Old November 5th, 2011, 03:46 PM   #1
deaddemon
Motorcycle(s): Kawasaki Ninja 250r
Rear brake fluid leak (container leak?), any advice appreciated.
I am a new owner of a 2009 ninja 250r, recently replaced rear brake pads and had brakes flushed and bled at a dealer, didn't buy the bike at a dealer just did some service.
Soon after getting new brake fluid I noticed it started dripping on my garage floor, and even more after a ride. First I thought maybe my brake line is in bad condition but it does not appear to be so, then I thought they just overfilled the container so when it is on a stand the excess fluid spill out. Now it has been about a week and I still get few drops on the floor and I don't know what to think anymore.
If any1 can recommend a solution I would be very grateful. Here is a couple pictures of a container and you kinda can see it being very oily and even a drop forming, a little bit hard to get under there with a camera.
deaddemon is offline   Reply With Quote
Old November 5th, 2011, 03:53 PM   #2
pop0tart
Motorcycle(s): stolen :(
Brake fluid is corrosive, so try and get this one taken care of. I couldn't see the drip...
Anyway, it could be as simple as a cross threaded reservior cap to the clamp at the bottom to one of the banjo bolts, and that's if the lines are in good shape.
The rear brake is really easy to drain, fix, refill and bleed.
http://faq.ninja250.org/wiki/How_do_...brake_fluid%3F
If it is the lower line, I am sure you can get one cheaply off of a forum member who has upgraded to ss lines.
Last futzed with by pop0tart; November 5th, 2011 at 03:55 PM. Reason: **Welcome to the forum!**
pop0tart is offline   Reply With Quote
Old November 6th, 2011, 11:06 AM   #3
take the reservoir off, cap the tube with fluid in it.
Old November 6th, 2011, 11:29 AM   #4
pop0tart
+ 1
another outstanding contribution.
get help.
Old November 6th, 2011, 01:27 PM   #5
headshrink
headshrink's Avatar
It isn't really an essential part of the bike, so I wouldn't worry about it. JUST KIDDING!
I pretty much agree with everything already said.... If the cause isn't obvious, I would first clean it up, and re-seat the diaphragm and cap. If it isn't too much bother, or if it intimidates you, you could always go back to the dealer.... just don't let them charge you for fixing their mistake. I wonder if it could also be as simple as some spilled fluid when they filled it (not likely, but possible).
Old November 6th, 2011, 01:52 PM   #6
deaddemon
thanks guys for answers, I will definitely check out how the cap is sitting on there and if it still continues will go check out what the repair shop has to say
Fluid Leak After Drop tony7kp 2008 - 2012 Ninja 250R Tech Talk 7 December 31st, 2013 01:00 PM
Please tell me this isn't a brake fluid leak anacron 2013 - 2017 Ninja 300 Tech Talk 22 July 29th, 2013 02:50 PM
Is this a leak? Anyhow, I want it gone the big mike 2008 - 2012 Ninja 250R Tech Talk 19 August 13th, 2012 08:23 AM
Any advice on mods appreciated rdano1197 2008 - 2012 Ninja 250R Tech Talk 6 May 5th, 2012 07:03 PM
Oil Leak, I think I found it but just needing some advice jaustin77 1986 - 2007 Ninja 250R Tech Talk 2 May 11th, 2011 12:56 PM
