Old June 13th, 2011, 08:19 AM   #1
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Installed Stebel Nautilus air horn, a.k.a. Wolo "Bad Boy" horn
Bought it a year ago, decided to finally install it. Rummaged through my random hardware and found a steel angle brace. I drilled out the holes in it to fit the various bolts holding the relay and horn on, and to allow the stock Ninja horn screw to fit, then bent it around a little. The relay shown is what came with the kit, the stock horn wire terminals fit it perfectly. I ran two new wires back to the battery to power the horn itself as it draws up to 20 amps.
All in all it was a pretty straight-forward installation, and it is loud as heck.
The bracket, almost done. Just need to flatten out the kink in the vertical leg:
View showing the horn and relay mounted, still have to finish insulating terminals:
View from the front:
Final view from the side, everything clears through the full range of fork travel:
Old June 13th, 2011, 07:20 PM   #2
"A"
vampire
Motorcycle(s): 2 many 2 list
Question
Will the front fender hit the horn when the fork is compressed?
"A" is offline   Reply With Quote
Old June 13th, 2011, 07:49 PM   #3
Snake
Snake's Avatar
He answered that above the last pic.
Great job Frugal Ninja250. I.m sure that will get some attention. When I use my horn every one just turns and laughs.
Old June 15th, 2011, 06:14 AM   #4
FrugalNinja250
Update, I had to remove it for the time being. I didn't check for suspension travel, just rotational clearance, and it never occurred to me that the forks had that much travel, so yes, the fender hit the horn. Now have a 1/2" crack in the fender.
The horn is pretty bulky and has specific mounting orientation requirements, so it's going to be a challenge to find some place to mount it. If I do remount it I'll leave the relay in the old location because it's convenient to the OEM horn wire connection.
To say I'm disappointed having to go back to the lame meep meep horn would be an understatement.
Last futzed with by FrugalNinja250; June 15th, 2011 at 12:08 PM.
Old June 15th, 2011, 08:40 AM   #5
CynicalC
CynicalC's Avatar
Motorcycle(s): '96 EX250
There are some mounting ideas for that specific horn here:
http://faq.ninja250.org/wiki/I_want_a_louder_horn
Old June 16th, 2011, 07:46 AM   #6
FrugalNinja250
Followup: The horn sustained a small dent on top, enough to prevent the impeller from turning. It's toast. Took it apart to verify the failure mode theory, unfortunately the top cap had a machine-swaged attachment so no way to repair. Off to the store to get another one, lesson learned about front suspension travel.
Old June 16th, 2011, 09:14 AM   #7
CynicalC
CynicalC's Avatar
In that link, there are also some different horn suggestions that can be mounted in the stock location.
Old June 17th, 2011, 04:42 AM   #8
"A"
vampire
I saw it in the 3rd picture and thought the clearance would be problematic when the fork if compressed.. That horn seems way too big and heavy for the extra sound that it produces. I'd op for the slimmer profile and lighter weight 'freeway blaster' horn at 130+ db. Which has no need for a relay.
Old June 23rd, 2011, 05:37 AM   #9
FrugalNinja250
Finished installing the Wolo adjacent to the left coil per one option posted, works great! I will note that though the Wolo and Stebel appear similar at first glance, they are very, very different horns though laid out identically. I'll post some pictures next week.
I also ordered the high and low tone FIAMM Freeway Blasters, $10 each shipped off Amazon was a good deal. At some point I'll do a comparison between the two.
FS: Wolo Model 419 Bad Boy Air Horn Kit - 12 Volt (Automotive) tagged "motorcycle" 8 Amazon Postbot Amazon - Popular Motorcycling Items 0 April 23rd, 2013 04:52 PM
FS: Stebel Nautilus Compact Motorcycle Air Horn - Loud - Chrome tagged "motorcycle" 1 Amazon Postbot Amazon - Popular Motorcycling Items 0 April 23rd, 2013 04:52 PM
FS: Wolo Model 519 Bad Boy Chrome One Piece Design Air Horn Kit - 12 Volt (Automotiv Amazon Postbot Amazon - Popular Motorcycling Items 0 April 23rd, 2013 04:52 PM
[twisted throttle] - Stebel Nautilus Air Horn installed on a 1994 Yamaha Vmax Ninjette Newsbot Motorcycling News 0 September 22nd, 2011 01:40 PM
DIY Installing Wolo Badboy / Stebel Nautilus Horn kevlarorc 2008 - 2012 Ninja 250R Farkles 7 November 9th, 2010 06:21 AM
