Old July 2nd, 2014, 05:44 PM   #1
kfilla
kfilla's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250R
Shimming the carb needles
What does shimming the needles actually do to improve how the bike runs?
kfilla is offline   Reply With Quote
Old July 2nd, 2014, 06:12 PM   #2
Desmoluci
Threadkiller
Desmoluci's Avatar
Motorcycle(s): Yellow '04 stocker, '89 FJ1200, '87 Ducati Paso, '71 Yamaha XS1b, '99 KLR650, '81 FXE 80, '97 KTM 200EXC , etc
Hope this helps you understand.
https://www.ninjette.org/forums/showthread.php?t=9465
Desmoluci is offline   Reply With Quote
Old July 2nd, 2014, 06:14 PM   #3
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
Our bikes are set up from the factory too lean(not enough gas going ins), the needle in question blocks off fuel in the carb, as it is raised it enriches the fuel mixture getting the mid throttle power where it should be.
My Cafe Racer Build
My intro post
Shimming the Carb Needles... Is it for You? kkim 2008 - 2012 Ninja 250R Tech Talk 93 June 10th, 2018 05:25 PM
DIY Shimming the carb needles. Viper-Byte 2008 - 2012 Ninja 250R Tech Talk 1078 April 17th, 2014 10:16 PM
DJ Needles instead of shimming mxman38 2008 - 2012 Ninja 250R Tech Talk 7 May 30th, 2012 07:09 PM
Need help on shimming carb needles RedNinja21 2008 - 2012 Ninja 250R Tech Talk 6 October 27th, 2011 10:16 AM
FREE!!! 3MM Washers for Shimming Your Carb Needles kkim 2008 - 2012 Ninja 250R Tech Talk 1 September 10th, 2010 02:26 AM
