Old January 8th, 2012, 04:45 PM   #1
paopufruit
Motorcycle(s): 09 ninja 250r
gauge cluster
well i had my bike sitting for about 2 weeks a little while ago and i just got to hop back on, and on the way home form work i noticed the light for the cluster was out. is there an easy way i can fix this without having to go to the shop or must i take it in?
paopufruit is offline   Reply With Quote
Old January 8th, 2012, 05:10 PM   #2
jdoucet93
jdoucet93's Avatar
Motorcycle(s): 2009 R6
There are a few lights that illuminate the cluster. Are they all out? Or is it just one area of the cluster?
jdoucet93 is offline   Reply With Quote
Old January 8th, 2012, 05:12 PM   #3
paopufruit
sorry, guess i should have clarified that xD. only the one that lights my odometer and tach and that stuff
Old January 8th, 2012, 05:30 PM   #4
jdoucet93
jdoucet93's Avatar
To get to the lights, you have to get behind the cluster. To get behind the cluster, you have to take the upper faring off. Then you will be able to see all of the wires and plugs going into the back of the dash. Pull each one of the plugs out of the back of the cluster until you identify the burnt bulb(s). Not sure exactly which ones are for the illumination so it may take a small bit of trial and error.
Old January 8th, 2012, 05:33 PM   #5
paopufruit
thanks for the info. i may just have to take it in as list time i tried to strip the bike down i ate a few screws . i will give it a try though and if im gunna screw something up ill stop :P
Help me find a gauge cluster InvisiBill General Motorcycling Discussion 13 February 9th, 2015 01:39 PM
Necessity of Gauge Cluster? RuthlessZ 1986 - 2007 Ninja 250R Tech Talk 33 December 10th, 2014 05:02 AM
08 Gauge cluster wanted devildogae Items Wanted 2 November 7th, 2012 12:43 AM
Serious delay in gauge cluster dtyndall 2008 - 2012 Ninja 250R Tech Talk 3 June 21st, 2010 06:14 PM
Loose Gauge Cluster? jonb08 1986 - 2007 Ninja 250R Tech Talk 8 April 13th, 2009 10:40 PM
