Old October 18th, 2011, 06:37 AM   #1
eddiekay
eddiekay's Avatar
Motorcycle(s): 300, WeeStrom
chain slack
Near 15k on my original chain. Highway miles mainly.
I've always pulled the chain every few weeks.
Strange...hasnt needed it in past 5 or 6 weeks ( +/- 2000 miles).
What do you think ? ready to break ?
Old October 18th, 2011, 07:27 AM   #2
SteveL
old git
SteveL's Avatar
Motorcycle(s): BMW K1300S
A well looked after chain should do 25K miles look at the teeth on the sprocket and the condition of the chain i.e. no rust no O rings sticking out, and it’s still good.
Steve
Some mistakes are too much fun to make only once.
SteveL is offline   Reply With Quote
Old October 18th, 2011, 09:31 AM   #3
Scattcatt
Scattcatt's Avatar
Motorcycle(s): 2008 Kawasaki Ninja 250R, 2003 Honda CBR600RR
Measure the chain stretch, I believe 12.71 inches over 20 links is the service limit. Let me double check...
Okay the service limit is 12.72 inches (323mm) over 20 links with 20 pounds (10kg, 98 N) hanging on the bottom of the chain to keep it tense.
Measure it in multiple spots though, in case the chain isn't stretching uniformly.
Sources: My service manual
ATGATT
Scattcatt is offline   Reply With Quote
Old October 18th, 2011, 09:42 AM   #4
eddiekay
eddiekay's Avatar
Thanks Zach,,
Old October 18th, 2011, 03:20 PM   #5
eddiekay
eddiekay's Avatar
A close look in daylight shows a worn sprocket.
Really happened fast....adjusted the chain maybe a month ago and i must've pulled it too tight. I'm pissed.
Lesson: dont pull chains at night by a flashlight becuz youre too lazy to get up 10 minutes early the next day before you ride.
Old October 18th, 2011, 05:01 PM   #6
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Does this mean you need a new sprocket?
Old October 18th, 2011, 05:21 PM   #7
Scattcatt
Scattcatt's Avatar
Total bummer... Check the chain wear while you were at it? I'd be kind of iffy on keeping the chain regardless whether or not it was still within limits if that chain and sprocket were in the same set, might be better off getting a new set entirely, RK racing chains and Vortex sprockets would be my vote!
ATGATT
Old October 18th, 2011, 05:25 PM   #8
yes. that's exactly what it means. When it's time to replace the chain or sprockets, it's time to replace both, or else the one that didn't get replaced will just shred the brand new part relatively quickly
Old October 18th, 2011, 05:40 PM   #9
eddiekay
eddiekay's Avatar
Yeah...new sprocket....hoping the Kawa chain was tougher than the Bike Bandit sprocket though. Once I make some room in my porch I'll bring it in and look at the chain real careful, I'm les concerned with the quality of the parts than I am with not paying attention to what I did in the first place and NOT realizing something was wrong
Anyway...I could remount the stock sprock till spring, WTF, yeah, that's what I'll prob do
Recommended Chain Slack burnrich 1986 - 2007 Ninja 250R Tech Talk 18 January 20th, 2014 02:22 PM
Chain Slack jeffb502 2008 - 2012 Ninja 250R Tech Talk 11 December 3rd, 2013 10:02 AM
Chain Slack for two up riding? Buffalony 2008 - 2012 Ninja 250R Tech Talk 1 June 4th, 2011 12:13 PM
Chain Slack Tool? ScorpionNinja 2008 - 2012 Ninja 250R Tech Talk 11 October 24th, 2010 11:53 PM
Chain Slack? Xuracing 2008 - 2012 Ninja 250R Tech Talk 2 June 9th, 2009 09:21 AM
