Old December 26th, 2011, 04:27 PM   #1
sjc88
Motorcycle(s): 08 Ninja 250
Oil Leak Help
Hi, unfortunately I had my first spill today and now I have an oil leak on the engine case. What can I do to fix it? Do I need a new cap? Help would be most appreciated. Thank you
sjc88 is offline   Reply With Quote
Old December 26th, 2011, 05:46 PM   #2
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
There's not a lot of oil in that part of the engine, so it shouldn't be leaking much. Is it just a film of oil? You can remove that cap and replace the O-ring underneath. It's possible to replace the entire cover but it may be pricey to find a replacement. Do you have any better closeup pictures of the cap itself?
Old December 26th, 2011, 06:00 PM   #3
sjc88
yeah the leak looks to be about what you described. Here is a close up picture I dunno if you can see it clearly.
Old December 26th, 2011, 08:35 PM   #4
FrugalNinja250
It looks like you broke the cap and tore the O-ring. Pull the cap and see if the mating surface on the cover is still intact. If so, a new cap and O-ring should fix you right up. If the O-ring contact area is damaged then yeah, you'll need a new cover, or you may be able to repair it if you've got good maker skills.
Old December 26th, 2011, 09:04 PM   #5
sjc88
ahh thanks, any tips on removing the thing above the cap?
Old December 26th, 2011, 10:22 PM   #6
Skippii
Milkshake Drinker
Skippii's Avatar
What is that thing above the cap? Might just be because I'm on my ancient phone, but I can't figure out what the heck that thing is.
Posted via Mobile Device
Old December 27th, 2011, 08:24 AM   #7
FrugalNinja250
It's the bracket for the evap canister. He's got a California bike.
Old December 29th, 2011, 04:13 PM   #8
Dragone
Dragone's Avatar
Motorcycle(s): '86 VFR 750, '90 ZX7, '92 KZ1000, '05 ninja 500, '05 6RR, '06 10R, '07 ninja 250
+1 to the bracket. The parts are inexpensive as well to replace. http://www.chaplinkawasaki.com/fiche...007&fveh=21725
Dragone is offline   Reply With Quote
Oil leak.... skilletmo 2008 - 2012 Ninja 250R Tech Talk 13 October 24th, 2014 09:31 PM
Oil leak Xaero 1986 - 2007 Ninja 250R Tech Talk 11 November 16th, 2013 06:58 PM
Oil Leak? Fakker 1986 - 2007 Ninja 250R Tech Talk 5 September 6th, 2013 06:38 AM
Oil Leak thisisbenji 2008 - 2012 Ninja 250R Tech Talk 10 December 12th, 2012 06:59 PM
possible oil leak? Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 17 August 21st, 2012 01:35 PM
