Old April 26th, 2020, 08:43 PM   #1
kawasaki_wife
Motorcycle(s): Kawasaki ninja 250
Idling issues 2005 Kawasaki Ninja 250
Just picked up a 2005 Kawasaki Ninja EX250F with 8,000 miles. It had been sitting for the last 3 years. The gas was extremely old and carbs were gummed up and dirty. I drained all the gas out of carb and tank, tooks carbs off and cleaned them thoroughly along with jets. Put everything back together and now it will start but only idle for a couple seconds and die. Both carbs have full bowls of fuel, nothing out the overflow though. Choke fully on, only runs a few seconds. Choke off, can't get it running. Once running, cannot turn of choke or open throttle as it will just die. tried adjusting the idle screw linked between the two down all the way and half turn in to just barely open the flapper valve, it started easier but didn't stay running. Any ideas?
Thanks!!!
kawasaki_wife is offline   Reply With Quote
Old April 26th, 2020, 08:58 PM   #2
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
kawasaki_wife! Glad to have you aboard...
<-- Linky
Old April 26th, 2020, 09:03 PM   #3
kawasaki_wife
I dont know what your meaning i dont know how to use a forum exactly this is my first time i was just looking for some help
Old April 26th, 2020, 10:13 PM   #4
Artruck
Motorcycle(s): 2007 ex250 (black), silver 2005 ex250 scrambler, 2003 ex250 donor bike, 2006 kymco people 250
Nevadawolf was just welcoming you to the site....
I would guess that you have your main jets and circuits clean, but the smaller ones are still clogged, so it’s trying to idle on the main jet. When you open the throttle, does it dies right away, or does it try and rev then die? Can you slowly open and get it to rev?
I would also double check all the vacuum lines that attach to the carbs. Did you split the carbs to clean them? If so you mad need to reset the throttle blades as well with some feeler gauges.
Artruck is offline   Reply With Quote
Old April 26th, 2020, 11:09 PM   #5
kawasaki_wife
vacuum lines are good, replaced one cracked one. made sure all tiny holes in both jets were clear of debris and through center holes. good fuel through both carbs. idle screw set just 1/2 turn past starting point. idle mixture screws turned out 2 1/2 to 3 turns on both carbs, choke fully on, starts then dies. will stay running sometimes but with any throttle, dies no matter how subtle it's applied. spark plugs are older i'm assuming look oily and black. have new ones on order, nobody had in stock. not sure if that would make a huge difference because it's already firing, just not staying running, so maybe weak spark? uhhh....
Old April 26th, 2020, 11:17 PM   #6
Artruck
The main jets are clear, but there are small passages in the carb that meter the air and control the idle jet that basically runs the bike below 4 or 5k rpm. If those are still blocked, it will fall on its face when you try and run it. The only other thing to check are the diaphragms and the needles to make sure they are in right. If they are catching or stuck, it would also choke it off.
Bad news is, I think you are going to have to pull the carbs out again.
I found that running cleaner through all the small passages, and ultrasonic cleaning in vinegar and degreaser mix worked really well. I also always replace the screws on the bowls with hex head screws in SS to make sure they come off again later.
I mostly find old filter material in the small passages in the intake part of the carb cause the problems. Old filters get dry, some one fires up the bike, and it crumbles into the carbs.
Old April 27th, 2020, 06:12 AM   #7
ducatiman
ducatiman's Avatar
15 years old, only 8000 miles and sitting the last 3 years
Aggressive carb circuit clearing methods coupled with automatic replacement of all consumables would be strongly advised. Sounds like some attention to the carb enrichener (aka starting circuit) and float circuits were not dealt with. Pilot screw orings replaced? Air correction circuits confirmed clear? I'd guess not.
How clean the carbs look is not necessarily the 100% indicator....its what you *can't* see that'll get ya every time.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old May 2nd, 2020, 05:34 AM   #8
Snake
Snake's Avatar
Hello and welcome!
Old May 2nd, 2020, 08:16 PM   #9
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Welcome!
Old May 3rd, 2020, 09:54 AM   #10
Welcome!
2005 kawi ninja 250r Running issues. Ninjas 1986 - 2007 Ninja 250R Tech Talk 61 September 23rd, 2017 09:55 PM
Idle/Start issues with 2005 Ninja 250 agentbad 1986 - 2007 Ninja 250R Tech Talk 14 August 24th, 2013 05:51 PM
2012 ninja 250 idling high tdog7812 2008 - 2012 Ninja 250R Tech Talk 12 May 16th, 2013 04:38 AM
2005 With carb issues and water leak pilot815 1986 - 2007 Ninja 250R Tech Talk 23 June 4th, 2011 09:40 AM
2005 - shifting issues gogiburn 1986 - 2007 Ninja 250R Tech Talk 0 July 4th, 2010 09:04 PM
