May 10th, 2011, 08:37 AM | #2 |
Join Date: Oct 2009 Motorcycle(s): '09 zx6r Green/Black, (ex-)Diablo Black '09 Ninja 250r Posts: 959
17mm
May 10th, 2011, 08:57 AM | #4 |
KThanksBye
Join Date: Mar 2011 Motorcycle(s): 2006 zx636r Posts: A lot.
17mm is metric, everything on the bike is metric Don't ever use something that isn't the exact size or you'll end up stripping it
May 10th, 2011, 09:00 AM | #5 |
It doesn't matter which size.
May 10th, 2011, 09:01 AM | #6 |
KThanksBye
May 10th, 2011, 09:03 AM | #7 |
You can use either, most use a 1/2" - better?
May 10th, 2011, 09:05 AM | #8 |
KThanksBye
I'll bring a 17mm when we do the oil change
May 10th, 2011, 09:15 AM | #9 | |
Join Date: Nov 2010 Motorcycle(s): '09 250 Street, '09 250 Race, '13 300 Race Posts: A lot.
The oil drain bolt requires a torque of 19.6 NM. I don't think I've ever seen an 1/2" drive torque wrench that accurately measures that low of a torque. 1/4" drive torque wrenches cannot go that high. 3/8" drive is what you want. However you can still use a 1/2" drive socket with a 3/8" drive torque wrench if you use an adapter. Last futzed with by dino74; May 10th, 2011 at 10:15 AM. Reason: grammar |
May 10th, 2011, 09:23 AM | #10 |
KThanksBye
May 10th, 2011, 09:26 AM | #11 |
/moved to new-gen tech
May 10th, 2011, 09:55 AM | #12 |
Your right - 3/8" is the best option.
May 10th, 2011, 10:13 AM | #14 |
One question about torque wrenches:
Do 12 inch pounds = 1 foot pound? I'm just curious if it converts, because I bought a torque wrench that goes from 120 inch pounds to 960 inch pounds. I'm assuming this will work. |
May 10th, 2011, 10:17 AM | #15 | |
Jenn, you're lookin for like 172 inch pounds (172 in lbs). Most likely you're gonna wanna get a 3/8" drive torque wrench and then a 3/8" drive 17mm socket.
May 10th, 2011, 11:03 AM | #16 |
Join Date: Jun 2009 Motorcycle(s): '09 250R SE Lime Green Posts: 48
I agree, go with the 3/8ths.
One more thing I'd like to add, and if you know this already I apologize, but for anyone who doesn't; don't EVER use your torque wrench to loosen a nut or bolt. I have had several co-workers do this and completely wreck the torque wrench. Basically, you can damage the internal mechanism and from then on you think you are torquing to 19.6 Nm but in reality it is less than that. |
[motorcyclistonline] - Drive Chain Maintenance | Drive Time | Ninjette Newsbot | Motorcycling News | 0 | May 9th, 2013 05:30 PM |
[topix.net] - PHOTOS: Motorcyclists drive for Toys for Tots charity drive | Ninjette Newsbot | Motorcycling News | 0 | December 17th, 2011 03:00 PM |
how much does tire size affect the final drive? | Oaklandish | General Motorcycling Discussion | 16 | July 20th, 2011 09:10 AM |
steering head screw size | randomwalk101 | 2008 - 2012 Ninja 250R Tech Talk | 2 | May 4th, 2009 09:51 AM |
WTT: Size S Synergy Heated Gloves for Size M like kind | headshrink | Items Wanted | 0 | March 26th, 2009 01:45 PM |
