Go Back   ninjette.org > General > Pictures
Old January 7th, 2020, 11:53 PM   #1
memphisninja
memphisninja's Avatar
Motorcycle(s): 06 Ninja 250 and Suzuki Burgman 400. Previously owned: 78 KZ650, 80 KZ440, 03 ZX6R
$150 Ninja 250 Build
Picked this up on FB for $150, only has 2300 miles on it and is in damn good condition besides missing some parts (luckily I have most of the parts. Was used as a parts bike, I plan on making it into a street fighter bike, but I can't make up my mind because the plastics are in good shape, just needs painting. The bike was missing a fuel petcock, ignition key, gas cap, upper triple tree, carbs,
Here is what I plan on doing.
Clean the bike and every nut, bolt, wire, plastic, etc. very thoroughly.
Order new Pirelli MT75 tires, new battery, fuel petcock, and a gas tank bracket
Re-grease and inspect the swing-arm bushings, suspension linkage bushings, new wheel bearings, new brake pads, clean the chain and oil (still good, just dirty as hell), and replace sprockets.
Change fork oil, upgrade fork springs, inspect steering stem bearing, check alignment on forks and triple trees, install clamp style handlebars on triple tree, make a headlight bracket.
Inspect the valve train and adjust valves if needed, check timing, and change the oil. Not planning on doing too much as the engine looks in damn good shape and has good compression (185 psi on both cylinders).
Get the extra carbs I have rebuilt by Ducatiman.
So far here is what I have done...
I've ordered a K&N pod filter, 110 main jets, 40 pilots, 15T front sprocket, front master cylinder, new ignition, upper triple tree, and a Pirelli Mt75 120/80-16 rear tire.
I have removed the rear end to be cleaned and inspected. I pulled the old air box out, I removed the chain and sprockets.
I am hoping for this to end up being a very clean build and cheap build. I expect to keep the grand total under $600.
_
memphisninja is offline   Reply With Quote
Old January 10th, 2020, 08:19 AM   #2
dodgerdad
dodgerdad's Avatar
Looks like a lot of fun work. Keep on posting updates!
Old January 11th, 2020, 08:22 AM   #3
Snake
Snake's Avatar
Great project. I love that color.
Old January 11th, 2020, 03:51 PM   #4
Great project!
Shoot, too late! I have spare upper triple-clamp I could’ve sent you!
Be careful about spending too much on these builds. Sum of all little parts here and there could’ve gotten you running EX250 already assembled.
Old January 12th, 2020, 04:00 PM   #5
memphisninja
Great project!
So far I am only in $445 grand total ($150 for the bike, $60 in gas to get it, and $235 in parts so far.) I sure do appreciate it though!
Here is an update and some more pics.
So I made my own custom 1/4 fairing with the touring windshield. I still gotta fabricate some lower mounting brackets, but it should be fairly easy, I was thinking about some metal straps. Anyway, in the pictures it's just mocked up, so there is still some gaps, but that will go away once I make the proper brackets and get some stock mirrors back on.
As far as the rest of the bike goes, I installed a upper triple tree, got my new pirelli mt75 rear tire in,installed throttle cables, installed handlebars and controls, installed foot peg brackets, installed fuel petcock, organized carbs and parts so it can be cleaned, got my K&N air filter in, got some bigger jets for it, and I sealed up the bolt holes on the gas tank.
Not too much left. I just gotta get a front tire and get tires mounted and balanced, clean,install, and adjust the carbs, install a battery, re-grease the bushings, re-torque all bolts to spec ,valve adjustment, oil change, bleed brakes, install headlight bulb, install stock mirrors, and clean and oil the chain. Should have all of this done by next weekend. I plan to spend no more than $700 grand total. But when I am done I should have a Ninja 250 worth double that.
Old January 12th, 2020, 05:15 PM   #6
Custom fairing!! That’s awesome!!
Can’t wait to see how this turns out!
Old January 14th, 2020, 02:43 AM   #7
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
NICE!!!!
Looking forward to watching the progress of this build!!
The Bike | The Truck
Old January 16th, 2020, 11:50 PM   #8
memphisninja
Here is another update.
I got the ignition installed, gas cap, fuel petcock, throttle cables, upgraded power wires to 4 gauge (ground, battery positive, and starter positive), new Accel 8mm coil wire, mounted and balanced Pirelli MT75 120/80-16 rear, and the front end has been re-assembled and re-torqued to specs.
I have a carb set, front tire, sprocket, battery, spark plugs, and brake pads on the way. Once I get all of that installed and the bike running, I'll start focusing on the suspension. I am gonna use a 08+ rear shock and EX500 springs with 15w oil for the fork springs. If anyone has either of those LMK I would be interested in purchasing.
Old January 17th, 2020, 07:38 AM   #9
gantt
gantt's Avatar
Motorcycle(s): 2019 Ninja 400, Sold 2012 Ninja 650, Sold 2009 Ninja 250r, Sold 2007 DRZ400s
you can generally find a gsxr shock on ebay for 30 bucks or less. i've bought two now and both cost about 25 bucks shipped
gantt is offline   Reply With Quote
Old January 20th, 2020, 12:20 AM   #10
memphisninja
Ok guys, here is another update. I have the rear end completed. Here is what was done. Everything was really good shape on the swingarm, just cleaned up, regreased, and then reassembled. Pretty easy and straight forward.
Cleaned and regreased swing-arm, balanced wheel statically, cleaned chain, clean and regreased Unitrack linkage bushings, adjusted chain, aligned rear wheel, cleaned wheel, cleaned shock, and torqued all bolts to specifications.
Should have this done by next weekend. Just waiting on a few more parts. So far my grand total investment is right at $600, all I really need left is a battery, fork springs, fork oil, rear sprocket, and a headlight bulb.
Old January 20th, 2020, 06:54 AM   #11
One suggestion - shim the cush drive if you haven't -
https://faq.ninja250.org/wiki/How_to...the_cush_drive
Smooths out the on/off/on throttle transition. They typically are extremely loose.
Old January 20th, 2020, 03:39 PM   #12
memphisninja
Thumbs up
Thanks, I completely overlooked that!
Old February 16th, 2020, 06:25 PM   #13
memphisninja
Well I have it completed... Gotta get it painted now. I decided to run it open frame in the rear and tuck all of the electronics away and I plan to install a LED tail light. So far it runs fantastic with the K&N pod filter. I have 110 mains, 40 pilots and 1 shim on the needles. The carburetion is damn near perfect (just a tad lean at redline). It idles extremely consistently, and the low speed-mid-throttle is very smooth. I'll post some more pics later. Here is a video and some pictures for now.
https://www.facebook.com/spencer.mit...2893596293557/
Old July 28th, 2021, 10:21 PM   #14
Jaydot1993
Motorcycle(s): Ninja 250R Ninja 400R
Did you delete the air box and run the bigger jets? I’d like to see the process I’m trying to get mine going with the pod filters and jet kit.. also I can’t see the photos on here I’m curious on how’s yours turned out
Jaydot1993 is offline   Reply With Quote
Old July 29th, 2021, 06:19 AM   #15
Be careful of "Jet Kits". The jets can be way out of spec, and way overboard.
It doesn't take much tuning to get it to run with pods, but it's not usually a great choice for the Ninja. Pods may make more power at WOT, but elsewhere they don't. They typically soften the low and mid-range power - which isn't a great trade-off for the little Ninja.
If you have an airbox, I'd keep it.
One of our Ninjas came with pods, and it ran OK when tuned, but still kinda flat down low.
For jetting with pods and a leaky stock exhaust, we ran factory 108 Main Jets, 1 shim on the needles, standard 38 Pilot Jets with the idle mixture screws in the range of 2.5 to 2.75 turns out depending on conditions.
It ran clean all the way to the limiter.
My Ninja 250 Build Nativex 2008 - 2012 Ninja 250R Tech Talk 8 April 2nd, 2018 05:42 AM
'86 Ninja 250 parts for sale $150 highvoltj General Motorcycling Discussion 3 September 14th, 2017 05:44 PM
Ninja 250 Build JMod45 1986 - 2007 Ninja 250R Tech Talk 8 January 20th, 2012 08:32 AM
