Old October 21st, 2011, 09:35 AM   #1
eddiekay
eddiekay's Avatar
Motorcycle(s): 300, WeeStrom
spark plug removal
Any trick to getting the owners tool to work ?
drops down nice into the hole but spins freely, cant get it to grab anyrthing ?
Old October 21st, 2011, 10:21 AM   #2
dubojr1
dubojr1's Avatar
No trick... should work great...
Try pushing the tool down a bit as you slowly turn it. If you don't have any luck then try to use a mirror and a flash light to look down there to see if anything appears abnormal.
Old October 21st, 2011, 10:48 AM   #3
eddiekay
eddiekay's Avatar
PUSH...and turn ...yep, came right out.
First time i tried this....tank on. I can see how tank off would've made it work immediately.
Thanks jason
Old October 21st, 2011, 10:56 AM   #4
dubojr1
dubojr1's Avatar
Glad it worked out for you!
BTW... Be sure to use NGK's over any other brand if your replacing them.
Spark plug removal tool or tool kit landon1 Items Wanted 11 April 1st, 2015 07:03 PM
Replacement Spark Plug Removal Tool Roark 1986 - 2007 Ninja 250R Tech Talk 8 January 27th, 2015 04:54 PM
spark plug tool rideclassiv 1986 - 2007 Ninja 250R Tech Talk 11 March 19th, 2012 10:49 AM
spark plug cleaning before removal wkiltz 1986 - 2007 Ninja 250R Tech Talk 5 July 10th, 2011 06:15 PM
Quick question, spark plug removal Ragnar1x 1986 - 2007 Ninja 250R Tech Talk 4 April 21st, 2011 08:11 PM
