April 15th, 2011, 02:16 PM | #1 |
Bushmaster11B
Join Date: Mar 2011 Motorcycle(s): 2009 Kawasaki Ninja 250R "Limited Edition" w/ Metallic, Pearl Essent, Candy Coat 3 Tone Paint Job Posts: 181
Can I go wrong with just a CAN?
I talked about rejetting my bike and placing a pod filter on it. What if I just leave that alone and put a Slip-on Exhaust or Full Exhaust on it? Would I still have to rejet it? And where can I find an exhaust system or slip-on dirt cheap? Thanks for your help.
I love Afghanistan.................. NOT!
http://r9.fodey.com/2166/7fddc3a7c75...978e4f3c.0.gif |
April 15th, 2011, 03:16 PM | #2 |
Join Date: Mar 2011 Motorcycle(s): 899, 748, 250, 250, 70 Posts: 348
Generally speaking, you can usually add a slipon without rejetting.
With that being said, unless it's been properly dyno-tuned, the carbs probably need some attention anyway; bikes come from the factory set up for emissions, not ideal power delivery. |
April 15th, 2011, 03:20 PM | #3 |
Bushmaster11B
just afraid I may screw things up. do you know where I can find a good carbon fiber can that looks good? looking to spend around 200.
April 15th, 2011, 03:26 PM | #4 | |
If it were me, though, I'd save up and get a full system; I just installed the Area P on my racebike, and it looks pretty boss. |
April 15th, 2011, 08:22 PM | #5 |
no joy
Join Date: Nov 2009 Motorcycle(s): Ninja 2006 636 Posts: 408
Is that the 25mm Bushmaster?
Posted via Mobile Device |
April 15th, 2011, 09:14 PM | #6 |
Join Date: Mar 2011 Motorcycle(s): 2009 Ninja 250 Posts: 31
I got two bros on eBay for 300 shipped. I was also looking at the hmf on there as well. It's black aluminum for 248 shipped. I'll post a link as soon as I get off work
April 15th, 2011, 10:57 PM | #7 |
Bushmaster11B
I have no clue what you are talking aout....
April 15th, 2011, 10:59 PM | #8 |
Bushmaster11B
sweet, thanks man. I think I seen the HMF on ebay as well. Still post it though. It says full exhaust system but does show list of parts. Fishy
April 15th, 2011, 11:00 PM | #9 |
i just picked up a danmoto exhaust from china 127 shipped to tx havent got it yet but check out the reviews on here and google
April 15th, 2011, 11:02 PM | #10 | |
Bushmaster11B
NOTE 2 EVERYONE: Can you post a link if you find a deal? Thanks...
April 15th, 2011, 11:14 PM | #11 |
http://cgi.ebay.com/ebaymotors/HMF-B...Q5fAccessories
There is the link for the hmf. I searched YouTube and it sounds really nice |
April 16th, 2011, 05:57 AM | #12 | |
Hot Wheels
Join Date: Mar 2011 Motorcycle(s): 2010 Kawi Ninja 250R Posts: 64
April 18th, 2011, 08:37 PM | #13 |
There's a limit to s2pdty
Join Date: Apr 2011 Motorcycle(s): 250r ninja (sold) Posts: A lot.
I have the HMF carbon fiber slip on, and I love it! it sounds awesome! I think i got it for like $250 (I didn't rejet/ shim or anything, i still want to get good mpg)
But if I have a "rewind button" I'll get this instead http://cgi.ebay.com/ebaymotors/YOSHI...Q5fAccessories |
April 19th, 2011, 04:23 AM | #14 | |
Bushmaster11B
April 19th, 2011, 04:25 AM | #15 |
You are going to get popping and backfiring with any exhaust. You have to block the kleen air system off
April 19th, 2011, 05:51 AM | #16 | ||
April 19th, 2011, 06:10 AM | #17 |
Even if the manufacturer say no rejet or shims needed, i.e. mgp growler, the bike will run even leaner and way hotter. Mine was running almost 300 degrees hotter at the header with my growler.
April 19th, 2011, 08:26 AM | #18 |
April 19th, 2011, 12:30 PM | #19 |
April 19th, 2011, 07:51 PM | #20 |
mmm interesting maybe that's why she gets hot really fast. but I'm not having any problems. (maybe it's time for me to shim the needles then)
April 19th, 2011, 11:32 PM | #21 |
I haven't had any problems as of yet. I'm shimming mine anyways tho just because I want to put pod filters on
April 20th, 2011, 07:12 AM | #22 |
IC2(SW)
July 10th, 2011, 10:59 AM | #23 |
Bushmaster11B
found a JT-5 full exhaust online for $308 (new).... I would have to shim huh?
September 1st, 2011, 07:58 AM | #24 |
shimming is a good idea even without any other modifications. gives the bike extra pepp in the midrange
September 2nd, 2011, 10:29 AM | #25 |
Bushmaster11B
I have a hollowed OEM pipe right now and I shimmed with #3 washers. Used 2 on each needle and now she is way more responsive.
What am i doing wrong? | jbraz7 | 1986 - 2007 Ninja 250R Tech Talk | 22 | April 28th, 2016 05:17 AM |
Talk about wrong time, wrong place | tlhamon | General Motorcycling Discussion | 8 | February 1st, 2015 12:07 PM |
What do you think is wrong with it? | Brother Michigan | 2013 - 2017 Ninja 300 General Discussion | 10 | August 25th, 2014 02:07 PM |
Right or wrong?? | almost40 | Off-Topic | 38 | March 19th, 2011 04:30 PM |
