March 26th, 2019, 08:11 PM | #1 |
Join Date: Mar 2019 Motorcycle(s): 2007 Ninja 250R Posts: 14
250 Sputters and lags on acceleration at speed?
So I have come across a problem and as a newbie I still don't even know where to begin.
The bike seems to lag or stutter when I go full throttle when I'm cruising. I'll be going along in 2nd gear or 3rd then gun the gas and it like skips a beat until I shift gears again. This may be relevant but the idling is wonky, it sits really high and when I turn the idle screw a little down it will bog out the engine and maybe die or sit until revved again. Could it be carb? The gent I just bought it from said that it had been sitting for a minute as he didn't ride it. Any thoughts on what it might be? Any help would be much appreciated! I've never cleaned a carb before so if there's an easy way to check if it's that before taking the whole thing apart, any tips would be awesome. |
March 27th, 2019, 08:00 AM | #2 | |
yes, very likely
March 27th, 2019, 05:21 PM | #3 |
Yes, you need to examine carbs closely. Symptoms indicate insufficient fuel delivery, most likely due to clogged carb fuel-circuits. As a test, you can try limiting air-flow to countre-act lack of petrol when going full-throttle. Read this thread and the linked ones within.
https://www.ninjette.org/forums/showthread.php?t=331186 |
March 28th, 2019, 07:10 AM | #4 | |
Any other suggestions if it wouldn't be the carb? |
March 28th, 2019, 07:38 AM | #5 |
Join Date: Feb 2018 Motorcycle(s): Harley Fatboy, Honda CX500, Harley XL1200C Sportster, 305 Honda Dream, Ninja 250 Posts: 174
The passage ways in a carburetor are extremely small. Just looking is not a way to ensure your carbs are clean. Even an ultrasonic bath will not always get the crud out. Fine wires, carb cleaner and air will after a good ultrasonic bath. I also use q-tips.
March 28th, 2019, 07:44 AM | #6 |
fuel delivery issue?
*tank vent? *petcock? *air restriction (filter, intake snorkel?) you never clarified the "sitting for a minute" statement. Visually "spotless" is positive, but does not necessarily indicate clarity of circuits, fully justifying your confirming. Just who cleaned these carburetors...the previous owner? Did the bike ever run correctly during your ownership?
March 28th, 2019, 05:15 PM | #7 | |
[motogp.com] - Honda: progress with acceleration and top speed | Ninjette Newsbot | Motorcycling News | 0 | March 3rd, 2018 09:10 AM |
Sputters When Warmed Up | Scattcatt | 2008 - 2012 Ninja 250R Tech Talk | 17 | November 10th, 2017 01:29 PM |
HELP! Bike coughs sputters almost shut off but then ran | cadymae | 2008 - 2012 Ninja 250R Tech Talk | 16 | August 20th, 2015 09:40 AM |
bikes throttle sputters at WOT | ninjamatt03 | 1986 - 2007 Ninja 250R Tech Talk | 11 | September 16th, 2014 07:37 PM |
Tips for fast acceleration from a stop on ninja 250? | fr1dayn1ght | General Motorcycling Discussion | 25 | June 23rd, 2013 07:53 PM |
