Old September 30th, 2011, 05:05 PM   #1
paterick4o8
paterick4o8's Avatar
Motorcycle(s): '08 blue 250R [sold]. '09 lime ZX-6R [stolen :( ]. '06 blue 636.
Rattling noise from the engine..
I have a slight guess as to what it might be, but any ideas? Kinda worried here..
paterick4o8 is offline   Reply With Quote
Old October 1st, 2011, 06:33 AM   #2
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Has the sound just started?
It almost sounds like a normal Kawi engine to me. Let me listen again..
What's the prognosis? How many miles? Have you done your valve adjustment?
Is it a loose header? (exh leak?)
http://www.ninjette.org/forums/signaturepics/sigpic2121_4.gif <Yeah, it's a 250.
LMFAO!
Weaksauce
ninja250 is offline   Reply With Quote
Old October 1st, 2011, 12:40 PM   #3
paterick4o8
it seems to me like the sound just started, I don't recall it being like that but then again the exhaust kind of masks the rattling sound and I put on my ear plugs pretty shortly after I start her up.
valves were adjusted at 16K in August 2010; I'm now at 20.5K
Havent checked to see if it's the header but I'll check later on before I ride again.
Old October 2nd, 2011, 02:55 PM   #4
Kanestar
Kanestar's Avatar
Motorcycle(s): 2010 Ninja 250
i had the same prob, took it to the dealer and they are toying with my ass. They said they are sending a oil sample to kawa then get permission to get it broken down. I've been w/o my baby for almost a month =(. I think it has something to do with the valves
Kanestar is offline   Reply With Quote
Old October 2nd, 2011, 06:02 PM   #5
leed
leed's Avatar
Motorcycle(s): Time will tell
If not an exhaust leak.. Bad rod journal bearing? Maybe piston slap from a jammed valve?
Old October 4th, 2011, 01:10 PM   #6
Mine's making the same noise. Oil sample? My oil always smells like gas too. It's not nearly as bad after I ride a while.
Old October 6th, 2011, 04:49 PM   #7
Kanestar
Kanestar's Avatar
Mech said that my crank rod or something with my valve went nuts. My bike sounded just like the one in the video but a little louder. Noise was coming from the bottom right. I only have 1200 miles on it and its a 2010.
It all happened when I was on the freeway, usually i go maybe 45-50mph but this day i wanted to take it on the freeway so i did 90ish and then when i went off my exit it just started making that loud ass noise. I noticed a big drop in power and both of my lights came on. I pulled over and called progressive and got it towed. Now i have to wait for them to rebuild my engine while kawasaki analyzes my oil to find out what happened.
Old October 6th, 2011, 04:54 PM   #8
paterick4o8
yikes!
sorry to hear.
I hope mine's not that serious
Old October 7th, 2011, 09:04 AM   #9
lunerkid
Motorcycle(s): 08 Ninja 250
Hey Paterick,
I get the same exact sound. At first I thought it was my valves, but when I hit my 15k and did my values it was the same thing.
I was always under the impression that that sound was the kawi tick.
You can listen to my bike to next time we meet haha.
lunerkid is offline   Reply With Quote
Old October 7th, 2011, 12:20 PM   #10
paterick4o8
iiiiinteresting. yeah Ed we need to meet up
anyhoot, just a small update: I havent noticed any change in performance from my bike. after the engine's properly warmed up I can still ride it hard and go WOT without feeling like it's lost something
Old October 7th, 2011, 12:36 PM   #11
lunerkid
Yup no loss in power. Just that tapping noise.
Old October 7th, 2011, 10:39 PM   #12
Here's mine, cold and then slightly warm:
Old October 7th, 2011, 10:49 PM   #13
CmichRider
CmichRider's Avatar
Motorcycle(s): 2000 Ninja 250
So, is this normal or no? My bike makes the same ticking noise and it's a 2000. I haven't noticed a drop in power, tho I don't ride the bike up to 90 mph ever.
CmichRider is offline   Reply With Quote
Old October 8th, 2011, 01:33 PM   #14
Kanestar
Kanestar's Avatar
czroe's bike sounds normal. Mine sounded like someone put nails in a coffee can and shook it like like crazy
Old February 9th, 2021, 11:35 AM   #15
JuJu
Motorcycle(s): 1998 Kawasaki ninja 250r
Did you ever figure this out mine makes the same noise. Sometimes at idle it stops but then comes right back. It reminds me of a vacuum that has somthing stuck in it, like somthing is jumping around in there and every so often it gets caught on somthing then the air grabs it again and starts tossing it around again. I thought at first it was loose plastics somewhere cuz that’s what it sounds like the most to me it sounds like plastic flapping around but haven’t found that to be true. Please let me know if you have figured this out or if and when you do. Thanks
JuJu is offline   Reply With Quote
Old February 9th, 2021, 08:16 PM   #16
GAU-8
Socially inept. Yet FUN!
GAU-8's Avatar
Motorcycle(s): Current machines- 1992 SECA II 600, 2006 Ninja 250, 2008 Ninja 250
( edit: response is for JUJU)
I'm wondering if it could be your coolant pumps impeller? Maybe there are a few spots of air in system, and/or maybe low on coolant?
Mine had a similar "random" plastic-ish spinning/ticking sound. I found out my coolant resevior had developed a tiny crack, along the mold line seam, near the bottom. This let my coolant get really low. After replacing the resevior, and doing a complete flush, and fill of coolant, haven't had the issue/noise again. Just a thought. These bikes are getting older, and stock plastics are bound to fail.
My leak was really hard to find. ( but the resevior kept getting wet at the bottom. Anyways, i'd say double check, or completely re-do your coolant, if low, or bike is "new" to you.
Last futzed with by GAU-8; February 9th, 2021 at 09:46 PM.
GAU-8 is offline   Reply With Quote
Rattling Noise hieuster 2008 - 2012 Ninja 250R Tech Talk 12 July 3rd, 2013 11:13 PM
Sharp Rattling(sorta) Noise Problem Postiez 2008 - 2012 Ninja 250R Tech Talk 6 August 23rd, 2009 08:00 PM
Rattling Noise from 8-9k RPM 250fan 2008 - 2012 Ninja 250R Tech Talk 20 August 1st, 2009 10:52 PM
knocking or rattling noise tinng321 2008 - 2012 Ninja 250R Tech Talk 12 May 31st, 2009 09:51 AM
So I'm hearing a rattling noise from my engine ARc 1986 - 2007 Ninja 250R Tech Talk 25 May 11th, 2009 06:06 PM
