Old October 3rd, 2011, 01:47 PM   #1
aftermarketcycles
Aftermarket Cycles
aftermarketcycles's Avatar
Motorcycle(s): 2 Ninja 250's
WMRRA Aftermarket Cycles Ninja 250 Cup
I wanted to share some images I took of Tim O'Mahony and Sean Galt of WMRRA in Seattle, WA
These guys had a great season with WMRRA and I would like to thank them for all of their support and friendship.
They have spent a lot of time and money to make their bikes look great and run great!
Enjoy
aftermarketcycles is offline   Reply With Quote
Old October 3rd, 2011, 05:54 PM   #2
Old October 4th, 2011, 08:04 AM   #3
SPG
Motorcycle(s): 250 Ninjette
And a big thanks to Mark and Aftermarket Cycles for supporting our racing efforts. He always went the extra mile to find parts for us and get everything in time for the next event.
Tim O' got 2nd in both of our 250 classes. I was 8th and 10th, and Adam G. (Order) pulled off a 6th and 5th. Clearly, I still have some work to do.
Can't wait for next season.
-Sean
SPG is offline   Reply With Quote
Old October 4th, 2011, 08:44 AM   #4
dino74
dino74's Avatar
Curious to hear about what upgrades has been done to the bikes?
CVMA #55
Old October 4th, 2011, 11:48 AM   #5
SPG
Well lets see...
My bike (blue):
Woodcraft clip-ons and rearsets
Leo Vince exhaust
Ivan's jet kit
Andriani Cartridges
RaceTech Rear shock with longer clevis
Stainless lines and Vesrah pads
Ignition key delete
415 chain and sprockets, (18/55)
Pirelli Supercorsa tires, 110/70 SC1 front, 120/70 SC2 rear
Scott's steering damper
ASV levers
Pregen CDI
Tim's (green) is pretty similar except a lot cleaner and:
gsxr cartridges adapted by KFG (GP) suspension
Penske Rear shock
Stock CDI
Dunlop GP-211A 120/70 front and rear
EBC pads
Both bikes were pretty well set up. The only major changes throughout the season were changing to the smaller rear tires (recent) and increasing the ride height in the rear (not as recent). The smaller rear tires also caused a change from a 57 rear sprocket (for Tim's Dunlop 150/60 and my Bridgestone 140/70) to the 55 tooth. The smaller rear tires grip just as well, handle better, don't have wasted chicken strips like the 150s do, and weigh 3 pounds lighter. They do not seem to last quite as long however since there is less rubber to wear away. (and they are pretty soft.)
-Sean
Old October 4th, 2011, 12:29 PM   #6
dino74
dino74's Avatar
Originally Posted by SPG View Post
Well lets see...
120/70 SC2 rear
-Sean
I'm I missing something or are you running front tires on the rears?
CVMA #55
Old October 4th, 2011, 12:59 PM   #7
SPG
You are correct. In the Pirellis they make a 110 and a 120 front, so I use the 110 in the front and the 120 in the rear. Dunlop doesn't make a 110 race tire, so it's 120s at both ends.
The combination of elevated ride height in the back and the narrow tire makes for insanely crisp handling without getting twitchy. The ability to adjust your line at will, and keep the front on it's line whatever you do with the throttle is pretty cool. The first session I did on the new tires, I almost ran off the inside of the track in the first 3 corners because I was used to the bike running wide on the exit. Now it finishes the corner beautifully.
I can only think of one guy in Seattle who is still running a 140 on the back, and he just bought the bike and hasn't changed the tires out. Everyone else on the newgens is running 120s
-Sean
Old October 4th, 2011, 01:06 PM   #8
dino74
dino74's Avatar
Good to know. I was looking to pick up a set of rain tires but the 125gp rears are expensive. Do you guys up in Seattle also run a front 120 rain tire in the rear?
CVMA #55
Old October 4th, 2011, 01:12 PM   #9
SPG
There is one guy who did on a pre-gen with 17's. Not sure how well it worked out for him though.
The rest of us just run the 125GP rains which are 95 F / 115 R if memory serves. A brand new pair of Dunlops is $250 mounted and balanced which is a lot cheaper than new bodywork.
-Sean
Old October 4th, 2011, 05:26 PM   #10
Rexbo
CVMA / AFM / M1GP #250
Rexbo's Avatar
Motorcycle(s): 2009 Ninja 250r, 2011 Zero S, 2009 KLR 650
Damn, i am going to try that next! I love the pirellis and want to run them front and rear, but never throught to run a 120. If it works for you, I'll give it a shot
Rexbo is offline   Reply With Quote
Old October 4th, 2011, 06:06 PM   #11
SPG
Most of the folks running them are using the SC2 in the rear. Grip is fantastic, but I think they probably last 3-4 race weekends before they are done. Mine has noticeable wear from 1 trackday and a race day.
I hear that Pirelli no longer makes an SC3 in this tire but they do have an SC4. I might see what I can find (in compound) that bridges the gap between my BT003's which could easily last all season, and the SC2 pencil eraser compound.
I'd still probably keep the SC2 for racing, but a slightly harder tire on a spare wheel would probably be great for trackdays. The fronts seem to wear pretty well in the SC1, so no worries there.
As far as working, it drops 3 pounds of rotating mass and the bike is super nimble. For me, the radius of the tire was 14mm lower than my Bridgestone, so I added 6mm of height to the rear shock to make up for it. This kept my front end geometry the same as I liked, and even gave me a little more swingarm angle. An overall win-win.
-Sean
Old October 4th, 2011, 06:14 PM   #12
Rexbo
Rexbo's Avatar
Heck yeah thats a win-win, except I'd need a longer rear shock to pull this off. Seems you can still get an SC3 in a 120 from http://www.coreytaylorracing.com/pro...upercorsa.html
Old October 4th, 2011, 07:23 PM   #13
SPG
You'd probably like a longer shock anyway. My favorite quote from another rider is:
"We just keep adding rear height, and it just keeps getting better."
That said, I still have some room to grow on my rear shock, but I just can't imagine it being any better so I don't want to mess with a good thing.
Thanks for the tire link. I'll see if the local guy can get one first, if not, I now have options.
-Sean
WMRRA Round 2 Races + Full length video of 'How to highside a Ninja 250' Order Ninjettes At Speed 7 May 14th, 2012 09:16 PM
2012 wmrra round 2 - ninja 250 cup - april 29, 2012 largeone Videos 4 May 14th, 2012 12:13 PM
2011 WMRRA ROUND 8 - NINJA 250 CUP - Finished 4th Order Videos 8 March 2nd, 2012 10:01 AM
WMMRA - Aftermarket Cycles Ninja 250 Cup - Pacific Raceways Kent, WA aftermarketcycles Ninjettes At Speed 12 May 3rd, 2011 05:50 AM
