Old June 25th, 2015, 03:07 PM   #1
basementmt
Speedo needle going crazy
Hi all... all of a sudden I have a problem with the speedo needle, basically upon turning off the needle is stuck on 20km/h even though I am at a standstill, while moving also it is not giving the correct readings, riding at approx 10km would give me 20km while sometimes it gets stuck on 40km.
I tried to remove the cable and plug it again with no success. The funny thing is that when I knock gently on the glass it goes back to 0km.
Do you know what could be the problem and how I can solve it?
basementmt is offline   Reply With Quote
Old June 25th, 2015, 07:18 PM   #2
The cable has 2 ends. When you say you unplugged it and replugged, is it safe to assume you did both ends? I mean, the end on the front wheel is real easy to get to ya know.
Old June 25th, 2015, 08:34 PM   #3
Originally Posted by basementmt View Post
.......... The funny thing is that when I knock gently on the glass it goes back to 0km.
The needle may be hitting the dial.
Use a magnifier to concentrate Sun light on several spots of the needle in order to straighten it out with the heat.
Old June 26th, 2015, 01:00 AM   #4
basementmt
Yeps, both ends with no luck.
Old June 26th, 2015, 01:02 AM   #5
basementmt
I don't think so, I think it's more related to the pin needle stuck because of internal mechanism, no one ever encountered this?
Old June 26th, 2015, 08:02 AM   #6
There is no internal mechanism, just a magnetic clutch a spring for returning to zero.
The cable makes the magnet of the clutch spin, which drags the needle via the clutch.
Old June 26th, 2015, 08:34 AM   #7
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
I had a pin in my speedo once, hurt like hell; I can't imagine a needle being any different :/
Old June 27th, 2015, 02:00 AM   #8
basementmt
haha, trolling around JohnnyBravo?
Old June 27th, 2015, 04:31 PM   #9
JohnnyBravo
How high the needle? Ninjinsky 1986 - 2007 Ninja 250R Tech Talk 1 September 29th, 2014 05:27 AM
Speedo Drd, Speedometer and Odometer Accuracy-Speedo Healer/drd Klondike1020 General Motorcycling Discussion 8 August 17th, 2014 12:23 AM
what carb needle to use? 01subaru 2008 - 2012 Ninja 250R Tech Talk 6 April 24th, 2012 05:17 PM
which size needle goes where? slow_2k10 2008 - 2012 Ninja 250R Tech Talk 7 September 7th, 2010 01:57 PM
Mixture Needle Shimming komohana 1986 - 2007 Ninja 250R Tech Talk 26 March 17th, 2009 09:08 PM
