Old December 13th, 2011, 05:30 PM   #1
djliquid
Motorcycle(s): '03 EX250, '06 EX500
Cali bike / 49 state replacement tank / hose routing help
Hi. My wife has a 2003 EX250 and the previous owner had it hit in San Francisco while parked.
Anyways, the tank was pretty beat so I bought a pretty good condition replacement on eBay. I took the old tank off - removed the petcock, fill cap assembly - mounted it back onto the bike and realized it only has 1 hose vs 3. To confirm I have all the CA emissions stuff on the bike and these 2 extra hoses with nowhere to go :]
It ran for like a minute and then sputtered and died. I tried bending the blue striped (to blue dot hose) and that didn't help... and i tried the same for the middle one (obviously with no luck). It also seemed to leak gas toward to top of the gas cap seal (~ 10 o'clock)
I am looking for some insight on how to get the bike to function - I assume it's a vacuum or emissions thing. Ideally if I can cap it off that would be ideal, while retaining the emissions stuff on the bike.
Thanks for the insight.
http://www.ninjette.org/forums/showthread.php?t=22296
http://faq.ninja250.org/wiki/Hose_ro...ine_fuel_tanks
http://kawasakiworld.com/zx-12r/2041...n-control.html
Last futzed with by djliquid; December 13th, 2011 at 05:34 PM. Reason: I'm dumb
djliquid is offline   Reply With Quote
Old December 13th, 2011, 05:38 PM   #2
/moved to pre-gen tech area
Old December 13th, 2011, 05:40 PM   #3
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Those hoses are for the Kleen Air System, a useless piece of junk. There is a DIY on removing it but it is for the newgens. You can still follow the DIY, things will just be in different places.
http://www.ninjette.org/forums/showthread.php?t=9948
You're going to need a few caps to plug some hoses and the holes on the bike. Good luck
AFM #676
Supersports are for n00bs
Old December 13th, 2011, 05:46 PM   #4
djliquid
thanks, guys.
I'll give that a look. If anyone stumbles into a thread for a 2003 (or any pre-2007) it'd be greatly appreciated.
peace-
e
Old December 13th, 2011, 06:03 PM   #5
Skippii
Milkshake Drinker
Skippii's Avatar
Whoa....Isn't the KAS the air-into-exhaust injection system that comes on new bikes to optimize catalytic conversion of unburnt hydrocarbons as the expense of NOx gases? The thing that makes them all pop on decelleration?
That's a totally different thing with a totally different purpose than the evaporative fuel system, which stops gasoline from evaporating out of your tank.
"What a sweetheart."- ninja_sleeper to me
Old December 13th, 2011, 09:20 PM   #6
djliquid
i re-read this page.
On the 49 state tank there's the one hose outlet (drain).
49 state models have only one hose coming from the rear of the fuel tank. This is a drain hose for fluid that gets in the depression between the filler neck and the top of the tank, from being in the rain or overfilling the tank. Air vents into these tanks
On the Cali tank there's 3 (L-R), with the middle apparently the drain.
  • The right tube allows air into the fuel tank through the gas cap as the gas level drops. This tube must remain open.
  • The middle tube is the drain and should keep the stock routing under the bike in the hose cluster (right-hand side of the frame, as discussed above).
  • The left tube circulates fumes to the emissions system and should be capped off.
I vented the red tube - running it to the left side by the coolant reservoir.
I capped off the third tube (blue stripe) by bending it back and ziptieing (like with landscape irrigation).
I started it up and it ran fine for at least a few minutes, which is way more than before, and showed no sign of stalling. The red tube did drip some gas, but this was likely because I had stupidly hooked it up to drain before reading anything.
So far so good - will report after more thorough test.
Old December 14th, 2011, 09:17 AM   #7
Jinx250
Smoker
Motorcycle(s): Guess....
Yank the round R2D2 looking thing and the rectangular lunchbox and all the assorted hoses. Then swith out the vacuum line on your carbs from a 2 piece hoe with a T in the middle to a one piece with no T.
And the system is call the CA evaporative emissions control or some BS like that. The Kleen Air System is totally different and does not exist on the 250.
Jinx250 is offline   Reply With Quote
Old December 14th, 2011, 09:33 AM   #8
CynicalC
CynicalC's Avatar
Motorcycle(s): '96 EX250
I had the exact same scenario with my bike. Rip all the emissions stuff off and replace that little hose on the carbs (the one with a T in it) with a piece of solid hose. The nipple on the tank is just a drain. Send it right down to the ground.
Ç¥ñ頻| ßÿ Ñâ7µ®é. Äñt¡~§º¢Ïä| ßý Çhøî©è.
Carb Hose Routing jschatte 1986 - 2007 Ninja 250R Tech Talk 6 July 8th, 2014 08:30 AM
vacuum hose routing Sebastian f7 1986 - 2007 Ninja 250R Tech Talk 2 July 28th, 2013 07:06 AM
Need Visual Confirmation of Carb Hose Routing indr 2008 - 2012 Ninja 250R Tech Talk 3 June 23rd, 2013 07:49 PM
Routing for fuel overflow hose haze5736 1986 - 2007 Ninja 250R Tech Talk 3 July 7th, 2011 07:09 PM
Routing for 'side hose' on fuel tank kobachi 2008 - 2012 Ninja 250R Tech Talk 11 December 12th, 2010 05:00 PM
