Old March 13th, 2012, 12:24 PM   #1
seis gunnar
Motorcycle(s): '09 250R SE Lime Green
Recon Instruments HUD
Recon Instruments, who built a HUD into a ski goggle, is finally looking into making one for MC use. I stumbled across a link to the survey on their Facebook page. It is a typical, information/market research survey, but the more responses they get the better for us.
http://bit.ly/AjA8W5
The link will jump you to a Google doc, with the survey.
Jon
seis gunnar is offline   Reply With Quote
Old March 22nd, 2012, 10:57 AM   #2
Scattcatt
Scattcatt's Avatar
Motorcycle(s): 2008 Kawasaki Ninja 250R, 2003 Honda CBR600RR
I think it would be awesome to have a HUD inside of a helmet, I would totally be in once something like this was available in the market at a reasonable price
ATGATT
Scattcatt is offline   Reply With Quote
Old March 23rd, 2012, 11:15 AM   #3
razorgamez
razorgamez's Avatar
Motorcycle(s): 2008 ninja 250r
One thing I want them to fix is that, their current device generates quite a bit of heat after a while...you don't feel it when you are skiing etc but if you for example go in for a hot coffee or something and leave the goggles on, u can feel the heat.
....(O_O)....(O_o)....(o_O)....(-_-)
razorgamez is offline   Reply With Quote
Old March 23rd, 2012, 11:57 AM   #4
Liist
Liist's Avatar
I would love a speed indicator in my visor so I stop looking down at the instrument cluster to avoid speeding and instead look down the road. This is the future of technology and I would love to be at the cutting edge.
Liist is offline   Reply With Quote
Old March 23rd, 2012, 05:49 PM   #5
razorgamez
razorgamez's Avatar
As far as I can tell from ripping mine apart...no it does not have an internal heater. So its a waste in terms of energy. In terms of integrating it into a motorcycle helmet, they need to make sure the heat dissipates away from the face....it gets really uncomfy.
Originally Posted by trixter View Post
That can be an advantage for skiing or other cold climes. The gopro has an internal heater to keep the battery warm. Cold rechargables lose voltage, ie they will go dead just from the cold. Keeping it warm can keep the battery life longer (it requires some minor math to compare current draw vs current loss due to temperature to see if its useful). This is why your mobile phone should be in an internal jacket pocket instead of a backpack or external pocket in the cold - so the battery lasts longer.
With that said a thermistor could be added to any additional heat source so that it turns off when its warmer (or the heater just gets less power so its not a binary on/off).
Now their thing may not have any additional heater it may just have that much waste energy which means improving efficiency may help with that and then have some thermistor regulated add on heater for the battery life issue.
Instruments Apex Off-Topic 71 February 25th, 2024 10:25 PM
[hell for leather] - The future of motorcycle instruments Ninjette Newsbot Motorcycling News 0 June 3rd, 2013 11:10 PM
Recon Mod Live ($200) - (only used twice) razorgamez Miscellaneous 7 November 1st, 2012 08:28 PM
Missing Bolt near instruments/wind screen hackeron 2008 - 2012 Ninja 250R Tech Talk 3 January 31st, 2012 09:10 AM
musical instruments alex.s Off-Topic 21 July 5th, 2011 11:06 AM
