Old June 10th, 2011, 03:19 PM   #1
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
How to install LED front turn signals & relay
Here's the write up on how to install my LED P&P turn signal kit.
1. Remove the fairings. Please refer to this thread. I can post a quick DIY on how to remove the rear ones if you really need it. Just let me know.
2. Remove the OEM turn signal. It's just one screw. The screw is located on the back side of the blinker inside the blinker well. You might also want to break this screw loose before removing the fairing. I have a JIS #3 driver that I used. You can get away with a phillips #2. Here's a picture to give you an idea where it is: (taken from the DIY flushmounts thread)
3. Once you have the signal removed, just take the new one and put it in.
4. Put the washer on and the supplied nut. The nut is a 19mm or 3/4" nut. You can use a crescent wrench or even adjustable pliers. You don't need to torque it down very tight. Just tight enough the blinkers won't shift/rotate during riding. If for some reason the extensions are too short or too long, you can screw them in or out to adjust the length.
5. Run the wiring inside the fairing like stock. You may want to use some electrical/masking tape to keep it in place if you can't get it to stay.
6. Reinstall the fairings and enjoy the new lights .
The following is for installing a new relay.
1. Remove the seat, rear seat/cowl, and left side rear fairing.
2. Find the oem relay. It will be right in front of your face. Unplug the relay and zip tie the new one in place.
3. Plug in the oem harness and ground the attached cable. I chose the bolt that attaches the front of the gas tank bracket to the frame.
4. Switch on the lights to make sure they work and then reinstall fairings, rear seat/cowl, and seat.
The www.ModMy250.com guy
Old June 14th, 2011, 08:57 PM   #2
/linked from the main DIY thread.
Old June 19th, 2011, 10:15 PM   #3
Why does it need a ground wire? Are there any PnP relays that work for LEDs that don't need that?
Last futzed with by CZroe; June 20th, 2011 at 09:44 AM.
Old June 19th, 2011, 10:20 PM   #4
CThunder-blue
ModMy250.com
There are other ones that will work, but this one will work with up to 6 sets of lights so you can run rear LED's or other lights with the same relay. According to Tridon's website, the only other flasher with the same pin spacing and in a 2 pin configuration, which is also an electronic relay, is the EP12. I can't find a source for those unless I was to order them from AUS, which would just be more expensive than the EP34.
Old June 20th, 2011, 08:06 AM   #5
BlackNinja
Motorcycle(s): '09 2fiddy
Originally Posted by CZroe View Post
Why does it need a ground wire? Are there iny PnP relays that work for LEDs that don't need that?
Tri stated the technical know-how, but it definitely needs a ground wire. Mine didn't work till I hooked up a ground wire. I figured if he can put together a badass flush mount kit, I'll use the same relay he uses, as he has to know more than me.
BlackNinja is offline   Reply With Quote
Old June 27th, 2011, 10:56 AM   #6
pushkin
Motorcycle(s): 2008 ninja 250
Hey all,
I recently bought a universal LED turn signals (unfortunately, not like the ones mentioned above) and they won't blink =/ just stay on all the time.
I wanted to know if I can use the same EP34 relay or is it related to the signals themselves?
thanks for the help and this great post !!
pushkin is offline   Reply With Quote
Old June 27th, 2011, 11:07 AM   #7
CThunder-blue
ModMy250.com
Yes, you can use the EP34 to fix the problem .
Old June 27th, 2011, 11:50 AM   #8
pushkin
will give it a go and let you know how it went
thank man !
Old July 22nd, 2011, 11:12 PM   #9
DarkNinja52
DarkNinja52's Avatar
Motorcycle(s): Red 09 Ninja 250r aka Sheila (RIP), Red '10 Ninja 250r aka Sasha (Sold), White '13 Ninja 300 (To be Purchased)
I think I remember seeing a different relay used for other projects of this sort, that ddnt need a ground wire, but idk if it supports up to 6 sets of lights as you said this one does. im gona take a look and see if i can find it, im curious what the differences would be because its one i used to have on my old bike and just planned on getting teh same one again.
DarkNinja52 is offline   Reply With Quote
Old July 24th, 2011, 04:03 AM   #10
pushkin
Hey,
I didn't get that exact one (cause i couldn't find a store that ships to Israel) but i did get some other kind of "electronic flasher" and my problem was solved. The one i got was plug and play, no modifications were needed, no ground cable either.
I don't have any technical background but i think when you connect a large number of lights (or whatever) to the relay it increases the resistance and thus it might not work as expected (it's just an assumption here).
Old July 24th, 2011, 06:59 AM   #11
gfloyd2002
User Title Free Since '12
gfloyd2002's Avatar
MOTM - Feb '12
Finally installed mine yesterday (long vacation intervened between receipt and install) and they look great. With the Special Edition graphics, there is only one way they work without blocking the "Ninja" sticker, so mine are upside down from the way others (except for Oroboros I think) put theirs on.
Works and looks great. Plastic threaded bit could have been a 1/4 inch longer to make install smoother with positioning needed for SE graphics, but overall a simple thing. I'll put up pics when I take them.
Old July 24th, 2011, 12:40 PM   #12
CThunder-blue
ModMy250.com
Floyd, you can turn the nylon extension so it extends the length if you need to. It has about a half inch play.
Old July 24th, 2011, 12:47 PM   #13
gfloyd2002
gfloyd2002's Avatar
MOTM - Feb '12
Darnit. Yeah, that would have worked, lol. Still, connects well enough, I'll fix if it becomes an issue.
Old August 22nd, 2011, 12:09 PM   #14
chilloutdamnit
Guest
Posts: n/a
Will this work with OEM rear blinkers + led front blinkers?
Old August 22nd, 2011, 12:54 PM   #15
CThunder-blue
ModMy250.com
Yep. It's how I had mine set up until I found some awesome rear LED blinkers. The relay is still necessary with rear stock blinkers.
Old August 27th, 2011, 02:33 AM   #16
DarkNinja52
With 4 led's you needed the DIODE mod, correct??
Old August 27th, 2011, 08:18 AM   #17
gt_turbo
gt_turbo's Avatar
Motorcycle(s): '09 250R, '13 CBR500R
yep!
gt_turbo is offline   Reply With Quote
Old August 30th, 2011, 12:27 AM   #18
DarkNinja52
http://compare.ebay.com/like/1104633...=sbar&_lwgsi=y
this is the one i used to have. I believe it worked, but my bike burned in a fire b4 I had everything put back together. Do we have a 'database' of working flasher relays??
Old August 31st, 2011, 08:43 PM   #19
5evenz
5evenz's Avatar
Motorcycle(s): 09' 250r Thunder Blue
I have a tridon X lead 204 relay, works for back LED's but not front did i mess up wiring or do i need a different relay?
5evenz is offline   Reply With Quote
Old September 1st, 2011, 05:58 AM   #20
CThunder-blue
ModMy250.com
I've never used that relay before so I can't say for sure. You could try a different one and return it if it doesn't fix the problem.
Old September 1st, 2011, 11:09 AM   #21
5evenz
5evenz's Avatar
Turns out the relay is good i need some more resistance. Tried to mess with it for an hour and after melting one wire and making a great big mess I decided to man up and wait a day or to and get the nice clean connectors. Just ordered the no cut Diode kit Thanks btw.
Old September 1st, 2011, 11:25 AM   #22
CThunder-blue
ModMy250.com
Thanks, I'll get one out to you tomorrow or saturday.
Old September 1st, 2011, 07:48 PM   #23
jonnyc
Motorcycle(s): 250
hey how do you like those turn signals, I was thinking of getting those because they are not as flat as others, how bright are they?
jonnyc is offline   Reply With Quote
Old September 25th, 2011, 10:53 PM   #24
slim08xxx
Motorcycle(s): Ninja 250R
Where did you get those signals?
slim08xxx is offline   Reply With Quote
Old September 25th, 2011, 10:59 PM   #25
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
They are from his website www.modmy250.com
His products are well made and easy to install. He's very helpful and supportive with any questions you may have, and very fast to answer them. He's quick to ship your orders. I definitely recommend doing business with Tri. His LED front flushes and LED rears look awesome and his no-cut diode makes them work together and is very easily installed.
Trailerboy531 is offline   Reply With Quote
Old September 25th, 2011, 10:59 PM   #26
Cuongism
Cuongism's Avatar
He sells them himself.
www.modmy250.com
Tri, you probably should have your own website in your sig
Old September 26th, 2011, 07:36 AM   #27
CThunder-blue
ModMy250.com
Hehe. thanks guys. I've been meaning to ask Alex about that Coung. I just didn't want to violate any TOS.
Old October 13th, 2011, 12:52 PM   #28
Mr.E
That rider dude.
Mr.E's Avatar
Motorcycle(s): 2011 White Ninja 250 SE.
this may be a dumb question, but ill ask any who. should i/do i have to dissconnect the battery to do these things? only because doing so is a pain. thanks!
Mods: flushmount Led front binkers, diode mod, pazzo levers, clear tank pad, racing replica grips, bike monkeys integrated tal light, zx-2r vinyls, rearsets, red bar ends, and more red accented stuff.
Mr.E is offline   Reply With Quote
Old October 13th, 2011, 01:16 PM   #29
CThunder-blue
ModMy250.com
nope
Old March 31st, 2012, 12:02 PM   #30
b4idie
b4idie's Avatar
Motorcycle(s): Ninja 250r and 08 zx10r
Help!!!!
I just got my Protons and hotbodies undertail with LED turn signal for the rear. I was wondering if the ep34 relay will have them blink correctly without having to use resistors. If I need resistors which ones should I get?
Thanks in advance
b4idie is offline   Reply With Quote
Old March 31st, 2012, 03:43 PM   #31
CThunder-blue
ModMy250.com
The EP34 will definitely allow them to blink correctly. I actually stopped selling the EP34 though. I now sell a new relay that works just as well and only has 2 pins for a cleaner install.
Old February 25th, 2013, 03:59 AM   #32
hraklos
Motorcycle(s): ninja 250r
which relay is the one you sell??
hraklos is offline   Reply With Quote
Old March 18th, 2013, 05:35 PM   #33
ninja1234
Hey,
I'm kinda new to this site so don't really know how it all works but anyways, I had rear LED turn signals installed and they didn't blink until i installed the Tridon EP34 relay, and now they blink, but both at the same time... What could be causing this and how would I go about fixing it? Also not sure if it helps or if its the reason why, but I don't have any front turn signals installed. And on the dash the turn signal light does not come on... Any Help???...
ninja1234 is offline   Reply With Quote
Old March 18th, 2013, 07:17 PM   #34
CThunder-blue
ModMy250.com
Do you have front LED signals too? If so, you would need the diode kit, which I saw you purchased and I'm about to leave to the post office to ship to you tonight.
Old March 18th, 2013, 07:27 PM   #35
ninja1234
I don't have any installed currently, but I've purchased a pair off ebay a few days ago so I was going to install those once I receive them.. And I purchased the diode kit because from reading the posts I figured I would need it, correct?...
Old March 18th, 2013, 08:34 PM   #36
CThunder-blue
ModMy250.com
Yeah, you'll be needing them.
Old March 18th, 2013, 08:58 PM   #37
ninja1234
Alright, and about the turn signal indicator on the dash, is that just a blown bulb or something more?...
Old March 19th, 2013, 12:04 PM   #38
CThunder-blue
ModMy250.com
You might have blown it out.
Old April 8th, 2013, 10:07 PM   #39
carbonfibergsx
carbonfibergsx's Avatar
so first off i wanna say i am new to this site and modding bikes in general but i recently got new led front signals and a integrated led tail light and the hotbodies undertail kit and i see i need the flasher relay and diode kit but how exactly is this all supposed to tie in together do i need the diode kit in front and resistors in back im confused
carbonfibergsx is offline   Reply With Quote
Old April 9th, 2013, 05:51 AM   #40
sLick415
http://www.ninjette.org/forums/showthread.php?t=79642
sLick415 is offline   Reply With Quote
No idea how to install LED turn signals ChickenRun 2008 - 2012 Ninja 250R Tech Talk 3 May 2nd, 2013 01:51 PM
