noobie needing it - kept the original CDI if I resale.
I have the non-programmable unit.
austexjg is offline   Reply With Quote
Old March 31st, 2011, 02:35 PM   #15
Those articles made sense. Now there's 2 things on my list of what Kawasaki should do to the ninja next. FI, and revisit the CDI.
Old March 31st, 2011, 03:03 PM   #16
CThunder-blue
ModMy250.com
They already have FI for the ninja, just not in the US.
Old March 31st, 2011, 05:33 PM   #17
HKr1
IC2(SW)
HKr1's Avatar
The FI bikes dont have a CDI.
Then I have to laugh... I was thinking theres nothing in that pic... we need a video. It is when you click on it LOL
Old March 31st, 2011, 09:15 PM   #18
ztrack157
The Sportisi Master
ztrack157's Avatar
Motorcycle(s): 2008 Ninja 250
Nope the new cdi's are built differently.
Sportisimoto USA is born.
ztrack157 is offline   Reply With Quote
Old April 1st, 2011, 07:51 AM   #19
tac12345
the programable and the non programable are fixed ?
Also for street use, the non-programable would be okay i guess ?
Old April 1st, 2011, 12:06 PM   #20
ztrack157
The Sportisi Master
ztrack157's Avatar
They weren't broken in the first place.
I recommend non programmables for anyone who is not doing timed events. The thing I don't like about non programmable is you cannot trouble shoot them. The programmables can be reset.
Old April 1st, 2011, 12:14 PM   #21
randomwalk101
self wrencher
how much for a non-prog costs now?
Old April 1st, 2011, 12:40 PM   #22
ztrack157
The Sportisi Master
ztrack157's Avatar
http://www.sportisimoto-usa.com/ignition.php
Old April 1st, 2011, 12:57 PM   #23
tac12345
Can you use regular 'super' fuel without adding octane booster when using the non programmable unit ?
Old April 1st, 2011, 01:06 PM   #24
randomwalk101
self wrencher
i use 93 octane (premium fuel). There were a couple occasions where I forgot and pumped 87 octane (regular) and it worked just fine.
Old April 1st, 2011, 01:43 PM   #25
austexjg
austexjg's Avatar
How much of a difference did you notice with the second map and 93 octane? I have yet to even hook-up the map button. I have bought a few different set of connectors, but none were the right size to use without slicing the wires coning from the unit - that, and I'm lazy.
BRT TIS troubles hoodadooda 2008 - 2012 Ninja 250R Tech Talk 54 May 25th, 2013 08:16 PM
BRT TIS 87 Octane etiainen 2008 - 2012 Ninja 250R Tech Talk 13 August 23rd, 2011 07:53 AM
Shimming or BRT TIS? tjb0012 2008 - 2012 Ninja 250R Tech Talk 14 April 26th, 2011 02:30 PM
Kick Stand Solution using the BRT TIS??? dubojr1 2008 - 2012 Ninja 250R Tech Talk 34 September 7th, 2010 10:16 PM
BRT TIS is Finally here ztrack157 Motorcycle-related 20 July 10th, 2009 12:10 AM
