March 27th, 2012, 10:13 AM | #1 |
Join Date: Mar 2012 Motorcycle(s): 07' Nija 250 Posts: 3
What is the stock exh header made of? Stainless?
I am in rut-
Trying to mod my 07' Ninja 250 here. I am tring to convert over to a +08' SINGLE exh setup. I have a brand new single slip on... (Danmoto) + airbox delete.... I have just discovered that Kawi changed the head casting( stupid!!) at the exh ports.. so an older header wont bolt up. If you eye ball it... it looks the same-- but when you actually get the newer header up to the head, it tells a story. So I am about to fab up and weld a hybrid flange, slipping the old flanges on the newer pipes. I'm wondering about dissimilar metals... Q: ** I know the +08 headers are SS but does anyone know what the older ones are made of ?? I have not been able to find anyone else who has done this swap using Kawi parts. I do know that I will need to fabricate a lower mounting point down at the bottom,. easy. Matt |
March 27th, 2012, 10:55 AM | #2 |
Update,
I found a magnet.. it and it stuck so it's steel. This mod will be interesting when its done. matt |
March 27th, 2012, 11:23 AM | #3 |
Milkshake Drinker
Join Date: Aug 2011 Motorcycle(s): 2007 Orange DRZ400-S, 2005 Ninja 250 & Custom Thundercunt Dirt Chopper Posts: A lot.
With the heat cycles headers go through, it's easy to tell what they are by looking at them. Mild steel is covered in rust, stainless isn't, and titanium turns blue. I know the pregen headers are stainless steel, but I'm not sure what type of steel. Some types of ss will stick to magnets, others won't, while all types of mild and high carbon will stick to magnets. As long as you use a good stainless welding rod or wire you should not have any problems joining them, though. Check with @RacerX if you have questions, as he recently welded up a way to run a pregen exhaust on his newgen bike.
Posted via Mobile Device |
March 27th, 2012, 11:28 AM | #4 |
Join Date: Aug 2011 Motorcycle(s): 2004 Ninja 250R Posts: 46
Pregen headers are double walled mild steel painted. I did a 2-1 header conversion on my bike about a month ago.
March 27th, 2012, 11:32 AM | #5 |
thanks,
my pregen's have blue-ing ..here n there. No way are they Ti. its chromed tho. matt |
March 27th, 2012, 11:32 AM | #6 |
Milkshake Drinker
March 27th, 2012, 01:58 PM | #7 |
Join Date: Dec 2008 Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike Posts: 890
While a magnet test usually will work to determine if it's stainless or not, just be aware that there are alloys of stainless that are still slightly magnetic. Obviously not any helpful information in this case where it's already been determined, but keep it in mind for later.
March 27th, 2012, 02:33 PM | #8 |
You can weld stainless to mild steel using stainless filler material.
Ç¥ñ頻| ßÿ Ñâ7µ®é. Äñt¡~§º¢Ïä| ßý Çhøî©è. |
March 28th, 2012, 09:39 AM | #9 |
Milkshake Drinker
Slightly magnetic?
MANY stainless steels are just as magnetic as mild steel. Do none of you guys cook with stainless knives?
"What a sweetheart."- ninja_sleeper to me |
WTS...Stock '06 header/mufflers & stock pair of red rear pod lens | Ninja Nut | Motorcycle-related | 6 | October 21st, 2012 01:36 PM |
06' stock header/exhausts | Ninja Nut | Motorcycle-related | 2 | April 12th, 2012 05:41 PM |
2008 ninja green seat cowl ,stock muffler and header,and stock sprockets | Darkshadow4ya | Motorcycle-related | 0 | December 3rd, 2010 08:02 PM |
