May 31st, 2013, 08:21 AM | #1 |
Wartown, USA
Went 150/60/ZR17....
Ok, so I've been wanting to try out a 150 on my ninja 250R just to see what it would be like, and after reading the posts from folks that have done it...went for it.
I chose the Michelin Pilot Road CT2 150/60/ZR17 tire. First off, I dont know what crack the 150 proponants are smoking, but a 150 most definitely is not a "no clearance issues" tire for the 08 and later 250R. Yes, you can install it, and yes it will work. However, you are left with a baseball card thickness worth of clearance between the tire and the chain guard, and more importantly...between the tire and the right side of the swing arm. Now... Is that enough clearance to run it. Yes, provided you watch your tire alignment and air pressure religiously. After running this tire on my 250, through a rather hot run in the twisties, where I deliberately tried to get the tire to flex as much as possible, there are absolutely NO signs of any contact at the tight spots. I'm running 40psi in the rear to keep it nice and stiff. If you prefer lower air pressures for stunting, etc., it might be a possibility the tire will flex and make contact in the tight spots. IDK. Now...as far as how it changes the handling of the bike. Personally, I love it. Gone is the "twitchy in the wind" feeling on the interstate. The bike tracks like its on rails, and is much easier to maintain your intended line through the corners. In addition, since its a radial dual compound EXTREMELY sticky rear tire, it hooks into corners like a dream and drives out of the exits with authority. As far as "loss of flickability"...I'm not seeing it. The bike still corners just as well as it did before, what I notice is less of the oversteer/understeer constant line correction that was necessary with the stock 130 rubber band that is normally used, instead I now have a very smooth instinctive "go where I point it" feel in the corners. To be honest....this is what should have been on the bike from the factory in my opinion. Here is my set up... Front tire. Michelin Pilot Power 120/70/17 - at 30psi Rear tire. Michelin Pilot Road CT2 150/60/ZR17 - at 40psi - rear shock on "3" |
May 31st, 2013, 08:30 AM | #2 |
Have you tried a 140? Plenty of clearance and delivers a lot of the positives you mention.
May 31st, 2013, 08:35 AM | #3 |
Fast-Guy wannabe
MOTM - Jan '13
Dude there was like 10mm of clearance to the swingarm with the 17-150/70 Michelin Pilot road 3s I was running. I think you mounted you tire backwards
May 31st, 2013, 09:06 AM | #4 |
Wartown, USA
Um...tire is same width forwards or backwards...but mine is oriented correctly for direction of travel. Also, aligned and installed correctly. Its a big tire....obviously much larger than the 3.
May 31st, 2013, 09:10 AM | #5 | |
Fast-Guy wannabe
MOTM - Jan '13
Maybe you mounted it inside out |
May 31st, 2013, 09:23 AM | #6 |
Join Date: Apr 2013 Motorcycle(s): 250/300 Posts: A lot.
Hey Unregistered never go faster than your brakes can be applied... |
May 31st, 2013, 09:36 AM | #7 |
Jigglin' your Jiglets
MOTM - Apr '13
Have you ever tried Rosso 2's? And 40psi? Are you nucking futz?
May 31st, 2013, 10:47 PM | #8 |
Join Date: Mar 2012 Motorcycle(s): Ninja 250r 2010 SE Posts: 573
May 31st, 2013, 11:24 PM | #9 |
King Hamfist
Join Date: Oct 2012 Motorcycle(s): 2007 Crf 150R, 2011 Hypermotard 796 Posts: 940
I have a 150 and there is plenty of clearance for a hand or two. The radial tires will all have the positives that you mentioned. Eventually try the Pirelli rosso II's in a 140 width. I was really happy with them. @Jiggles I'm looking up tire pressure stuff now. I'm going to do some investigation. Basically I'm going to do a little street ride and figure out how hot I get the tires and play with setting the cold psi a few ticks below that. Words of wisdom from a crazy European guy I met at Sonoma. "It's just a street bike, who cares." This was said after he rode out to check out practice and his front tire had something like 19 psi in it.
June 1st, 2013, 06:02 AM | #10 | |
Long Time Rider
40 PSI is high for the Ninja 250, even riding 2-up. Most of the big heavy cruisers (i.e. Vulcans) run tire pressures in the 40's. You should be good with 32-36 PSI. A good long run on a hot day or sitting out in the sun can raise tire pressure by up to 5 PSI from the cold inflation PSI. |
June 1st, 2013, 07:46 AM | #11 |
Join Date: Aug 2010 Motorcycle(s): 09' 250 ARRRRRR Posts: 130
I just got 150 70 pilot road 3 from revzilla and I CAN NOT GET THE BEAD TO SEAT. Did you have any issues? Even my local kawasaki dealer couldnt get it on.
June 1st, 2013, 08:40 AM | #12 |
MOTM - Apr '13
I leave my track pressures in my street tires, xept the bmw
June 1st, 2013, 02:49 PM | #13 | |
Personally, I noticed it minimally when going back-to-back between two sets of tires on my ninjette, but only when tossing it quickly from one direction hard to the other. Not that I'm saying that one type of tire was ever a 'bad' tire or that the bike felt slow to transition, but when going back-to-back, I noticed a small difference. Same idea as adjusting gearing; you only notice it right away. Once you get used to it, it's a non-issue. Is 'flickability' worth choosing one set of tires over another? likely not. The bike will still be light and nimble and a load of fun on curvy roads. Again, this is all a theoretical point for discussion. In reality, YMMV. You might notice a difference if you ride with very quick, sharp directional changes; you might not if you like to be smooth and even in your carving. As long as you like your tires and like the feedback you get while turning, that's the important part. |
June 3rd, 2013, 08:28 AM | #14 |
626ER
Join Date: May 2013 Motorcycle(s): 08 Ninja 250 Posts: 40
I have the same exact sent up as you and im loving it!!!!!! Also looks a lot better
June 3rd, 2013, 08:36 AM | #15 | |
Fast-Guy wannabe
MOTM - Jan '13
I don't think I had any funny issues but I do use a good tire lube. If you ever have trouble beading a tire try wrapping a ratcheting tie down around the circumference of the tire and cranking it down to spread the bead and keep moving the tire around till you get lucky. I've had some crazy hard to head tires in the past but my PR3's weren't ago them. |
June 3rd, 2013, 12:53 PM | #16 |
Wartown, USA
I gave the tire to a local shop, and let them put it on. They had it on in minutes, didn't seem to give them any issues. At least they didn't say anything to me. However, mine is a Pilot Road 2CT, not the 3...so perhaps that makes a difference. IDK.
June 3rd, 2013, 12:56 PM | #17 | |
Wartown, USA
Normally I run rears in the 38-42psi range, and I'd feel comfortable running this setup in that range. 24-26psi is in the "overstress the sidewalls, and prepare for blowout on hot day" range..even for a bicycle tire, so no. |
June 3rd, 2013, 12:57 PM | #18 |
Fast-Guy wannabe
MOTM - Jan '13
Every style of tire is different but they will all bead eventually. I find Bridgestone street tires to be a total bitch to bead because of the stiff carcass.
June 3rd, 2013, 02:01 PM | #19 |
not an actual panda
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250, 2009 CBR600RR (Sold) Posts: A lot.
So on a hot day and a spirited ride your pushing what.... 47psi in the rear if your 42 cold? Also I am running 150 shinko podium and I have no clearance issues.
June 3rd, 2013, 02:04 PM | #20 |
Join Date: Jun 2012 Motorcycle(s): 12' Ninja 250 Posts: 831
Pics ?!
June 3rd, 2013, 02:11 PM | #21 |
Fast-Guy wannabe
MOTM - Jan '13
June 3rd, 2013, 04:09 PM | #22 |
not an actual panda
Helium in tires + backwards = 15rwhp at least
June 5th, 2013, 11:20 AM | #23 |
Wartown, USA
It usually tops out around 41.6psi on a spirited 20 min ride.
Normally, for every 10 degrees F outside temperature, the psi goes up 1. I check pressures EVERY morning before riding. Also, the cold temps on a tire are the max inflation at COLD....not the max pressure. So if the max cold pressure is listed on the tire as 40psi, it is designed to handle 40+ hot, also....underinflated tires generate more heat, and also increase pressures more rapidly. Properly inflating one, will make both the tire temps and the pressures more stable. |
June 5th, 2013, 11:55 AM | #24 |
MOTM - Apr '13
That's some high ass pressures! I run the lowest I can in my beamer without it yelling at me that the tires pressure is low which is about 36 psi in both
June 7th, 2013, 05:56 PM | #25 |
Took it to tire kingdom, firestone, columbia power sports, and my friends tire shop. In the end carb cleaner and a bic did the trick. It's rained the past few days here, and wet grip/drive out of corners is AMAZING
July 12th, 2013, 06:59 AM | #26 |
Join Date: Apr 2013 Motorcycle(s): '04 919 / '08 250r / '95 xr100 Posts: 39
All this and not one pic of a 150 installed?
July 12th, 2013, 07:12 AM | #27 |
Fast-Guy wannabe
MOTM - Jan '13
July 12th, 2013, 07:35 AM | #28 |
July 12th, 2013, 07:49 AM | #29 |
Fast-Guy wannabe
MOTM - Jan '13
July 12th, 2013, 05:00 PM | #30 |
July 13th, 2013, 04:54 AM | #31 |
Rojo kinda kills tires. Effortlessly.
He might not be the best one to ask about how rear's are holding up, seeing as he likes to run a sweet tire in front, and a crummy IRC roadwinner in rear. He might just be the first person to get even wear on an IRC roadweener. |
July 13th, 2013, 05:25 AM | #32 | |
Fast-Guy wannabe
MOTM - Jan '13
The 140 road winner on the back is doing great, still gripping the asphalt like a mofo and showing very little wear over 4000 miles into its life. I have a good feeling about this one, it may be my first rear tire I can get to go to cords on both sides and center. When I change the front tire here soon ill flip the rear tire again to keep the wear even As for the PR3's they made it like 6000miles before they got to the cords so they are my longest wearing tire besides OEM. When I first mounted them up I loved them but during the last couple rides I started to lose faith in the front a bit for my more spirited(not your normal level of spirited) rides and when I finally went back to a full race tire I fell in love all over again. Sure the race front wears fast then the road fronts but I can run them several thousand miles farther then a road front simply because even with the tire bald it still grips and feels great. But ill still mount a PR3 front for our short winter since I ride in the rain when it finds me. |
July 13th, 2013, 08:42 AM | #33 | |
We finally found a rear that might get as much mileage as a front for Jason. Who'da thunk it'd be an IRC??? |
July 13th, 2013, 12:22 PM | #34 | ||
March 16th, 2015, 11:28 AM | #35 |
Join Date: Feb 2015 Motorcycle(s): Ducati 998s, Aprilia RSV 1000r, Aprilia RS250 , 2012 Kawasaki Ninja 250 Posts: 2
worn out safety hazzard
Wow, unbelievable!! I can't believe anyone would even run a sportbike tire with any cords showing. The way I ride, its definitely not worth the consequences. hopefully my friend you are not on the road with this....it only takes one time for that thing to go at the wrong time and your done.....not cool! Cords do not heat up and stick....the rubber does!
March 16th, 2015, 11:32 AM | #36 |
Welcome David!
There are few riders here who are above the normal curve, Rojo is one of them. If he feels he can rock that tire, then just take it at face value as one might have a different risk vs. reward curve than he does.
March 16th, 2015, 12:10 PM | #37 |
Inline 4!!!
Thanks for the input
I've been toying with the idea of putting a 150 on my 300, but since I plan on doing some track time with the ol' 300 I don't think I want to attempt anything that could compromise the handling. ....Either way, I want one just not sure if I'll pull the trigger.
March 16th, 2015, 12:15 PM | #38 |
Certified Troublemaker
I got a 160 for my 300. Yes, i'm nuts. I fully admit it. No track plans at the moment and if i do i'll get track tires anyway. I should have them mounted this weekend.
March 24th, 2015, 01:30 AM | #39 |
More like below the curve I think if I'm understanding you right. I have a stock pile of race tires and road tires that will fit his bike that have less then 500 miles on them that I am willing to pay shipping on and give him for free if its a money issue just so as these type tires are not put on the road for his safety and those who will be at the receiving end. I really can't imagine anyone enjoying riding on cords on edge. I would just hate to run him over not if but when the tire lets go in a turn. Just saying......
Bridgestone Battlax BT-016 Rear Tire 150/60 ZR17 100$ | krolinked | Motorcycle-related | 0 | January 7th, 2013 06:39 PM |
FS: Michelin pilot powers 110/70/zr17 150/60/zr17 | Havok | Motorcycle-related | 14 | June 19th, 2012 05:20 PM |
[topix.net] - 2010 Ford F-150 Harley-Davidson, an AW...2010 Ford F-150 Harley-Davidso | Ninjette Newsbot | Motorcycling News | 0 | March 24th, 2010 02:00 PM |
Ninjtiny anyone 150 RR | ztrack157 | General Motorcycling Discussion | 31 | October 7th, 2009 06:17 AM |
