Old April 13th, 2011, 09:57 PM   #1
kingkang204
Motorcycle(s): Bike-less, Can I ride yours?
Brake scraping while turning?
I'm not sure if its actually the brake or not but it's the same sound as if you where using your front brake to slow down. And every time I start to lean it makes the sound as if I'm braking when I'm not touching either of the brakes.
Do your 250's make this sound also or is something wrong?
Thanks!
kingkang204 is offline   Reply With Quote
Old April 13th, 2011, 10:32 PM   #2
setasai
setasai's Avatar
Something is definitely wrong. Everything is very smooth when I lean/turn.
Check all your cables and make sure nothing is pinching. Turn your wheel and look at what it's touching and see if you can see some obstruction or tension that's causing it.
Peg Scraping? mrudich Riding Skills 39 June 12th, 2014 08:19 AM
Front brake pads/rotor scraping WAGESLAVEesc 1986 - 2007 Ninja 250R Tech Talk 8 June 3rd, 2014 06:13 PM
foot scraping.. Josh_kcco General Motorcycling Discussion 13 May 7th, 2014 03:10 PM
Scraping Pegs... Dangerous!? ahskeetz Riding Skills 14 April 21st, 2009 07:07 AM
