Old March 19th, 2023, 07:28 PM   #1
SS310
07 Carb options?
Hey all, I went down a month ago and the crash seems to have messed up my carb. The left side seems to be fine but the right (the side that went down) is dumping fuel into the cylinder.
The options I saw were a Motoku for $200 but a review said the needles didnt work for an 07, and a used oem for $220. I wanted to buy a new one to save myself the trouble but how hard is it to adjust the #2 carb back to normal? Should I try and save $150 on a rebuild kit or just buy a new one?
SS310 is offline   Reply With Quote
Old March 19th, 2023, 08:15 PM   #2
I would highly recommend making an arrangement with our Ducatiman to restore the carb to new condition. I'd also recommend sending both of them to him so he can make sure they're both like new. I don't want to speak for him, but I think you'll be happy with the price.
Whatever you do, don't buy a rebuild kit. They're known for aftermarket substitute parts. If you want to give it a go youself, take the bowl off the errant carb and see if the float and/or the float needle is sticking open.
Old March 19th, 2023, 11:23 PM   #3
SS310
Ill ask him about it, but if rebuild kits are so bad how does he do it?
Old March 20th, 2023, 05:39 AM   #4
ducatiman
ducatiman's Avatar
"if rebuild kits are so bad how does he do it?"
carb kits? Nah.....I reuse after careful refurbing of each individual tuning component. I employ modern equipment in my arsenal.
Example....see pics...from this to that. Therefore, kits (too many variables) not necessary, just appropriate orings and float valves which have been confirmed by testing and repeat/prior use from confirmed vendors.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old March 20th, 2023, 07:06 AM   #5
ducatiman
ducatiman's Avatar
i've pm'd you....can offer you a refurb or do yours, either way.
Custom Carb Service
Old March 20th, 2023, 08:46 AM   #6
thedrewski86
thedrewski86's Avatar
Totally agree, rebuild kits are a marketing ploy for people who haven't done much carb work (or have, but don't really understand what they're doing). Brass parts need to be cleaned, sometimes a rubber o-ring needs replacement. Any "kit" full of parts is just that, and throwing parts at these bikes has never worked
Don't think, look!
Old March 20th, 2023, 08:51 AM   #7
Worse than that, all the aftermarket kits I've come across have aftermarket jets. That often (always) makes for difficult or impossible tuning problems.
Old March 20th, 2023, 11:11 AM   #8
ducatiman
ducatiman's Avatar
prime example documented right here. Pilot screw differences, and far east kits often contain unmarked (afa size) jets as well.
Custom Carb Service
Old March 20th, 2023, 07:28 PM   #9
EAK
Motorcycle(s): 2002 Ninja 250
Waste your time and money or let Gordon fix your carbs
Enough said.
He refurbished mine and many others on this forum. Quality work, reasonable prices. Take them off once, send to Gordon, reinstall. Simple.
EAK is offline   Reply With Quote
2007 250ZZR Carb cleaning - any mods should I do while the carb is apart? SibSerge 1986 - 2007 Ninja 250R Tech Talk 26 February 19th, 2024 03:17 PM
FS: Motion Pro Syncpro Carb Tuner (Carb Sync) $60 Shipped menikmati Motorcycle-related 4 April 8th, 2020 12:39 AM
Valve adjustment, carb clean, carb sync? amad1972 1986 - 2007 Ninja 250R Tech Talk 2 July 29th, 2014 09:42 PM
Shock options RacerX113 Ninjettes At Speed 27 December 11th, 2013 03:09 PM
Pregen Carb Options? bagtf3 Ninjettes At Speed 2 March 7th, 2013 09:09 PM
