March 8th, 2012, 12:42 PM | #1 |
~08 ninja 250~
Join Date: Feb 2011 Motorcycle(s): 08 ninja 250 Posts: 21
too much oil
so in the fall, a friend did my oil change for me but put a lil too much oil in it.. he said it'd be ok but i wanted it to be the way the book says.. i'm still new and i don't know anything about that sort of thing so i wanted some taken out but i don't have a ratchet and i'm not comfortable doing that sort of thing so i came up with a way to remove some oil and staying clean!!
Last futzed with by miss_connie; March 8th, 2012 at 12:46 PM. Reason: my pic didn't attach |
March 8th, 2012, 12:46 PM | #2 |
A little too much won't hurt much. A lot too much can have serious consequences, primarily blowing seals in a variety of areas in the motor.
Some people have had luck siphoning oil right out of the fill hole, using something like a windex bottle squeeze pump. But at least one story I read had someone lose that tube down into the fill hole, which created a new problem, so be careful. When you measure the oil level, make sure that the bike is on a flat surface, and raised as close to vertical as feasible. If you can't hold it vertical while viewing the sight glass yourself, have a friend do one or the other, to make sure the oil level is near the center of the viewing area.
March 8th, 2012, 12:53 PM | #3 |
~08 ninja 250~
ya, it was past the top of the window, i have to put a piece of wood under the kickstand so it's easier for me to hold it upright, now it's 3/4 in the window instead of past the top.. i work in a lab so i used a butterfly needle (minus the needle) which attaches to the syringe so it wont come off.. threw a straw down there first so the tubing went where i needed it
March 8th, 2012, 06:08 PM | #4 |
Very clever idea, Connie
March 9th, 2012, 01:12 AM | #5 |
Join Date: Aug 2011 Motorcycle(s): RED 2010 Ninja 250r Posts: 304
Lovin it. I'll bookmark this just incase this ever happens to me.
March 9th, 2012, 03:30 AM | #6 |
Make sure you check again after running the engine for a few seconds. Often it will appear overfilled until it gets inside the new oil filter and the visible level drops. The visible level will always drop while the engine is running, so shut it down quickly and check.
March 9th, 2012, 04:36 AM | #7 | |
Join Date: Jan 2012 Motorcycle(s): Green 2012 Ninja 250SE and a Yamaha fino scooter (my wife's really) Posts: 355
Be safe ride smart .....a dumb rider is a dead rider |
March 9th, 2012, 06:47 AM | #8 | |
As for waiting for it to return to the sump, which is what we agree on, that much is obvious and fairly quick when the oil is cold and the engine has only been on a few seconds (not much has worked its way up). Quite literally, the oil level will be visibly moving up and it's pointless to consider a particular moment during a changing indicator to be a "reading." Another point where I disagree with you is letting it sit on the stand. The stand WILL change your oil reading. Try it before and after and you will see. |
March 9th, 2012, 03:43 PM | #10 | ||
You miss read i said nothing about letting it sit on the stand I said let the bike stand (British English )meaning stand still to allow the oil to flow back down. Quote:
read your manual it will tell you the difference in the amount of oil needed with or without a filter change .
March 9th, 2012, 09:51 PM | #11 | |
March 11th, 2012, 11:51 PM | #12 |
~08 ninja 250~
when buddy did it, I read the manual to him, I think it said something like 1.7L? he dumped both in n said itd be fine.. Im thinking hes the type of guy that 1 doesnt like a woman telling him how to do the favour he's doing for her and 2, admitting he did it wrong lol its all good tho, hes still my buddy but he wont be doing the oil changes
As for the turkey baster, it wont fit that far in.. |
March 12th, 2012, 03:47 PM | #13 |
Join Date: Mar 2012 Motorcycle(s): 2012 Ninja 250 Posts: 80
how much qualifies as "too much"?
i did my own oil today and put in around 1.7-1.9L and the viewing glass is completely full when the bike is fully level...should i take some out? |
Is it normal for oil to increase a bit in the crankcase after an oil change? | cadd | 2008 - 2012 Ninja 250R Tech Talk | 10 | May 15th, 2014 08:38 PM |
Synthetic oil at 300 mile oil change? | anacron | 2013 - 2017 Ninja 300 Tech Talk | 14 | July 29th, 2013 04:58 PM |
5qt. G-Oil Synthetic Motor Oil (5w-30) Free After $26 Rebate | setasai | Miscellaneous | 3 | May 25th, 2011 01:59 PM |
[webbikeworld.com] - Substitute Ducati Oil Filters - Changing the Multistrada Oil and | Ninjette Newsbot | Motorcycling News | 0 | October 26th, 2008 05:10 PM |
