Old May 30th, 2011, 08:35 AM   #1
Tony B
Tony B's Avatar
Motorcycle(s): GPX250 + many others!
Re-use old head gasket ?
Ok, Ok, I know, of course I shouldn't re-use an old head gasket, but I want to get the bike running in a hurry and it's a bank holiday here in the UK. I've carefully scraped the old gasket cement off, should I use a very thin smear of gasket sealant on it, try it dry, or am I doomed to failure ??
Tony B is offline   Reply With Quote
Old May 30th, 2011, 11:28 AM   #2
oroboros
GDTRFB
oroboros's Avatar
Motorcycle(s): 2009 Ninja 250 - sold 2005 EX500R project
Get a new gasket. Seriously...
I don't want a pickle Just want to ride on my motorsickle
-Arlo Guthrie
oroboros is offline   Reply With Quote
Old May 30th, 2011, 11:34 AM   #3
scotty
scotty's Avatar
Motorcycle(s): Yahama v star 650 classic
Yup, never reuse a head gasket. For real. You will end up having to tear it down again and waste more time tring to fix it, rather than riding it.
scotty is offline   Reply With Quote
Old May 30th, 2011, 03:28 PM   #4
Tony B
Tony B's Avatar
OK, thanks for the comments, it's going downhill anyway now, I need a special spanner for adjusting the valve clearances, and I may have made a mistake with the cam chain tension. I timed the cams up as per the manual, set the tensioner, but when turning the motor over, even slowly, the chain is going slack at the front and the ex cam is skipping.
Just off to bed with my factory manual, to re-read and see what I've missed
Old May 31st, 2011, 08:35 AM   #5
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Just for clarity: Head gaskets typically have a metal "fire" ring at the combustion chamber. This ring is designed to crush to fit as the head bolts are torqued, and as such it stays permanently deformed. There is a high risk of failure of the fire ring when head gaskets are reused because it won't crush properly the second time around.
Old May 31st, 2011, 08:42 AM   #6
HKr1
IC2(SW)
HKr1's Avatar
Think he's talking valve cover gasket.
Head gasket would just be too funny........
Old May 31st, 2011, 02:46 PM   #7
Tony B
Tony B's Avatar
Cheeky sod, I WAS talking about the head gasket !!! I'm the eternal optimist, and I was in a hurry to get the damn back on the road.
Going to try and order a head gasket tomorrow .......
Old May 31st, 2011, 02:51 PM   #8
Tony B
Tony B's Avatar
You've got to bear in mind in 33 years of riding bikes and working on them, this is the first watercooled bike I've owned, (the other 40+ were aircooled), and often you could get away with re-using a head gasket. Triumph copper gaskets are the best, anneal them each time and re-use them ad infinitum.....
Old May 31st, 2011, 04:03 PM   #9
FrugalNinja250
Things change a bit when you start putting out 150 horsepower per liter...
Old May 31st, 2011, 11:54 PM   #10
Tony B
Tony B's Avatar
My '39 Triumph produces 18 BHP and is 600cc, that's around 30 per litre isn't it .... ?
Old June 1st, 2011, 06:27 AM   #11
FrugalNinja250
Hehehe... but it has lots of low-end torque!
100HP/L was a big deal when manufacturers were able to obtain it reliably, much like 1HP/Cu.Inch was back in the muscle car days. To put it in context, at 150HP/L a 5.7L car motor would be making 855HP. That's a lot. The main way bikes do it is with RPM, since HP is a function of torque and RPM. Smaller motors can spin higher RPMs.
Head Gasket Replacement tjkamper 2008 - 2012 Ninja 250R Tech Talk 10 August 13th, 2012 01:58 PM
Head Gasket torn indr 2008 - 2012 Ninja 250R Tech Talk 3 March 25th, 2012 02:13 AM
head gasket? NorthKoast 2008 - 2012 Ninja 250R Tech Talk 14 March 10th, 2012 04:01 PM
cylinder head cover - gasket headshrink 2008 - 2012 Ninja 250R Tech Talk 7 March 7th, 2010 04:22 PM
copper head gasket Racer x 2008 - 2012 Ninja 250R Tech Talk 3 February 13th, 2010 05:08 PM
