August 2nd, 2013, 08:11 PM | #1 |
rpms dropping
Ugh always something with my bike haha
Okay so at idle my rpms will just drop and bounce back up almost like a miss fire but after getting hot it stops. But then rpms start to hang at 2k before dropping Any ideas? Heres a video
Link to original page on YouTube. |
August 2nd, 2013, 09:19 PM | #2 |
Is the gas fresh?
I'd say the first things to do would be to adjust the idle mixture (sounds like it's lean) and check the carb sync before moving on. How do the plugs look? |
August 2nd, 2013, 09:44 PM | #3 | |
Gas is fresh or so id assume its done it one every fill from every gas station and plugs im not to sure ill have to getting around to checking them out. |
August 3rd, 2013, 09:04 AM | #4 |
Idle speed is to low. 1300 +/- 50 rpms. If you ever look at your plugs you may be running rich. The slight fluctuation is probably nothing. Otherwise the bike sounds normal.
Have you had the valves adjusted yet? |
August 3rd, 2013, 09:09 AM | #5 |
Still have rpm issues? If the bike runs and pulls fine all the way to redline, then I wouldn't worry about that little thing. Now if it does it while riding under load, then I would think something is up.
August 3rd, 2013, 09:35 AM | #6 | |
A new set of Iridiums may also help your ignition woes a little. FAQ Reading Spark Plugs How to Read Your Spark Plug |
August 3rd, 2013, 10:49 AM | #7 | |
August 3rd, 2013, 12:23 PM | #8 |
Join Date: Apr 2013 Motorcycle(s): 2004 Ninja 250 Posts: 465
My bike does the exact same thing only its a pregen. I'm going to sync my carbs then see if it helps. What are your idle screws at?
August 3rd, 2013, 12:44 PM | #9 | |
A few other things to note. 1. you have a jet kit and slip on and have no idea how rich or lean you are running 2. your average ambient temp you've been riding in is over 100 degrees faren. temps play a role in how rich or lean the bike runs 3. to your knowledge you haven't had a valve adjustment or plug change/check. If your idle hangs or is hunts, it's usually a symptom of another problem. You may need to readjust the idle mixture or have the valves adjusted. Poor idle is a give-away of valves being out of adjustment. Motorcycle Carb Theory 101 |
Throttle not dropping | 07_25_stl | 1986 - 2007 Ninja 250R Tech Talk | 16 | December 28th, 2014 01:29 PM |
Dropping into N after shifting to 2nd. | Mountain Dew | 2008 - 2012 Ninja 250R Tech Talk | 21 | August 27th, 2012 10:46 AM |
What's up with my bike? Dropping gears | Trailerboy531 | 2008 - 2012 Ninja 250R Tech Talk | 15 | June 25th, 2011 12:06 PM |
Ninja Dropping Experiences | Goosey | !%@*#$%!)@#&!%@ I crashed! | 22 | June 23rd, 2011 11:37 PM |
Eaves Dropping | HKr1 | Off-Topic | 11 | October 15th, 2009 03:52 PM |
