Old November 25th, 2011, 08:14 PM   #1
samw
Motorcycle(s): 2005 HON CBR1000RR Repsol, 2012 KAW Ninja 250R
Aftermarket engine plugs?
Does anyone know where I can get some aftermarket engine plugs that will be easier to drill for safety wire? The plugs I'm referring to are the ones that look like you could turn with a large washer or coin. There are 2 such plugs on the alternator cover. Yosh makes some plugs, but they don't specifically mention ones for the Ninja 250.
samw is offline   Reply With Quote
Old November 25th, 2011, 11:06 PM   #2
smokinsingle
L8APEX
smokinsingle's Avatar
Motorcycle(s): 07 KTM 950SMR, 06 KTM 450SMR, 99 KTM 300MXC, 00 Derbi GPR 50, 09 Ninja 250 racebike, race with www.cra-mn.org!
I tried cross checking the ninja plug part numbers to see where else they may have been used by Kawasaki and came up with only the EX500 for which there are no fancy plugs. But the oil fill cap on the 250 is also used on the KLX 110 so there are plenty of blingy caps out for those.
www.joemillersmoderngarage.com www.starr-cycle.com
***The most important concept of science isn't memorizing facts, it's observation of phenomena.***
smokinsingle is offline   Reply With Quote
Old November 26th, 2011, 01:10 AM   #3
randy328
CMRA Mini Endurance #6
randy328's Avatar
Motorcycle(s): CBR954, CBR600RR, EX250
CMRA lets us silicone those plugs, not wired.
randy328 is offline   Reply With Quote
Old November 26th, 2011, 07:26 AM   #4
samw
Originally Posted by smokinsingle View Post
I tried cross checking the ninja plug part numbers to see where else they may have been used by Kawasaki...
Good idea, I'll check the Kawi dirt bikes. My Honda CBR250R shares the same plugs as the CRF250R.
UPDATE: I came up empty handed
Last futzed with by samw; November 28th, 2011 at 09:34 PM.
Old December 25th, 2011, 07:42 PM   #5
jasle
Motorcycle(s): 09Ninja250, Ducati Monster 800ie, Harley FXSTS,Rebel 250,CR144,KX85,RM85L
you can weld a nut to them...then safety wire to the nut. gives a nice hole for a loop.
jasle is offline   Reply With Quote
Old December 27th, 2011, 07:49 AM   #6
smokinsingle
L8APEX
I'd like to see someone weld a nut to plastic
Old December 27th, 2011, 09:10 PM   #7
jasle
actually we weld plastic all the time. you use hot air to melt the rod when welding instead of metal rod. very similar process to regular welding...
http://en.wikipedia.org/wiki/Plastic_welding
Old December 27th, 2011, 09:18 PM   #8
smokinsingle
L8APEX
so you must be talking about welding a plastic nut to it? JB sounds way eaiser.
[RoadRUNNER] - MotoMojo Spark Plugs ? What They Say About Your Engine Ninjette Newsbot Motorcycling News 0 October 15th, 2014 03:01 AM
spark plugs juanpak87 1986 - 2007 Ninja 250R Tech Talk 12 October 3rd, 2013 09:44 AM
Aftermarket slipon with aftermarket header Jojah17 2008 - 2012 Ninja 250R Tech Talk 10 July 20th, 2011 07:58 PM
spark plugs postie1686 2008 - 2012 Ninja 250R Tech Talk 7 June 7th, 2011 04:52 AM
My plugs headshrink 2008 - 2012 Ninja 250R Tech Talk 1 March 24th, 2010 02:07 AM
