December 8th, 2011, 11:39 PM | #1 |
Lost float springs
Hi everybody,
I've been cleaning my carbies and have somehow lost both the little springs that the float needle inserts into. Yes I am an idiot and should have been more organised. The parts list doesn't include them and I can't find a mention of them anywhere. Does anyone know where I can get a hold of some of them or the spec of the springs so I can find a local replacement. Any help really appreciated. I need to get my ride back. |
December 9th, 2011, 01:12 AM | #2 |
92081-1891. Any online parts store should have it on the "carburetor parts" diagram.
http://www.bikebandit.com/houseofmot...8858#sch638148 You can also get a full rebuild kit that would come with them.
Ç¥ñ頻| ßÿ Ñâ7µ®é. Äñt¡~§º¢Ïä| ßý Çhøî©è. |
December 9th, 2011, 01:19 AM | #3 |
Milkshake Drinker
Join Date: Aug 2011 Motorcycle(s): 2007 Orange DRZ400-S, 2005 Ninja 250 & Custom Thundercunt Dirt Chopper Posts: A lot.
http://www.ronayers.com/fiche is where I always go to look at part diagrams.
Here the carb parts list: http://www.ronayers.com/Fiche/TypeID...rburetor_Parts I don't know what you mean by "float needle" though. There are needles that go into the jets to meter fuel to the engine, but there are also floats in the float bowls, used to meter fuel from the tank to the carb bowls. EDIT: I just noticed you have a GPX. I don't know anything about that bike or what carbs it uses, sorry.
"What a sweetheart."- ninja_sleeper to me |
December 9th, 2011, 01:42 AM | #4 | |
December 9th, 2011, 04:09 AM | #5 |
Thanks for the replies so far.
Sorry for the bad explanation. I should clarify a little. I'm in Australia so a GPX250r is the same bike as an 86 - 07 Ninja 250r. The springs I'm talking about fit onto part 16030 on this list: http://www.bikebandit.com/houseofmot...8858#sch638148 So in summary; the plastic floats in the carb bowls are attached via a small metal tab to the float valve Pt 16030 (I called it a needle; sorry). The float valves sit in little springs. I have lost these springs. Oh yeah; and I have searched high and low for the little f*****s. They be gone. Possibly down a sink. Yes! I know I'm an impetuous idiot. If I had lost one of them I would try to find a match. I think I might have to keep my eye out for someone with a wrecker/spares bike. Thanks again all. |
December 9th, 2011, 09:04 AM | #6 | |
IC2(SW)
December 9th, 2011, 09:32 AM | #7 |
no such thing as ninjette
Join Date: May 2011 Motorcycle(s): (2) 1987 EX250E2, 1989 EL250B3, 1991 EL250E1, (3) 2005 EX250F19, 2007 EX250F7F, soon to add more.. Posts: 26
Yes, GPX250 is F model. 1988-2007 F2-F7F unless in japan that got it starting 1987 EX250-F1.
It is a float valve that is also called float needle. 16030-1007 VALVE-FLOAT http://www.murphskits.com/catalog/pr...roducts_id=328 Those valves do not sit into springs. The only part it has is the clip (16044-007 also known as CLIP,FLOAT VALVE) that is the wire attached to connect it to the float. The end of the float valve has an internal spring under that round metal end. You broke it apart? The other end, the rubber tip, seats into the valve seat fitting when the level of fuel rises to set level where it shuts off flow. Gravity keeps the float valve open when it is low or empty not a spring. |
December 9th, 2011, 04:36 PM | #8 | |
I got confused with the mixture needle springs or something. I've never done anything mechanically previously; so that's my excuse. As you were everybody. Thanks for the help. |
December 9th, 2011, 11:12 PM | #9 |
Join Date: Nov 2011 Motorcycle(s): 2000 Ninja 250 Posts: 20
You have no prior mechanical knowledge and your opening up your carbs ? You are a brave man my friend.
December 9th, 2011, 11:21 PM | #10 |
Ha. Yeah.
I have wanted to do some tinkering with cars for years, but it never happened. Bikes are way more accessible and this ninja was relatively cheap with no service history, so I just went for it. Although big thanks to the internet without whom it probably would not have happened. Especially the faq.ninja site with all the pics and tutorials. There are some tricky things to get your head and fingers around, but it's really not all that difficult. And if I ever get really stuck I'll just throw all the bits at a mechanic and say "can you make it better please" |
December 11th, 2011, 07:48 AM | #11 |
Fighterer in Training
Join Date: Jul 2011 Motorcycle(s): 2001 Ninja 250R Posts: 316
Yep. I never tinkered much before either. Since I never really wanted to put my only mode of transportation out of commission to satisfy my curiosity, I left my cars alone. But once I started looking at getting a bike, and saw the amount of info on the 250, I figured I would give it a try. After riding for the second half of the summer and doing small repair and maintenance jobs, now that the winter is here, I've done a complete tear-down of her. Plan to do some modifications and maintenance, re-route the wiring, service the brakes and forks, re-work the air intakes, and a few more little things. It's a great feeling to be able to repair and modify things, and I enjoy spending the time working and problem solving. The bonus is the economic side of it. I only have to pay for parts, and not the crazy labor rates. I hope to do a little more research and try my own valve adjustment, too. I definitely find it to be an extremely rewarding hobby, and enjoy all the learning in the process.
new springs, emulators, springs sound noisy? | subxero | 2008 - 2012 Ninja 250R Tech Talk | 6 | April 19th, 2014 04:14 AM |
Carb float levels... | corksil | 2008 - 2012 Ninja 250R Tech Talk | 9 | January 29th, 2014 05:30 PM |
[topix.net] - Joe Soucheray: We lost more than spelling when we lost the classifieds | Ninjette Newsbot | Motorcycling News | 0 | June 10th, 2012 12:30 AM |
Carb Float Problem | Trainsk8 | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 4th, 2012 12:31 PM |
Float | Zaydoc | 1986 - 2007 Ninja 250R Tech Talk | 2 | March 15th, 2012 05:44 AM |
