Old April 12th, 2011, 06:35 AM   #1
singlecoillover
singlecoillover's Avatar
Motorcycle(s): 09 Ninja EX250-J Special Edition
Poor MPG
So according to my last fillup I'm getting just shy of 47 MPG with my 09 SE. This isn't the first time I've seen less than impressive numbers with this bike. The other week I ran the bike bone dry with 196 miles to a FULL tank. So 196 / 4.4 = 44ish mpg. That was before I shimmed the carbs and added the 2-bros slip on. I have to say I'm a little upset. The whole reason I went with a 250 again is because of the MPG. Heck even my old 87 ninjette got 50mpg, but right now my almost-new 09 with 3500 miles only beats my car and my old Nighthawk 750 by a paltry 5-7 MPG.
What gives?
I ride a mixture of highway and backroad cruising. Nothing wild or crazy; very little WOT. I am convinced that these numbers just should not be. I am considering having the dealer take a look at my bike, but that could get really expensive. I do have the good times protection plan, but I have no idea what that covers.
singlecoillover is offline   Reply With Quote
Old April 12th, 2011, 06:57 AM   #2
warlord
warlord's Avatar
Motorcycle(s): 2014 Ducati Panigale 899
Yeah, I don't know but that sounds terrible.
I'm still in the break-in period but my last tank was 4.2gal @ 228 miles or 54 miles per gallon. It's going to take a while before I can calculate average fuel economy though. Is there a thread of experienced fuel economy with mods? It would be handy since gas prices are increasing...
warlord is offline   Reply With Quote
Old April 12th, 2011, 08:01 AM   #3
cwb48
Mature motorcyclist
cwb48's Avatar
Motorcycle(s): 2008 Ninja 250R, blue
Yeah, it's true, the '08 forward are not as good as the previous model on mpg. My '01 consistantly got 69-72 mpg, and the best I've done with the '08 is 62. I'm afraid to check it now that I've shimmed the needles.
Chris
cwb48 is offline   Reply With Quote
Old April 12th, 2011, 08:12 AM   #4
sombo
Newb..... on a steeek! :D
sombo's Avatar
Motorcycle(s): 2012 Harley Davidson XL883L Sportster Superlow
Don't feel bad, after I had my 94 serviced by a dealer about a month ago it dropped by 10mpg from over 50mpg (with mods) to in the 40's. So I'm soon getting it looked at by a different shop to get the 18k service, fix an exhaust leak and try retuning the carbs which I think might be set too rich.
sombo is offline   Reply With Quote
Old April 12th, 2011, 09:23 AM   #5
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
Sell it or trade it in and get the Honda CBR 250 I don't think I've ever gotten 50mpg, I've always been in the 40's, but my bike has the carbs and such worked on so it uses more fuel anyways.
The www.ModMy250.com guy
Old April 12th, 2011, 10:44 AM   #6
What gives?
you actually filled 4.4 gallons of fuel into your tank?
Old April 12th, 2011, 10:48 AM   #7
play2pwn
Only the good die young
Motorcycle(s): 2011 ninja 250r SE
Mines even lower im gettin 182 for a full tank im still in the break in period havent shimmed the needles since no hardware is sellin 3mm washer so ill order online
My friend told me thay my bike is not breathing well maybe becoz he ride an R1 and tried my bike
play2pwn is offline   Reply With Quote
Old April 12th, 2011, 10:53 AM   #8
nakedhunter
Motorcycle(s): 2009 Ninja 250R (RED)
I have a 2009 and get right at 55 mpg rejetted and Area P exhaust, thats it at about 1400 miles. Had a 2002 and got almost 60 mpg.
nakedhunter is offline   Reply With Quote
Old April 12th, 2011, 11:53 AM   #9
singlecoillover
yeah. It was so empty it wouldn't start. So I filled a 1 gallon gas can and emptied that into the bike to get it running. Then I rode up the street to the gas station and put 3.4 gallons in at the pump.
I've read that during the break in period gas mileage is lower, but with 3500 miles my bike should be broken in. I am gonna talk to my dealer and maybe go back to stock and check mileage again. Even though it seems to be getting better after shimming and pipe. I did use 2 washers on each needle.
It's nice to know I'm not the only one.
Old April 12th, 2011, 12:04 PM   #10
http://www.ninjette.org/forums/showthread.php?t=13536
Old April 12th, 2011, 12:19 PM   #11
DaBlue1
DaBlue1's Avatar
Cooler weather temps will affect with your gas mileage, especially with carbs. Gas vaporizes better at higher temps. Altitude, air temperature, and humidity are big factors that will affect how an engine will run. Air density increases as air gets colder. This means that there are more oxygen molecules in the same space when the air is cold. When the temperature drops, the engine will run leaner and more fuel will have to be added to compensate. When the air temperature gets warmer, the engine will run richer and less fuel will be needed.
A bike will run richer as humidity increases and lean out or run better with less humidity. Depending on which State you live in, the blend of gas you get will decrease your gas mileage. Some states have a winter and summer blend gas.
The Ninjette simply runs better in temps over 70 degrees and avg humidity.
Last futzed with by DaBlue1; April 12th, 2011 at 03:00 PM.
Old April 12th, 2011, 03:58 PM   #12
singlecoillover
I never knew that. That could be why I'm having trouble. Our temps really haven't been that warm lately. A lot of my riding has been in 40 - 50 degree weather.
I called the dealer and they really couldn't tell me anything besides what the EPA estimate was (49.)
Old April 12th, 2011, 04:26 PM   #13
warlord
warlord's Avatar
Most of my riding has been from 30-50 degree weather. I'm interested to see what I'll get when the weather gets warmer.
Old April 12th, 2011, 04:57 PM   #14
edwinmcq
edwinmcq's Avatar
I never really thought about it...
I almost always ride in the city and when I have done tests it has come out to roughly 44 on the low side and 54 on the high side.
Which is a 500 to 700% increase in MPG over my other means of transportation...540i M-sport.
www.edmcqueen.com
edwinmcq is offline   Reply With Quote
Old April 12th, 2011, 05:43 PM   #15
kamikaze
ex-ninjette.org guru :o
kamikaze's Avatar
Motorcycle(s): 2003 SV1000 S
in a little over 10,000 km I'm averaging 5.3L/100km which is 44mpg. I ride it like it's stolen
edit: BTW, anyone with an iPhone, an awesome app to track your fuel mileage is AccuFuel. I track my mileage everytime I fill up.
kamikaze is offline   Reply With Quote
Old April 12th, 2011, 05:51 PM   #16
setasai
setasai's Avatar
I dont really go WOT often but my commute is 11 miles half city, half freeway and I've been getting 46-48mpg. To be honest, I dont think I've gone past 51/52mpg max ever.
49.4 mpg? noche_caliente 2008 - 2012 Ninja 250R Tech Talk 33 August 24th, 2017 02:03 PM
36 MPG!! Z1R rider Ninjettes At Speed 4 June 20th, 2014 08:24 PM
MPG Chip cuz Off-Topic 1 January 31st, 2013 06:54 PM
MPG Xsavior 2008 - 2012 Ninja 250R Tech Talk 6 November 20th, 2012 07:02 PM
The best mpg egb1108 General Motorcycling Discussion 29 August 31st, 2011 11:46 AM
