Go Back   ninjette.org > General > Pictures
Old August 9th, 2011, 04:28 PM   #1
A7xschecter6661
A7xschecter6661's Avatar
Motorcycle(s): 2003 Yamaha R6
Clean black/green pre gen (many pics)
My progress so far:
Painted bottom fairing
Let me know if there's anything else you think I should do and how it looks so far
New heat shielding
250r stickers
ninja stickers
And finally the ninjette we just bought my mom with a parts bike for $1600
A7xschecter6661 is offline   Reply With Quote
Old August 9th, 2011, 04:40 PM   #2
Snake
Snake's Avatar
An 05 like mine. Great looking bike.
Old August 9th, 2011, 07:53 PM   #3
cerberusrex25
Accesories Guru
cerberusrex25's Avatar
Motorcycle(s): '99 EX250(Cafe/fighter project)
Clean and mean, love what you've done to it, any plans for flush mounted front signals?, maybe some bar end mirrors to give it an overall clean look.
cerberusrex25 is offline   Reply With Quote
Old August 9th, 2011, 08:12 PM   #4
A7xschecter6661
Ive thought about the gsxr/modern ninja mirror swap.
Maybe flushmounts, though I don't mind the stick out ones with the clean lenses.
Only problem being if it falls it 9/10 times cracks the fairings like my moms
If I did these I could get rid of the signals, get the ninja block off plates and have the signal in the mirror. Good to know...
http://cgi.ebay.com/ebaymotors/KAWAS...Q5fAccessories
Old August 9th, 2011, 11:18 PM   #5
hinow41
hinow41's Avatar
Motorcycle(s): 250r
Bike looks great! Nice and clean.
"What kind of bike is that"
"Ninja 250"
" Come on man stop joking around"
hinow41 is offline   Reply With Quote
Old August 11th, 2011, 03:42 PM   #6
cerberusrex25
Accesories Guru
Wow, those are a great idea bud, kill 2 birds with one stone.
Old August 11th, 2011, 07:11 PM   #7
SpeedDemon
SpeedDemon's Avatar
Motorcycle(s): 2009 Ninja 250
Black bike Black exhaust nice bike tho
Never ride faster than your guardian angel can fly
SpeedDemon is offline   Reply With Quote
Old August 11th, 2011, 07:17 PM   #8
Bosgarage57
Bosgarage57's Avatar
Motorcycle(s): 06 Buell Uly, 05 VStar 1100
One of the nicest pregens I've seen. Love the color. Good job.
Im running mirror block of plates, and bar end mirrors
Bosgarage57 is offline   Reply With Quote
Old August 11th, 2011, 07:56 PM   #9
A7xschecter6661
I don't like bar end mirrors
I am looking to get those mirrors with the signals built in though.
Winter project
My moms bike has the flat black exhaust and she said I could swap them but I just don't think it would look good. I would like to get aftermarket pipes or a 2 into 1 but they are so expensive its not even worth it
It looks so much better in person than it does in pictures. Impossible to get a pic of what it looks like in person
Old August 17th, 2011, 03:05 PM   #10
Tony B
Tony B's Avatar
Motorcycle(s): GPX250 + many others!
Nice bike, are those rear indicators built in to the tail piece a commonly found item ?
Tony B is offline   Reply With Quote
Old August 17th, 2011, 03:43 PM   #11
cerberusrex25
Accesories Guru
http://www.d2moto.com/p-7046-1994-20...h-signals.aspx
What I got, I just kept the red one for the stop because it looks way better.
Old August 17th, 2011, 11:07 PM   #12
Tony B
Tony B's Avatar
Thanks for the link, but it says for '94 up. Mine is an '89 and the sides of the tail are blank, no holes, just the indentations. Did they change the tailpiece on the later pre-gen?
Sorry for the questions, I'm still finding my way around these bikes, I'm not even sure if Kawasaki sold the later pre-gens in the UK, from what I've read, it seems they dropped it for several years before the new gen came out. So if there are detail differences in some components, it may not be an easy swap.
Old August 18th, 2011, 02:25 PM   #13
Timon
Timon's Avatar
Motorcycle(s): Ninja EX250R
In the states the tail on the pregens all have the blank spots for signals. Also at least on my bike it looks like the whole thing comes out as a unit. You could potentially get just the plastic housing of the tail piece from a different bike.
Look for something like this http://cgi.ebay.com/ebaymotors/06-Ka...item415c8a6bc9.
Timon is offline   Reply With Quote
Old August 18th, 2011, 11:09 PM   #14
Tony B
Tony B's Avatar
Hi, thanks for the link, but what are the side lenses, are they reflectors or light ?
Hang on a mo', I'll nip outside and photograph what the UK ones look like.
Here you go, does the lens clip on to those slots? If so, I guess I could mount some new light units after drilling a hole in the centre, then use a standard
lens.
Old August 18th, 2011, 11:52 PM   #15
Timon
Timon's Avatar
Honestly, it's hard to tell from the picture. Is there a slot on the top? Take out the center light and look how it mounts. there should be a slot on the top for it to fit into. The sides will need this same slot as well as a screw on the bottom corners (1 screw per side). Also keep in mind you'll probably have visibility issues with no reflective surface inside the lens.
Old August 19th, 2011, 12:06 AM   #16
Tony B
Tony B's Avatar
Hmm, I think there must be detail differences between them, no extra screw holes other than the two that hold the lens on. And yes, you're right about a lack of brightness if I just put light holders on the plastic. I may just have to use small flush mounted lights on the side of the tail, but I think the bare black plastic pieces by the rear light looks 'untidy'.
SORRY FOR THE HIJACK ......
New-gen engine in Pre-gen frame. Oil leak under exhaust ports. AFazakerley 2008 - 2012 Ninja 250R Tech Talk 11 June 5th, 2016 02:03 PM
Pre-gen (2007 and older) and "new pre-gen" (2008-2012) frames kjohng General Motorcycling Discussion 5 February 27th, 2013 10:03 AM
Pre-Gen Parts, clean out my garage! A7xschecter6661 Motorcycle-related 9 July 12th, 2012 09:12 PM
Does anyone have pics of a Pre-Gen without the front fender? Zim Pictures 8 March 4th, 2011 11:44 AM
