September 3rd, 2014, 07:54 AM | #6081 |
Well it looks like I am most likely stuck with making the Chinese lock to work. Seller will refund me after I send it back but has given me the opportunity to get it working so he can probably have the others fixed with my modifications lol.
September 3rd, 2014, 08:55 AM | #6082 |
Join Date: Jul 2014 Motorcycle(s): 08 Ninja 250 Posts: 15
Today i fixed an outstanding issue Ive had with my bike for weeks. It wouldnt pull past 9K rpms any gear (except neutral). Found the issue was a pinched snorkel on the air box.
Sooo happy its fixed. Today I should also get my jetting kit. Cant wait!!!! |
September 3rd, 2014, 05:13 PM | #6083 |
Join Date: May 2013 Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50. Posts: 186
New pistons and rings in the old '92 ninjette, along with a freshly honed low mile cylinder.
Rear shock from a '12 to go in today or tomorrow along with '06 forks I have replaced seals and bushes in. Old girl getting a new lease on life.
Originally Posted by jgcable; I ride a 2006 Custom HD Wideglide..... and I almost have to sign autographs when I park it. |
September 3rd, 2014, 06:07 PM | #6084 | |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
Oh yeaaaa... It happened |
September 3rd, 2014, 06:08 PM | #6085 |
Haha an posted upside down
September 3rd, 2014, 07:59 PM | #6086 |
Stock pistons or did you bump up the compression?
September 3rd, 2014, 08:11 PM | #6087 |
You pulling the snorkle off with the jet kit? It def helps the air flow, whatcha doin to your bike???
September 3rd, 2014, 08:19 PM | #6088 |
Chinese ignition lock is working. Soldered in resistor and jumper wire. Might have to epoxy or JB weld this crap together so it doesn't fall apart.
September 4th, 2014, 12:12 AM | #6089 |
Stock pistons, bought them last year before I stripped the engine.
Then found out it was bored .5mm oversize. No.1 piston and bore were marked bad so waited until I could find a decent cylinder.
September 4th, 2014, 08:43 PM | #6090 |
September 4th, 2014, 11:24 PM | #6091 |
Jersey Devil
Join Date: Oct 2012 Motorcycle(s): '06 Ninja 250 Posts: 469
Clutch gasket came in.
Now I need a new battery, though. One thing after another once I hit 27k I swear.
~Riding like a grandma because I wanna ride as a grandma~ |
September 5th, 2014, 06:36 PM | #6092 |
Join Date: Aug 2012 Motorcycle(s): 2012 kawasaki ninja 250r special edition Posts: 255
oil filter
i just got rid of this beauty anybody would like to buy a brand new k&n filter in the box( the one with the nut on top) |
September 6th, 2014, 10:54 AM | #6093 |
September 6th, 2014, 03:36 PM | #6094 |
sammich maker
MOTM - Apr '15
I cleaned mine and put on new decals, pics later...
September 6th, 2014, 03:41 PM | #6095 | |
MOTM - Jan '18, Sep '13
September 6th, 2014, 04:32 PM | #6096 |
Maybe the bike has a nut on top, sometimes I think mine does.
September 6th, 2014, 04:36 PM | #6097 |
Fitted shock from 2012 model, I see it lifts the rear a little, now to work out the correct oil level.
Destroyed one of the swingarm bearings trying to get them out to fit new ones, expensive excercise, ended up replacing the swingarm.
September 6th, 2014, 08:46 PM | #6098 |
Jersey Devil
Changed out the clutch plates.....to find that the old ones still looked pretty much fine. Dx
However, had I not changed it, I wouldn't have found out that I was missing a bolt for the clutch plate cover and all the rest I could almost undo by hand! I was shocked. Probably explains where all that oil was randomly leaking from. They're all torqued down to spec now and I had to switch out an old fairing bolt for an oil screen cover bolt to stick that where the missing clutch plate cover one was. This poor ****ing bike has so many wrong screws in the wrong places. A couple more and it'll be worth buying a new fairing bolt set. Got two ziptie mods on the front already. Changed the oil and cleaned the screen. Oil was so dark and the screen was full of ****. He needed it bad.
September 7th, 2014, 12:38 AM | #6099 |
Certified looney toon
MOTM Jul '13, Jul '14
A new pair of shoes!! (Again)
Destroyed the BT-45s, front got me just over 16k and the rubber was beginning to crack and peel (!), rear got me just under 10k - like 9400, and the center tread was so completely gone the shop guy doubted I'd make it back to Reno. So, back to Pirelli Rosso IIs as those were the only tires in my size they had in stock and luckily they had both front and rear right on the edge of the display rack so I spotted them as soon as I walked in. Props to 5th Gear in Elko, had me out the door two and a half hours after walking in. Great customer service and very friendly staff.
September 7th, 2014, 05:35 AM | #6100 |
Join Date: Aug 2013 Motorcycle(s): 2012 Ninja 250 Posts: 450
Pulled the tank to fix a corroded wire problem that stopped the bike dead in it's tracks tuesday forcing me to push it 6.5 miles back home to get to it to work again, which i was 4 hours late from a plug so corroded some of the wires and spades were green. There were also a couple of wires turned black from corrosion that had to have 12" of the wire replaced and soldered in they were that bad.
Keeping my fingers crossed all is well again, and i do not get stranded anywhere forcing me to push the damn thing unless i run out of gas. lol |
September 9th, 2014, 11:56 AM | #6101 | |
September 12th, 2014, 08:55 AM | #6102 |
Join Date: Sep 2011 Motorcycle(s): 2007 R6, 1991 EX250 Posts: 10
I removed the radiator, exhaust, and other various bits to start prep for a slight engine rebuild.
September 12th, 2014, 09:22 PM | #6103 |
Join Date: Jul 2014 Motorcycle(s): 2006 Honda ST1300, 2001 Ninja 250 Posts: 53
I ordered a new rear tire to replace the already new tire that got TWO holes in it and won't hold air with two plugs. AARRGGHHH! How two holes? I think I ran over a soldering gun tip.
Current vehicles: 2001 Ninja 250, 2007 Honda ST1300, 2013 Mustang GT, 1998 Firebird convertible, 2003 Jeep Grand Cherokee |
September 13th, 2014, 10:59 AM | #6104 |
Join Date: May 2013 Motorcycle(s): 10 Ninja 250 Posts: 172
rode from autozone about 5 miles to my home with two car rotors in my backpack...
Note to self: dont ever do that again |
September 13th, 2014, 01:12 PM | #6105 |
Join Date: Apr 2014 Motorcycle(s): '08 Ninja 250 Posts: 132
Well, just went through my third upper fairing stay. This one was "new", bought it from Tyga. The fairings line up better on this fairing stay than the rest, but they bulge out due to me giving them some tough love when aligning the side fairings on the frame.
So either this third fairing stay is bent as well, or something else on the bike is bent. The the side fairings seems to be fine when on their just by themselves with no nose fairing though. Now I have two "bent" fairing stays lying around the garage. Stupid crashes. |
September 13th, 2014, 08:02 PM | #6106 |
I lane splitted for the first time today! Stuck in Auburn traffic and was looking at a digital temp gauge reading 102*.
So I split to the front of the line to get moving again. spent the whole block chanting "please don't hit me, please don't hit me" Go me!
<-- Linky Hey Unregistered! The code [you] shows the username currently logged in. IBA # 56020 AMA # 521481 Fun Rides! ][ My Videos ][ My Gear Hold yourself to the same rules you expect others to follow. Last futzed with by NevadaWolf; September 13th, 2014 at 09:28 PM. |
September 13th, 2014, 08:12 PM | #6107 |
Certified Troublemaker
Join Date: Oct 2012 Motorcycle(s): 2006 Ninja 250r "Pikachu", 2017 Ninja 650 "Epona" Posts: A lot.
Raven's Rejuvenation A bruise is a lesson... and each lesson makes us better... |
September 13th, 2014, 09:00 PM | #6108 |
Private Joker
MOTM - Mar '14
That looks perfect, what brand stomp grips is that? I intend to get some clear stomp grip for my pregen and 300
September 13th, 2014, 11:02 PM | #6109 | |
Pretty sure stompgrips is the brand name. I think they even say it in that picture |
September 14th, 2014, 03:20 PM | #6110 |
Wrench wench
Join Date: Jun 2014 Motorcycle(s): TWO HUNDRED FORTY EIGHT CUBIC CENTIMETERS (R.I.P.), SIX HUNDRED FORTY FIVE CUBIC CENTIMETERS Posts: 415
I cleaned the carbs, which turned out to be pretty much unnecessary. They were amazingly clean inside. Everything was in tip top shape, plus one of the POs did me a favor and drilled out the EPS plugs.
Getting them on/off (especially on) the bike was orders of magnitude harder than actually cleaning. Tomorrow: sync. |
September 14th, 2014, 04:53 PM | #6111 | |
Just have to get the bike specific ones, the universal pads don't fit the 300 at all.
September 14th, 2014, 05:38 PM | #6112 |
September 14th, 2014, 05:42 PM | #6113 |
I ain't got time for that.
And it would have looked likr poop in my opinion. For the same price you can get the bike specific ones.
September 14th, 2014, 05:46 PM | #6114 |
I probably would've gotten stompgrips instead of techspecs if the bike specific ones were available at the time. I definitely wasn't gonna cut them myself either haha.
September 14th, 2014, 06:37 PM | #6115 |
Join Date: Mar 2014 Motorcycle(s): Currently own: 98 Honda VTR1000, 02 Suzuki's DR200 & DR650, 04 & 08 BUSA's, 05 Ducati SS1000, 12 Ninja 250R SE Posts: 59
Gave the Ninja a rest...and went for a 2 hour rip on my '08 Busa -
September 16th, 2014, 02:54 PM | #6116 |
beater 250 motor oil has fuel contaminated oil. Starting to wonder if I have stuck floats or bad float valves or that my short commutes to and from work have anything to do with it.
September 16th, 2014, 07:02 PM | #6117 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
I mounted my new camera, and played with it a little...
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. |
September 16th, 2014, 08:33 PM | #6118 |
Join Date: Jan 2012 Motorcycle(s): Ninja 250r - Track whore, Ninja 300 - SOLD, KTM RC390 - Orange Hulk, Ducati 899 Panigale - Red Devil. Posts: A lot.
Left her at the shop to install radial caliper, master cylinder and silicone hoses.
September 21st, 2014, 07:36 PM | #6119 |
September 21st, 2014, 08:12 PM | #6120 |
Join Date: Jul 2014 Motorcycle(s): 2011 Ninja 250R (Sold), 2015 Rocky Mountain Soul (Runs on fat) Posts: 404
Discovered something scary about my Ninjette today... | kjohng | General Motorcycling Discussion | 28 | October 15th, 2021 01:40 PM |
Sold the 2006 Ninjette today :( | Renner | General Motorcycling Discussion | 31 | October 16th, 2014 11:46 PM |
Today I Gave My Ninjette Wings! | BlueHairSar | Pictures | 5 | June 20th, 2013 07:38 AM |
my bro went down today on his ninjette | richierich781 | !%@*#$%!)@#&!%@ I crashed! | 46 | January 18th, 2013 11:59 AM |
Ninjette. org hacked today | CC Cowboy | Off-Topic | 9 | April 3rd, 2011 08:55 AM |
