February 29th, 2012, 05:45 PM | #1 |
Wicked808
Join Date: Dec 2011 Motorcycle(s): 2012 Kawasaki Ninja zx6r, 2012 Kawasaki Ninja 250(Traded in) Posts: 86
New HMF Exhaust slip/on & Carb. question
Installed my new exhaust and there is smoke coming out of it. I believe its a break in thing? Correct me if i wrong! And also, how do you know if your bike is running lean or rich? Thanks in advance.
February 29th, 2012, 05:47 PM | #2 |
that's perfectly normal. It's just a light coating of oil on the inside from manufacturing.
http://www.ninjette.org/wiki/Lean_or_Rich Here's the technique for jetting. with just a slip-on, you should be fine to just shim the needles out a little. Desnorkel while you're at it so you only have to adjust your jetting once. But still get a pair of jets that are 1 step larger than stock, and do some WOT tests to make sure the top end still feels good before you mess with the needles. |
February 29th, 2012, 05:57 PM | #3 | |
Wicked808
February 29th, 2012, 06:25 PM | #4 |
Wicked808
And is there a certain type of washer(zinc,metal) etc. That needs to be used? I know the size needs to be 3 mm.
February 29th, 2012, 07:12 PM | #5 |
just use standard SAE 4 washers (or 3mm ID, and as small OD as you can get) I'm not sure what metal those are specifically.
Just make sure you don't use funny vinyl washers. stick with the standard metal ones |
February 29th, 2012, 08:20 PM | #6 |
Wicked808
Damn man, home depot, lowes, napa, has no 3mm washer! Wtf??? Where can i go? Maui has nothing!
February 29th, 2012, 10:30 PM | #8 |
Wicked808
February 29th, 2012, 10:31 PM | #9 |
SAE #4 are different than 3mm. Very similar size, but different washer.
February 29th, 2012, 10:33 PM | #10 |
Wicked808
February 29th, 2012, 10:36 PM | #11 |
February 29th, 2012, 10:47 PM | #12 |
Dakine...
Join Date: Jun 2011 Motorcycle(s): 2009 Ninja 250R (Sold) | 636 (hopefully soon) Posts: A lot.
Heres the links i was telling you about over the phone jus a lil while ago:
Snorkel delete Kleen air delete |
March 1st, 2012, 02:03 AM | #13 | |
Join Date: Aug 2011 Motorcycle(s): RED 2010 Ninja 250r Posts: 304
HMF Slip-On Exhaust Video - Startup, Revving, & Fly Bys on 2012 Kawasaki Ninja 250R | SON1C | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 29th, 2014 01:14 AM |
2011/ 2012 Ninja + HMF exhaust question | cj_816 | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 23rd, 2012 10:25 AM |
HMF Exhaust Question | ezac32 | 2008 - 2012 Ninja 250R Tech Talk | 1 | November 16th, 2011 09:43 AM |
HMF Slip On Exhaust | adri99an | Videos | 35 | April 20th, 2011 10:52 AM |
