Old April 7th, 2014, 06:32 AM   #1
baz666
baz666's Avatar
Motorcycle(s): 2000 EX250 Ninja
Question NOT what you want in your carb
As I'd posted earlier, I was wondering why my 2000 EX250 would not start or run without choke. I figured since the bike sat for a long time before I bought it just after xmas, the carbs needed to be cleaned. So I removed the carbs, took off the tops to check the internals and much to my surprise, here's what I found in the left side carb (as you're seated on the bike). Amazing the bike ran at all.
Now, it might be possible but I can't imagine this damage would happen in regular use of the bike. The diaphram is chewed up along the edge and torn right through in a couple places. Some 'person' did this then put it back in the carb and put the carbs back in the bike. Who would do that?
The previous owner sold it because: "I just couldn't get it to run right."
Ya think?
So I'm doing a full carb rebuild since anyone who would put this diaphram back in a carb in capable of anything. I'll keep you posted on what other infamy I come across.
https://www.flickr.com/photos/69874352@N00/13692906455/
baz666 is offline   Reply With Quote
Old April 7th, 2014, 06:40 AM   #2
Old April 7th, 2014, 07:16 AM   #3
flitecontrol
Motorcycle(s): Rebel 250s, Ninja 250s VN750s (currently nine total)
Some people ought to be bull whipped. They might learn not to do such stupid things, and thereby protect the unsuspecting.
Hopefully, that's all the surprises you'll find!
flitecontrol is offline   Reply With Quote
Old April 7th, 2014, 07:36 AM   #4
kxpower?
kxpower?'s Avatar
Motorcycle(s): Ugly 89 frankenstien special ex250, and the "Zooks" : 1982 GS450 and 1979 GS1000
That sucks dude. That's a $110 part on mrcycles ouch! Hopefully someone around here knows a better source.
Oh god the bikes are multiplying!!!
kxpower? is offline   Reply With Quote
Old April 7th, 2014, 08:10 AM   #5
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
that's what happens when you try and run nitrous
Sucks because that part is so expensive you can probably find full carbs used for cheaper, but then you'll be wondering if they are any good.
Old April 7th, 2014, 01:02 PM   #6
baz666
baz666's Avatar
I saw the diaphragm on ebay for $34. Can the diaphragm be removed from the slider? Doesnt seem possible on this one without tearing diaphragm.
Is there some method that's not apparent?
Old April 7th, 2014, 05:36 PM   #7
j98sprint
Motorcycle(s): '02 Ninja 250, '98 Triumph Sprint 900, '69 H-D Sportster XLCH 900
Not that I'm aware of. The bike will not run right with that torn. You're best bet is to buy a used set of carbs off eBay.
j98sprint
j98sprint is offline   Reply With Quote
Old April 7th, 2014, 06:28 PM   #8
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
So what's the deal with the high-priced diaphragms?
My 39 year old defunct british sports car has a pair of constant velocity (CV) side draft carbs. I can buy a diaphragm for it for less than USD $10. What gives with the Kwak diaphragms? Are they "special", somehow?
Old April 8th, 2014, 01:18 PM   #9
agentbad
agentbad's Avatar
You could just buy one side of the carb and Frankenstein it back together or just buy a whole set so you have extra parts. Ebay is full of used carbs and carb parts.
Saw this:
http://www.ebay.com/itm/KAWASAKI-EX2...126725&vxp=mtr
Old May 27th, 2014, 04:56 PM   #10
I know at least one user put new rubber on his existing slider. Was it you, @cuong-nutz?
Edit: Found the thread.
FS: Motion Pro Syncpro Carb Tuner (Carb Sync) $60 Shipped menikmati Motorcycle-related 4 April 8th, 2020 12:39 AM
Valve adjustment, carb clean, carb sync? amad1972 1986 - 2007 Ninja 250R Tech Talk 2 July 29th, 2014 09:42 PM
Carb help PLEASE kslane 1986 - 2007 Ninja 250R Tech Talk 8 August 7th, 2013 07:42 AM
Carb help! set608 1986 - 2007 Ninja 250R Tech Talk 8 May 15th, 2013 03:16 PM
Carb Help msebastian 2008 - 2012 Ninja 250R Tech Talk 20 February 17th, 2013 01:22 PM
