Old May 2nd, 2011, 08:37 AM   #1
the big mike
the big mike's Avatar
Motorcycle(s): 2008 Ninja 250r, Fazer8
What's this thing?
I wanted to clean my bike thoroughly and so I removed the fairings (special thanks to the DIY: let's get nakid)
After everything was clean and putting my bike back together, I found this piece on the ground. I'm sure I haven't removed it myself, I must have fallen of something. It's made of rubber and has one sticky side.
Thx for your help if you recognize this thing. I don't think it has any importance for the bike as I had no trouble putting it all back together. But I like to see my bike 'complete'
the big mike is offline   Reply With Quote
Old May 2nd, 2011, 08:48 AM   #2
lux
http://www.ninjette.org/forums/showt...rubber+fairing
lux is offline   Reply With Quote
Old May 2nd, 2011, 08:52 AM   #3
dubojr1
dubojr1's Avatar
Pretty sure it is just a spacer. Others (and myself) have said theirs fell out too. I think it is supposed to be stuck on the fairing to space it out just a bit to avoid vibrating against the tank. See if you can find the sticky adhesive on the fairing where it came off. I believe it is around one of the mounting bolts. Good luck!
Old May 2nd, 2011, 09:13 AM   #4
bob706
bob706's Avatar
Had one on my bike fall off the other day. Good to know where it came from now
Old May 2nd, 2011, 09:13 AM   #5
scotty
scotty's Avatar
Motorcycle(s): Yahama v star 650 classic
I thik it slides onto something up by the gas tank in I remeber correctly.
scotty is offline   Reply With Quote
Old May 2nd, 2011, 09:21 AM   #6
setasai
setasai's Avatar
On each fairing there are 2 larger bolts. One next to the foot pegs and one higher up next to the seat. Those rubber things stick onto the bracket between the fairing. It keeps falling off but that's where its supposed to go. Each time removing the fairing, I just put it aside and stick it back on with some double sided tape.
I didnt have time to take a picture on my bike but this should work.
Old May 2nd, 2011, 11:34 AM   #7
dubojr1
dubojr1's Avatar
Yep....
Old May 2nd, 2011, 11:32 PM   #8
the big mike
Thx guys
Old May 3rd, 2011, 12:15 AM   #9
wayanlam
wayanlam's Avatar
Motorcycle(s): 2014 Z250
actually that lil rubber part doesn't go where Brian pointed out, it sticks on a different part of the side faring:
this piece seems to have a tendency to fall off a lot, lol
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer
Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield
wayanlam is offline   Reply With Quote
Old May 3rd, 2011, 09:25 AM   #10
setasai
setasai's Avatar
If that's the case then I wonder if the dealer got it mixed up too because the only reason why I thought it was there is because the first time I took the fairings off, 1 fell off and the other was still stuck to the bracket on the bike at that location.
Old May 3rd, 2011, 07:17 PM   #11
wayanlam
wayanlam's Avatar
its possible that they didn't know and stuck it where they "thought" it should go without actually checking
if they put that rubber piece where you indicated it could actually damage your faring. since it would add a spacer between the faring and the bracket mount. the bracket mount has a little protruding part that sits in the hole of the side faring. that prevents you from tightening the bolts too tight, potentially causing the plastic to crack.
adding that rubber piece on that part will raise the faring up, not something you want to do. however since its rubber, it probably isnt as bad as a solid spacer (steel washers).
next time you take the farings off i would recommend removing it from that spot
W.
I love this thing Apex Off-Topic 3 January 7th, 2014 08:20 AM
If it's not one thing....... DrewHamm974 1986 - 2007 Ninja 250R Tech Talk 7 April 23rd, 2013 01:11 PM
What is this thing? thisisbenji 2008 - 2012 Ninja 250R Tech Talk 17 January 5th, 2012 06:16 PM
What is this thing? sixer General Motorcycling Discussion 4 December 12th, 2009 10:13 AM
Its just one thing after another... Loaded Moses General Motorcycling Discussion 26 June 30th, 2009 11:12 AM
