Old January 12th, 2016, 09:30 PM   #1
blewbot
Motorcycle(s): Ninja EX250R 2012
$25 DIY Oilchange
Made this short video to show how easily the Oil can be changed on the 08-12 ninja - easily saves $50-75 that the dealer or a shop would collect and it only takes start to finish 10 minutes.
https://youtu.be/kSEl2Kra_cA
blewbot is offline   Reply With Quote
Old January 13th, 2016, 07:51 AM   #2
The oil level is not correct.
Just adding oil up to the upper line in the sightglass after replacing the filter does not give you the proper level.
After initial filling, you need to start the engine and let it run at least enough to fill the oil filter and circulate the oil, then wait (usually 3 minutes), then balance the cycle level (more accurate than using a rear or centerstand), then read the sightglass.
http://faq.ninja250.org/wiki/How_do_I_check_my_oil%3F
Old January 13th, 2016, 08:32 AM   #3
Welcome Josh!
Thanks for sharing.
Old January 13th, 2016, 05:09 PM   #4
blewbot
Thumbs up
Appreciate the info I did this after the video to be sure. The oil stayed at the correct level.
DIY thread.... Josh_kcco 1986 - 2007 Ninja 250R Farkles 2 January 7th, 2014 10:40 PM
Cleaning and lubing my chain, oilchange , and cleaning air filter SON1C 1986 - 2007 Ninja 250R Tech Talk 3 June 29th, 2013 05:55 AM
DIY: How to DIY Jiggles General Motorcycling Discussion 5 January 25th, 2013 11:01 AM
DIY ZG DB install ? chef 2008 - 2012 Ninja 250R Farkles 5 October 13th, 2011 04:44 AM
