May 14th, 2013, 12:17 PM | #1 |
Join Date: Mar 2013 Motorcycle(s): 2005 Ninja 250 Posts: 24
Carb help!
Was taking apart the carb and this fell out where does it go in the carb? Also which direction.
Last futzed with by set608; May 14th, 2013 at 11:41 PM. Reason: forgot |
May 14th, 2013, 01:18 PM | #2 |
Name: Not Applicable
Join Date: May 2013 Motorcycle(s): 2007 Blue Ninja 250 Posts: 171
I'm doing my carbs too!
You know the rubber rings on the vacuum side that connect to the plastic par that holds the needle and slides in? Look at the hole it's going into, and the silver thing fits in there! (Underneath the plastic) Let me know, I'm pulling my carbs out again later and I'll take pics if you need |
May 14th, 2013, 07:43 PM | #3 |
Those collars(#160170) go in before you install the main jet holder things that the main jet screws into.
You can see the collars protruding out inside where the needle fits through.
May 14th, 2013, 11:41 PM | #4 |
Ok i got it all back together thanks for the tips. My bike is still idling high at 3500 rpm or it goes below 1000rpm. i got new fuel, ran sea foam, cleaned out air box filter, cleaned out the carbs that were already clean. and have played with the idle screw ( it either idles to fast or to slow when i try to adjust it) its an 07 bike with 12000 miles. maybe a valve adjust next? Maybe new spark plug? HELP
May 15th, 2013, 04:39 AM | #5 | |
Join Date: Aug 2012 Motorcycle(s): Ninja 250 2001 Posts: A lot.
May 15th, 2013, 04:41 AM | #6 |
I'd try turning the screws out at least a half turn though because it sounds like its lean. When you blip the throttle does it hang high then set back down?
May 15th, 2013, 10:52 AM | #7 |
It does hang when i blip the throttle. So its too lean?
May 15th, 2013, 11:26 AM | #8 |
It could be that it is lean. Also make sure you don't have any vacuum leaks.
Did you rejet the carbs? Change out the needles? intake mods? exhaust mods? More info you have the better we can assist you The fuel mixture screws when set at 2.5 turns out will have the needle almost flush with the surface of the carb body. Usually 2.5 turns is a good starting point when tuning. Valve adjustments are done at every ~7500 Miles. You're exhaust valves will always be on the tight end of clearances which will require you to swap in some thinner shims to bring it within specs. There's a ton of info in the wiki about carb adjusting.
May 15th, 2013, 03:16 PM | #9 |
The bike is all stock no mods. when i cleaned the carbs both needles were flush .
FS: Motion Pro Syncpro Carb Tuner (Carb Sync) $60 Shipped | menikmati | Motorcycle-related | 4 | April 8th, 2020 12:39 AM |
Valve adjustment, carb clean, carb sync? | amad1972 | 1986 - 2007 Ninja 250R Tech Talk | 2 | July 29th, 2014 09:42 PM |
NOT what you want in your carb | baz666 | 1986 - 2007 Ninja 250R Tech Talk | 9 | May 27th, 2014 04:56 PM |
Carb help PLEASE | kslane | 1986 - 2007 Ninja 250R Tech Talk | 8 | August 7th, 2013 07:42 AM |
Carb Help | msebastian | 2008 - 2012 Ninja 250R Tech Talk | 20 | February 17th, 2013 01:22 PM |
