Old June 17th, 2018, 12:59 AM   #1
$wim
Motorcycle(s): 06 ninja 250r, 82 yamaha xj750
Exclamation New member, new problem
Hey, decided to join the site because I come here for all my 06 250r repairs. So after cleaning the carbs and putting them back on as well as changing spark plugs and throwing in some fuel additive with the unleaded gas I put in, my ninja turns on and shoots up to 10-11 rpm, warmed up with choke fully engaged is still 7-8 rpm... idle adjustment knob is also broken off(was still able to turn the cable but had no effect on idle) I am at a loss and am perfectly capable of repairs but I don’t know what the problem is
File Type: mov 372496B8-231C-405B-A922-2030FF6A6311.MOV (8.13 MB, 10 views)
$wim is offline   Reply With Quote
Old June 17th, 2018, 02:33 AM   #2
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
$wim! Glad you found us...
Raven's Rejuvenation
Old June 17th, 2018, 04:40 AM   #3
kaos
kaos's Avatar
Motorcycle(s): GPX250
G'day mate. I'd be looking for vacuum leaks first and if all's good I'd be pulling the carbs again and checking them over.
Never stick your fingers where you wouldn't stick your pecker...
kaos is offline   Reply With Quote
Old June 17th, 2018, 04:58 AM   #4
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Old June 17th, 2018, 05:57 AM   #5
Hi $wim, it's good to meet you. Being able to set the idle speed will be necessary at some point, even it not now, so you should get that adjustment working and go from there.
I don't know if this applies to the 250 carbs, but with some motorcycles I have, it's possible to get the slides in the wrong way, and in that case the RPM runs away like you're describing. I'm just guessing though. An air leak between a carb and cylinder head, as mentioned above, could also do this. A hung up throttle cable or linkage is another possible cause.
Old June 17th, 2018, 06:04 AM   #6
THusker
Welcome!
THusker is offline   Reply With Quote
Old June 17th, 2018, 06:27 AM   #7
Snake
Snake's Avatar
Hello and welcome!
Old June 17th, 2018, 07:14 AM   #8
Welcome!
Old June 17th, 2018, 08:56 AM   #9
Hi and welcome!
You'll need to fix that idle-adjustment cable. Meanwhile, you can set it by twisting inner wire of cable with needle-nose pliers. Or you can reach in from right side and twist throttle-stop screw end of that inner wire. You'll want to unscrew it or turn anti-clockwise.
Old June 17th, 2018, 07:46 PM   #10
$wim
THanks for all the help, it was actually a simple vacuum leak from the engine to the carbs. I felt so stupid once I found it, was barely tightened
Last futzed with by $wim; June 17th, 2018 at 09:31 PM.
Old June 17th, 2018, 08:24 PM   #11
JohnnyBravo
That's a win... Congrats
Old June 18th, 2018, 01:18 AM   #12
kaos
kaos's Avatar
Good stuff.
Old June 18th, 2018, 03:07 PM   #13
danno25nh
Motorcycle(s): 2014 Ninja 300, 2009 Versys
Welcome!
danno25nh is offline   Reply With Quote
Old June 18th, 2018, 03:37 PM   #14
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Welcome
I think I have a problem. ninjamunky85 Pictures 14 May 2nd, 2013 05:22 AM
Do i have a problem? NoobNinja Off-Topic 15 July 28th, 2009 06:17 PM
