Old July 2nd, 2020, 12:39 PM   #1
Tsmith9233
Motorcycle(s): 03 ninja 250
09 with no spark
Going to look at REALLY cheap 09. The seller says it was running until both coils went bad. I find it hard to believe that 2 coils would fail simultaneously. Any ideas from the experts? I know nothing other than what the ad says. Going to look at it at 430 today.
Tsmith9233 is offline   Reply With Quote
Old July 2nd, 2020, 01:42 PM   #2
pickup coil i bet...
Old July 3rd, 2020, 09:24 AM   #3
Really cheap can be good deal if you know how to repair. Coils do not ever go bad, I've only seen 1 or 2 in my entire 40-yrs of riding. One was broken wiring terminal due to vibration, internally it was still good.
Some possibilities:
1. bad crank pickup-coils, more likely mis-alignment due to loose mounting bolt
2. bad ECU, but also very unlikely.
3. bad wiring with shorts or broken wires, very, very likely
4. bad on/off kill-switch, very possible
5. bad IG fuse. Also possibility and you'll get a steal if this is case!
6. if it doesn't crank at all, most likely interloc safety switches.
If you know how to use multimeter and can do basic AND/OR logic, get it!!!
No spark Oldskool 1986 - 2007 Ninja 250R Tech Talk 0 May 7th, 2019 12:19 PM
no spark ??? Racer x 2008 - 2012 Ninja 250R Tech Talk 4 February 25th, 2014 09:08 PM
Removing spark spark plugs? tsdexter 2008 - 2012 Ninja 250R Tech Talk 3 June 26th, 2013 03:48 PM
Why no spark? Flying Pig 2008 - 2012 Ninja 250R Tech Talk 12 January 30th, 2012 01:13 AM
95 with no spark... maynard 1986 - 2007 Ninja 250R Tech Talk 1 January 3rd, 2011 01:55 PM
