Old October 27th, 2014, 08:06 PM   #1
JBinSD
Motorcycle(s): '13 Ninja 300, '99 SV650 tracked
Brake pads for Track?
Finally wearing through my OEM pads, anyone care to share the preferred shoes for the 300/250? I think the calipers are the same size. . .
Thanx,
Joel
JBinSD is offline   Reply With Quote
Old October 27th, 2014, 08:10 PM   #2
EBC Double-H ($35 or less) when I can't get vesrah. And trust, I show them no mercy. My greatest skill is in the brake zone ijs....
Old October 27th, 2014, 08:15 PM   #3
JBinSD
Thanx mang, my buddies reccommended carbone lorraine? looks like Riders discount carries them too. . . I was fine with the OEM, but maybe an upgrade is even better. . . Im track-only, so should invest in something better anyway. . .
Old October 27th, 2014, 08:19 PM   #4
I didn't have a problem with the OEM either, but I don't complain much about anything. Go figger...
Old October 28th, 2014, 11:53 AM   #5
Old Lemon
Lays er down
Old Lemon's Avatar
Motorcycle(s): 2008 Lime green Ninja 250R
what csmith said, ebc hh sintered pads. ive found them for 20$ before on ebay. definitely worth getting + steel braided lines is about the best you could make our brakes
Old Lemon is offline   Reply With Quote
Old October 28th, 2014, 12:29 PM   #6
Ghostt
Ghostt's Avatar
+1000 for EBC HH pads, I've run those on many bikes, without any issues.
I have now got the Extreme HH pads(http://www.amazon.com/gp/aw/d/B002LGU24K) and EBC full floating disc(http://www.amazon.com/gp/aw/d/B0031BCEMM) on the ZX5R and it will stop on a dime, and leave you nine cents change, I also changed the brake fluid out with Motul DOT 5.1 Brake Fluid(http://www.amazon.com/gp/aw/d/B005UGKDRY) and I already has a Spiegler brake lines (http://www.spieglerusa.com/brakes/cy...line-kits.html)
The ZX2R SET up is,*Venhill*brake lines(http://www.venhillusa.com/products.html), the EBC HH pads, a new V style rotor, and changed the fluid in both front and rear with the same brand that I used on the ZX5R
With all that, it too, will stop on a dime, and leave you nine cents in change.
look here http://ebcbrakes.com/products/motorcycle/
Another important item, and the most overlooked is the calipers themselves. When doing brakes ALWAYS at the very least disassemble and clean the piston cups, and might as well replace the seals, nothing sucks more than you wanted to save a few bucks, but is it worth your life? And you want the fullest possible performance out of your brakes.
violente et ignorantia
ZX-2R BLOG
Old October 28th, 2014, 01:17 PM   #7
vesrah
Old October 28th, 2014, 01:28 PM   #8
dino74
dino74's Avatar
I usually get the Vesrahs from
http://www.kurveygirl.com/shop/produ...roducts_id=353
CVMA #55
Old October 28th, 2014, 01:31 PM   #9
dino74
dino74's Avatar
Joel,
Check your rotor for warping. This is the stock the rotor off my 300. The center of the rotor is lying flat on the table.
CVMA #55
Old October 28th, 2014, 01:33 PM   #10
Ghostt
Ghostt's Avatar
Hence the need for a full floating disc
ZX-2R BLOG
Old October 28th, 2014, 01:34 PM   #11
Originally Posted by dino74 View Post
yea! I don't always order in time (my fault) and end up with EBC which is fine too.
Old October 28th, 2014, 01:39 PM   #12
dino74
dino74's Avatar
Yeah, I went to the EBC floating rotor,
FYI: Many sites say the rotors are compatible between the 250 and 300. The 250 has 6 holes and the 300 has 5.
CVMA #55
Old October 28th, 2014, 02:01 PM   #13
tooblekain
tooblekain's Avatar
Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike)
I had a warped rotor also, but I took my wheel (with the rotor still attached) to Dr. John's in Anaheim. He got it straightened out. It hasn't warped since.
I also use Vesrahs and got them from Kurveygirl
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear
tooblekain is offline   Reply With Quote
Old October 28th, 2014, 02:30 PM   #14
JBinSD
Thanx guys, EBC HH from Amazon less than $30 delivered, although I do like Kurvey and Vesrah, maybe next time. . .
this will be the first time working on my own brakes, so should be amusing, but its not rocket science, rt? ;-) Worst that can happen is I go faster. . .
Old October 28th, 2014, 02:34 PM   #15
^^^ hahahahhaha By default right?
Old October 29th, 2014, 07:53 AM   #16
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
Vesrah RJL but I also seem ok with the Galfers put on last time. Can't remember which pad off the top of my head but they held up well on the track.
Old October 31st, 2014, 10:32 AM   #17
bruce71198
bruce71198's Avatar
You guys use your brakes?
Old October 31st, 2014, 10:34 AM   #18
Ghostt
Ghostt's Avatar
Only when I come up on lap traffic LOL
ZX-2R BLOG
Old November 1st, 2014, 01:14 AM   #19
MirinNinja
Motorcycle(s): Ninja 300
How many days do you guys get out of your EBC HH pads? I only got 4 days out of my last set.
MirinNinja is offline   Reply With Quote
Old November 1st, 2014, 06:25 AM   #20
4 days
whoa........ right there. They must be draggin' terribly. I get a whole track/race season and then some.
Old November 1st, 2014, 11:38 PM   #21
MirinNinja
4 days
Yeah there is a significant amount of drag. If I spin the wheel really gard maybe it can spin 360 degrees. When I installed the pads I always push the pistons back but that doesn't seem to do anything.
Any ideas on how to fix this?
Old November 2nd, 2014, 12:33 AM   #22
Flying
Motorcycle(s): 2010 Ninja 250
check your brake piston seals for damage and check your pistons for any pitting
either or both may need replacement
Old December 12th, 2014, 10:18 AM   #23
JeffroJ
JeffroJ's Avatar
Motorcycle(s): Old gen and New gen 250, Buell XB12S, Yamaha FZ1
Clean the pistons with brake fluid, you may need to pull the pistons out and polish them.
Vesrah pads are the best for the 250 on track, put me on the podium many times.
WERA #217
3 Ninjas and a Mexican - Pre-2008 Class winner of the first ever EX250 Endurance by Marietta Motorsports
JeffroJ is offline   Reply With Quote
Cant find brake bolt connecting brake pads. Trubin General Motorcycling Discussion 6 June 3rd, 2014 05:35 PM
Replacing brake pads and brake fluid Bones85 2008 - 2012 Ninja 250R Tech Talk 4 April 28th, 2013 06:25 PM
Brake pads jack_bm 2008 - 2012 Ninja 250R Tech Talk 10 May 29th, 2012 12:34 PM
Brake Pads A7xschecter6661 1986 - 2007 Ninja 250R Tech Talk 11 August 12th, 2011 06:18 PM
Brake pads Bill N 2008 - 2012 Ninja 250R Tech Talk 8 July 14th, 2011 06:05 AM
