Old May 11th, 2017, 03:00 PM   #1
Sbworth17
Motorcycle(s): 05 Ninja 250r, 87 Honda Hurricane CBR 1000
Proper Starting Techniques
Can you guys tell me how it's SUPPOSED to be done, I feel like if my bike doesn't start up the first time then I'm doomed to flood it.
Do you ever or always use the choke?
How long do you hold the start button before giving up?
What happens if you hold it too long?
I always keep it on the battery tender when not in use...
Sbworth17 is offline   Reply With Quote
Old May 11th, 2017, 03:18 PM   #2
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
Sbworth17! Glad you found us...
Old May 11th, 2017, 03:46 PM   #3
Hello and Welcome!!!
Here's what I do:
1. pull choke
2. push start
3. don't touch throttle, ever!!!
4. as engine revs up, slowly decrease choke so it revs at regular idle-speed
5. you're not touching the throttle right?
6. as you decrease choke so idle-speed is normal, choke will eventually be off completely.
Old May 11th, 2017, 03:49 PM   #4
Welcome Scott!
Old May 11th, 2017, 04:08 PM   #5
Snake
Snake's Avatar
Hello and welcome! ,
Old May 11th, 2017, 05:34 PM   #6
Sbworth17
Here's what I do:
1. pull choke
2. push start
Lol after I tried it without the choke, I tried it with the choke, then yes, I touched the throttle.
Old May 11th, 2017, 06:58 PM   #7
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
The reason you can't open the throttle is that the "choke" isn't really a choke, it's an enriching circuit and needs the vacuum created on the engine side of the carb. butterfly to pull fuel through the enriching port. If you open the throttle at all you lose the vacuum.
Oh, and welcome
Old May 11th, 2017, 07:14 PM   #8
This is what ninja250.org suggests - https://faq.ninja250.org/wiki/What_i..._at_startup%3F
More info here - https://faq.ninja250.org/wiki/Intake
Old May 11th, 2017, 07:35 PM   #9
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
step 1 engage choke
step 2 push start button
step 3 disengage choke when revs start to get close to 4k.
TEAM ALFALFA
www.apexassassins.com
Old May 11th, 2017, 08:03 PM   #10
Sbworth17
Oh, and welcome
Ok cool thank you for a detailed answer that's exactly what I was looking for I appreciate it. So if the throttle gets touched and you lose the vacuum how do you recover from that?
Old May 11th, 2017, 08:42 PM   #11
Z1R rider
Z1R rider's Avatar
Just close the throttle, and if the idle speed adjuster (black knob under carb on the left side) isn't screwed in too far, holding the throttle plates open excessively, it will enrich (choke) again.
Old May 12th, 2017, 06:19 AM   #12
Having the engine tuned properly - correctly adjusted idle mixture and proper hot idle RPMs - will help starting as well.
Same goes for maintenance. Having the carbs synced, valves adjusted, air filter clean, and plugs in good condition will all contribute to ease of starting hot or cold.
Running the proper octane gas will help some engines fire up easier also. For the Ninja, always run "Regular" 87 octane. Ethanol-free gas is best for numerous reasons, if it's available in your area.
Old May 12th, 2017, 06:35 AM   #13
DEFY
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
DEFY's Avatar
Think you get the idea:
My Daily routine:
1)Gear in Neutral, leave parked in 1st.
2)Choke On
3)ON/OFF Switch On, leave it parked in off.
4)Hit Start switch
5)Leave it warm up until revs increase
6)Remove Choke
7)Add a little throttle to see if it won't sputter and die
7a) If starts to bog out add choke again and give more time to warm up
7b) else place in gear and add a bit of throttle to see if it can support the load without bogging out, once again if does place back into neutral and add choke again
Spoiler for topic:
It might just be the [you] tag
Old May 12th, 2017, 08:39 AM   #14
taz
taz's Avatar
MOTM - May '17
WELCOME
Old May 12th, 2017, 08:54 AM   #15
My Daily routine:
2)Choke On
4)Hit Start switch
6)Remove Choke
Similar here, except once it's running with the enrichers on, I ride away gently, and let it warm up while I'm rolling.
Old May 12th, 2017, 11:29 AM   #16
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
I used to ride slowly and gently with the choke on down the block. Then as the bike warms up, I'll decrease the choke. By the time I get out of my neighborhood (about 3/4 mile) and onto the main road, I can usually get rid of the choke completely.
But nowadays, I have an even better technique. It's called getting rid of the 250 and getting a 300. It could be 30 degrees, the bike starts right up. No need to mess with anything.
Riding it like I financed it.
Old May 18th, 2017, 05:16 PM   #17
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Welcome
Some of Valentino Rossi riding techniques Motofool Videos 1 April 29th, 2016 12:54 PM
Japanese U-turn techniques jkv45 Videos 9 February 10th, 2016 08:45 AM
Some police riding techniques and skills Motofool Videos 4 January 27th, 2015 11:41 AM
M Gymkhana® Tech Tips - Riding Techniques M Gymkhaner Riding Skills 7 September 25th, 2014 11:48 PM
Proper Camera, Proper Bike (07 Ninja 250) elninoloco7 Pictures 5 May 22nd, 2012 10:32 AM
