Old February 19th, 2014, 02:10 PM   #1
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
GSXR shock swap questions
So I have gone through countless GSXR shock threads and still can't make up my mind if it is something I should do or not.
Is the mod worth it?
Does anyone here recommend it?
For the people who have done it what are your thoughts?
Old February 19th, 2014, 02:33 PM   #2
tooblekain
tooblekain's Avatar
Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike)
Definately worth it. The only reason I am not running a gixxer shock is because I got a Racetech one...but I have my gixxer rear shock as back up.
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear
tooblekain is offline   Reply With Quote
Old February 19th, 2014, 02:58 PM   #3
Here is the deal, maybe you can learn from my mistakes.
On the stock bits, both front and rear the bike is kinda funky at pace but it tolerable. Once you upgrade the rear, the stock front will TOTALLY suck. If you upgrade the front bits only, the bike is better than tolerable.
Now... if you upgrade them both... now your talkin'.
My mistake was that the gsxr shock upgrade is so cheap and easy, I did it before the front and paid for it on the track with slower lap times.
If your just streetin' it, then if you you set it soft and dial in the damping and rebound to your preferences, your rewarded with more enjoyable seat time with less recovery time needed after rides.
Old February 19th, 2014, 03:03 PM   #4
tooblekain
tooblekain's Avatar
Plus one!!! Forgot to add that I also have emulators. Emulators are cheap and if you have a drill press you can do the install yourself.
Old February 19th, 2014, 03:35 PM   #5
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
Gixxer shock was one of the first mods I did to my 300. Difference is night and day IMO, definitely worth the $40 I paid for the shock plus the cost of hardware.
P.S. I just remembered that I sold my stock shock for $40, so overall cost was very little
Old February 19th, 2014, 05:06 PM   #6
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
All sounds good. So yes there are several gsxr swap threads but no DIY. I think i have the jest of it from reading other threads but one thing i am unsure of is the dog bones. So i will need to buy a set of dog bones that will work right?
Which ones do you guys use and where did you get them from?
Old February 19th, 2014, 05:10 PM   #7
You will need a set of bones to keep stock height or adjust per your needs, I got mine from Rexbo.
Old February 19th, 2014, 05:27 PM   #8
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
How fat are you? Gixxer shock may be over kill for some.
Rexbo no longer provides dog bones so that makes life harder, fyi.
CVMA #531
Trailerboy531 is offline   Reply With Quote
Old February 19th, 2014, 05:36 PM   #9
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
right now i am hovering right around 180lbs and have dreams of getting down to 170
Yeah i seen that rexbo does not make the bones anymore which lead to me wondering what i would end up doing.
Old February 19th, 2014, 05:57 PM   #10
iamjacob
iamjacob's Avatar
Motorcycle(s): 2011 250R SE
or even
If you can turn a wrench you can shape steel.
Sorry for the giant images, I could figure out how to make 'em any smaller.
Last futzed with by iamjacob; February 19th, 2014 at 06:15 PM. Reason: typos
iamjacob is offline   Reply With Quote
Old February 19th, 2014, 06:16 PM   #11
ChrisJuliano
Motorcycle(s): Ninja 250R
I ordered 1"-1.25" (he sells 1", I had him make me 1.25 or close to it" rise dogbones from a guy for $35ish shipped.
I have been waiting for a little over a week and a half and have not recieved them yet (sorta expected for custom specs given to him) so when I do get ill let you guys know how they are.
Burkhartcycle.com I think it was.
I just got a text from him saying they sent out this morning!!!! WOOT!
ChrisJuliano is offline   Reply With Quote
Old February 19th, 2014, 06:17 PM   #12
Trailerboy531
I think he wants you to get a bone from a pet store and drill a hole in it.
could work.
CVMA #531
Old February 19th, 2014, 06:27 PM   #13
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
Nice definitely post up once you get them.
What size would be best to keep bike in stockish position?
What made you go with the 1" and 1.25"?
what about these bad boys? junk?
http://www.ebay.com/itm/NEW-08-09-10...b73bc7&vxp=mtr
Old February 19th, 2014, 06:52 PM   #14
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
I have a little cash to spend (not much) and was originally planning on dumping it into farkles but after reading a bit i am thinking it will go into the front forks. **** aint cheap but will definitely be worth it.
I still need to send my dirt bike forks out to get revalved and setup ect… but i don't have to do anything and it only costs $200 bucks.
Question regarding gsxr shock, should i be looking for a particular year or will they all roughly fit the same even newer ones?
Old February 19th, 2014, 08:48 PM   #15
ForceofWill
Blind 250 Loving Whore
ForceofWill's Avatar
Assuming he has the specs now for the dogbones for our bike, I'm gonna get some from him since my shock is on the way.
What name and specs did you give him? IE, how should I reference this piece if when I talk to him.
Old February 19th, 2014, 09:02 PM   #16
LoD575
LoD575's Avatar
Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636
I have been following shock swaps as well. First is to replace front springs and oil then go for the rear.
LoD575 is offline   Reply With Quote
Old February 20th, 2014, 03:26 AM   #17
ChrisJuliano
He has 1" raise dogbones, I think 1.25 would be perfect since I think itll be very close to stock since I am lightweight and my gsxr shocks preload is set litearlly whole way up (1 3/4" of sag for me) so my rear dropped alot.
If you are more weight you may be able to get 1"
He has them on his website just search, if you want something custom in the messages I wrote what I wanted and emailed him. You can email him first if you want.
Old February 20th, 2014, 03:27 AM   #18
ChrisJuliano
Those and almost everything on the market lower it.
The longer they are the lower the bike will go, the shorter and the higher itll go. No one makes raised ones for the ninja most lower 1-4" this is the only one I can find other than rexbo which does not sell them anymore.
Old February 20th, 2014, 04:53 AM   #19
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Wrong, in Germany you can get this one for 35 USD (he's shipping worldwide and I'd send a email a while ago asking about size, he'll make each size you tell him, remember its mm not inch) http://www.ebay.de/itm/Heck-Hoherleg...item27bc02038d
And I post this link the second time now, where you can get some: http://japan.webike.net/ps/#!p.m=5921&p.c=1080&p.sk=1
Old February 20th, 2014, 05:01 AM   #20
ForceofWill
I just emailed them and asked, didn't see the option anywhere on the site, just lowering links.
Thanks for the heads up though!
Old February 20th, 2014, 10:35 AM   #21
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
Old February 20th, 2014, 01:15 PM   #22
ChrisJuliano
Thats weird they were just on his site. I am going to talk to him and see if he took them off or what.
Old February 20th, 2014, 01:36 PM   #23
ninjamunky85
Que Buenos Son!!!
MOTM - Nov '14
My shock was from an '07 I believe. I don't know if the year matters, I'm sure it does I just don't know what years don't fit. Make sure that it is from a 600/750cc though cause the shock from the 1000 won't fit.
Old February 20th, 2014, 01:42 PM   #24
ChrisJuliano
Hes adding it tonight for you guys.
What height would you guys want this to be raised. I can make him make one with multiple holes maybe, one for 1"-1.5"?
Old February 20th, 2014, 01:43 PM   #25
Use a 07, 08 or 09 they all are the same length (315mm).
Old February 20th, 2014, 01:59 PM   #26
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
IDK, what would I need to be at stock height, or just a hair above?
Old February 20th, 2014, 02:16 PM   #27
ChrisJuliano
Not sure, when mine come I can find out though when I install them. I got 1.25" raise I think.
Old February 20th, 2014, 03:31 PM   #28
ForceofWill
Multiple holes would be awesome(heh), I'm like 190 with gear on so I'd try 1-1.25
Old February 20th, 2014, 03:40 PM   #29
ChrisJuliano
Ill talk to him maybe he can make something up.
Old February 20th, 2014, 03:48 PM   #30
Question Tom. Why would you raise your ride height based on weight or is there more to your thoughts?
Old February 20th, 2014, 04:07 PM   #31
ChrisJuliano
Cssmith for me since I am light I had to get rid of all the preload the gsxr shock allows, which made it very low to get my sag right around 1 1/2 to 1 3/4. So my rear end was so low that I wanted it to be about a quarter of a inch higher than stock so figured 1.25" was just about right.
Hence why I choose to raise my bike 1.25" with the dogbones. Then I will ahve a great ride height since I want it to have a little bit of rake so it turns in quick.
Old February 20th, 2014, 04:33 PM   #32
old3
Anyone know the ratio of dogbone change to actual bike ride height? What distance between dog bone lengths equals 1" of ride height lift?
This could be as simple as drilling new holes in stock arms, no?
old3 is offline   Reply With Quote
Old February 20th, 2014, 05:03 PM   #33
0.559 with the stock 08+ knuckle. no idea on 300 or pregen
Old February 20th, 2014, 05:28 PM   #34
old3
Great place to start, thanks!
Old February 20th, 2014, 05:33 PM   #35
ForceofWill
Wasn't really just based on my weight. It's just I haven't seen a whole lot of concrete on the GSXR subject and I didn't wanna not be able to get there with a certain length riser and the shocks available pre-load.
Was thinking I would get both links or if he'll make them one with two holes at 1 and 1.25 so I can play around with it.
Old February 20th, 2014, 05:45 PM   #36
That's cool, normally riders buy springs based on weight and then adjust ride height other many other factors.
Last futzed with by csmith12; February 20th, 2014 at 08:11 PM. Reason: spelling
Old February 20th, 2014, 06:21 PM   #37
ChrisJuliano
I am going to keep the stock spring and see how it is, I may just have to replace the spring.
Old February 20th, 2014, 06:26 PM   #38
an unbalanced bike is worse than an incorrectly sprung balanced bike. do both front and back at the same time.
Old February 20th, 2014, 06:27 PM   #39
ForceofWill
Same. I'm gonna get the front put together and the gsxr and see how it does from there. If I need a new spring I can adjust after. I'm gonna be changing so much at once and I'm really not a bike suspension guru(more of a car guy) so I'm gonna have to start here and try and dial in what I can.
Old February 21st, 2014, 12:03 PM   #40
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
anyone know how much lower the bike is with the gsxr shock and stock dog bones?
new rear shock swap... perhaps i went a little too far? subxero 2008 - 2012 Ninja 250R Tech Talk 19 January 24th, 2017 12:00 PM
Race-prepped 250 GSXR shock swap question Braden07 2008 - 2012 Ninja 250R Tech Talk 7 November 15th, 2014 07:03 AM
engine swap questions Honda JEB General Motorcycling Discussion 6 December 13th, 2013 07:59 AM
CBR600rr rear shock swap Gorilla25 2008 - 2012 Ninja 250R Tech Talk 59 April 1st, 2012 11:39 AM
06-07 GSXR exhaust swap question. Cochese 2008 - 2012 Ninja 250R Tech Talk 19 May 9th, 2009 10:48 AM
